Trek BB90 Bearing Fit
Old 08-31-20, 03:25 AM
TBra
Quoted: 5 Post(s)
Hi all,
When servicing the BB90 bottom bracket on my 2014 Trek Madone (approx. 4000km ridden) I noticed that the bearings on both sides are able to be removed and inserted by hand. They seem to sit fairly snug in the frame, so I didn't use a press to reinstall them and there's no movement or creaking whatsoever.
I've read numerous explanations online e.g:
- "The BB90 is 'slip-fit' and doesn't require a press"
- "Use Loctite 609 on the outer race to keep it in place"
- "The carbon has worn away so use Trek's oversized bearings and press them in"
However I can't find a definitive answer. I'm assuming everything is fine because there's no creaking, but any information to give me peace of mind is much appreciated.
Thanks!
TBra is offline
Old 08-31-20, 06:14 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Never Fix A Running Piece
dsbrantjr is offline
Old 08-31-20, 06:25 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,378 Times in 2,730 Posts
I can't answer your question but I can direct you to this as a cautionary/what not to do tale. https://www.bikeforums.net/road-cycl...mance-non.html
shelbyfv is online now
Old 08-31-20, 09:14 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Ex Trek employee here. The bearings should need a press to be installed. If you can remove/install them by hand the frame has worn. You need to first try the V2 OS bearings. They are .1mm larger in diameter than the stock 37.0mm bearings. If those are not snug Trek has supplied a kit to it's dealers...well, at least the company owned stores have them...that can be used to machine out a little more carbon which is then replaced w/ a glued in carbon ring that brings the bearing interface back to the correct size. Only use grease when installing the bearings. This has happened on thousands of frames and has been repaired thousands of times at Trek in WI. It's an easy fix for a truly annoying problem...which is why Trek is slowly going back to threaded bottom brackets.
cxwrench is offline
Likes For cxwrench:
Old 08-31-20, 12:43 PM
Buzzkill53120
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 47 Post(s)
Liked 74 Times in 33 Posts
You had to send him down that rabbit hole!
Buzzkill53120 is offline
Likes For Buzzkill53120:
Old 08-31-20, 01:09 PM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 532 Post(s)
Liked 312 Times in 236 Posts
That's neat, used to work at an (independent but fairly high volume) Trek shop. Didn't know they had anyone else do bb repair. Was always a bummer when we had to send off a frame. Most bikes needing it benefited from a teardown and overhaul at the same time, but certainly not all.
cpach is offline
Old 08-31-20, 04:37 PM
TBra
Quoted: 5 Post(s)
Cheers for the info! Just wondering what the risk would be of keeping things as-is for now, given there's no play or creaking?
TBra is offline
Old 08-31-20, 05:47 PM
cpach
Quoted: 532 Post(s)
It's more likely to accelerate wear of the bore. It's a good idea to order the oversized v2 bearings, it is likely to prolong the life of your bb shell.
cpach is offline
Old 08-31-20, 09:38 PM
cxwrench
cxwrench's Avatar
Bikes: lots
^This^
cxwrench is offline
Old 07-30-21, 10:33 PM
N2deep
N2deep's Avatar
Quoted: 77 Post(s)
Liked 88 Times in 57 Posts
cxwrench THANKS!!
N2deep is offline
Old 08-16-21, 03:09 PM
afm199
Bikes: Trek Madone, 2012, Trek Kronos CX Ultimate, 2012
Quoted: 31 Post(s)
Liked 47 Times in 33 Posts
There are two loctite products for slip fit bearings, one for loose and one for snug. Buy and use.
afm199 is offline
Likes For afm199:
Old 08-16-21, 04:08 PM
N2deep
N2deep's Avatar
Quoted: 77 Post(s)
I trust the knowledge shared by Mr.CXWrench, so I used grease and so far so good. Thanks for your input.
N2deep is offline
Old 08-16-21, 04:09 PM
N2deep
N2deep's Avatar
Quoted: 77 Post(s)
I trust the knowledge shared by Mr.CXWrench, the pockets were tight so I used grease and so far so good. Thanks for your input.
N2deep is offline
Old 08-16-21, 04:34 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Not in Trek BB90 frames.
cxwrench is offline
Old 08-16-21, 07:05 PM
afm199
Quoted: 31 Post(s)
You can say that again!
I don't use the loctite if the TREK bearings fit tight. I use it if they don't.
afm199 is offline
Old 08-16-21, 10:05 PM
cxwrench
cxwrench's Avatar
Bikes: lots
If the standard bearings don't fit tight you need the V2 oversized bearing...not Loctite.
cxwrench is offline
Old 08-16-21, 11:45 PM
afm199
Quoted: 31 Post(s)
The problem with one size fits all solutions is just that.
afm199 is offline
Old 08-17-21, 09:28 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Exactly.
cxwrench is offline
Likes For cxwrench:
Old 08-17-21, 05:54 PM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
what about the trek frames is different such that loctite shouldn't be used? Plenty of other carbon shells can be used with loctite without issue
redlude97 is offline
Old 08-17-21, 07:35 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Because my experience tells me that is what works. I don't exactly trust the Trek engineers that recommend grease because they came up w/ the stupid idea in the first place, but I do trust my rather extensive experience w/ these frames.
cxwrench is offline
Old 08-17-21, 08:26 PM
oldbobcat
oldbobcat's Avatar
Quoted: 513 Post(s)
Liked 444 Times in 334 Posts
I was replacing these before Trek supplied the carbon ring. The first line of repair, always, was the oversize bearing. If the customer managed to booger his frame with those, we'd put in another set of oversize bearings and hold them in place with Loctite 640. After that I never had one work loose, but I also had the good fortune to never have to pop a worn one out for replacement. I retired, and then the shop shut down.
oldbobcat is offline
Old 09-23-22, 02:56 PM
Sasquatch16
Quoted: 17 Post(s)
Liked 6 Times in 5 Posts
I had a non drive side bearing fail on a 2017 Trek Domane. Drive side bearing still spins smooth. Should I leave well enough alone and leave this bearing in place?
Sasquatch16 is offline
Old 09-23-22, 03:47 PM
cxwrench
cxwrench's Avatar
Bikes: lots
If it's still tight in the frame, sure...leave it alone.
cxwrench is offline
Old 09-23-22, 04:16 PM
Sasquatch16
Quoted: 17 Post(s)
Still tight and runs smooth. For when I have to change in future how would I get this bearing out? There was a space behind non drive side so I could tap bearing out with drift. On the drive side the bearing is right up against a plastic sleeve of same diameter leaving no lip.
Old 09-23-22, 05:39 PM
cxwrench
cxwrench's Avatar
Bikes: lots
The plastic sleeve is 2 piece and overlaps in the middle. Should be the same on both sides. Ideally you pull the bearing out with a tool that's made for that job. I used to use the Enduro press/remover tool. I have hammered them out with a drift, just be careful not to damage the carbon.
cxwrench is offline
