How to service old Campagnolo Record front hub?
how do i disassemble an old campagnolo record front hub? i am having one hell of a time trying to figure that out. i have disassembled many front hubs but these are completely different as there is no way to use a cone wrench on these hubs. whats the trick?
this is exactly how my hub looks:
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 705 Times
Jeff Wills
Jeff Wills
Great State of Varmint
Liked 15 Times
Here's Park Tool's take on the old standard hub with loose bearings. Be sure to measure the bearings before replacing them. Grade 25 Chromium-Steel is the most commonly used ones:
https://www.parktool.com/repair/readhowto.asp?id=105
And here's the Bicycle Tutor video:
https://bicycletutor.com/overhaul-wheel-bearings/
Have fun!
Have fun!
NO "trick" to the front (or rear). Easy as pie. The front cones require a 13mm cone wrench. The outside nut requires a standard 16mm box wrench. That's all, ever, period. Do NOT ever remove the dust caps. EVER! Once disassembled and fully cleaned, VERY lightly grease the races, make sure the bearings are fully greased in hand and the cone has a slight coating of grease for that part of assembly. For final reassembling, assuming the axle is perfectly centered (!!!), on final setting calibration, always set fractionally "loose", hardly detectable in hand......., you will feel it is not perfectly set. This applies to both front and rear........ When correct, the quick release - with proper closing pressure shores up the gap (wobble) for perfect pressure between the cone to bearings to race. Many times you have to go back and forth to get this set right. Yes, it can be a pain. But, it's the difference between your standard, everyday junk "wrench" job and true precision. Ask me why I have SR hubs/wheels from the 70's and 80's that have over 130K+ miles on them and are perfect. Once precisely set you can simply periodically regrease without disassembly through the side cap dust hole. Just a light application works well enough several times per year. Purge will come out between the con and cap. Many greases work perfectly, but I've always employed Phil Wood. It's the easiest to inject through the aforementioned cap hole.
On the rear you employ two 14mm cone wrenches per side.
Likes For Camilo:
Quoted: 4396 Post(s)
Liked 1,555 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
That's a C-Record front hub, not a vintage Record front hub. Unfortunately, the OP's picture of the actual hub in question has disappeared in the 13 years since the question was first posted, so we'll likely never know if the OP was referring to a Record or a C-Record hub.
To service the C-Record hub, you need a special tool to remove the end caps on the hub shell to expose the nuts, as @Jeff Wills noted at the time:
For the older Record hub, a pair of 13mm cone wrenches will work.
Quoted: 805 Post(s)
Liked 705 Times
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 4201 Post(s)
Liked 3,857 Times
Do I recall correctly that Campy Valentino/Gran Sport front hubs do use a 16mm lock nut? Andy
AndrewRStewart
AndrewRStewart
Old fart
Liked 3,400 Times
Both Record and Gran Sport/Tipo front hubs use a 16mm lock nut. Record rear hubs use a serrated locknut with 14mm flats, and Gran Sport/Tipo rear hubs use a 17mm locknut.
Liked 1,555 Times
KONTACT: The remarks in my original post were specific to the classic SR hub as demonstrated in the photo with the referenced 16mm outside nut/13mm cone. Whether of interest or not, this hub/wheel (and its rear brother) are now around 40 years of age with approx. 110k miles on same. All original spokes (2.0/1.8 with brass nipples) on the SSC's. 32x3X "Build from strength". I have no time for cutting corners and saving some ridiculous gram or two........
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
those are some beefy spokes for a front wheel.
Looks like an SSC rim however.
Very pretty
/markp
Very pretty
/markp
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 983 Post(s)
Liked 632 Times
Oh, c**p, I inherited a set of wheels with those hubs, and old enough I'll need to get inside. Is that tool unobtanium? It looks kinda like gear puller but suspect the exact size is critical. OK, a search for "Campagnolo hub tool" on eBay finds some, $150-$200; perhaps cheaper to discard the wheels and start over.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Liked 3,857 Times
One can pull off the conical dust caps that cover the axle's cone and lock nut with a thin blade. Of course there is the greater possibility of slight cosmetic marring than if the Campy tool was used. I've done a number of overhauls on these hubs (personal and customer) without using the tool. Just take care and "work" around the dust cap bit by bit. Andy
AndrewRStewart
AndrewRStewart
MPETRY : It looks like an SSC because............ It IS an SSC. They, along with the Nemesis are the only two I've ever run since they came on board. Beyond ballistic. Confident. They haul. Alas, only the Nemesis THANKFULLY are still being made. I genuflect before Ambrosio for that. Clinchers......?? How hysterical.
If you go back and re-read, the spokes are simply classic 2.0/1.8, or 14/15's. I honestly cannot imagine so much as THINKING of going lighter. No need. All this worthless lightweight insanity is, simply stated, at a minimum unreliable, or WORSE! No one wants to know of still standing UCI fastest course records from the 1950's, 1960's, 1970's, 1980's when the lightest rig was coming in at 21lbs/9.5kg, earlier still 23lbs/10.5kg, all with friction shifters, a 5/6/7 cog rear, "etc.". It has become so plastic now. So plastic. So plastic. So soulless. So fay. So pre-assembled. So Made in China. Pure pop out plastic fantastic, etc....... Thank goodness I and others knew it when........
Likes For equinoxranch:
