Thin-wall socket for adjusting pedal bearings?
Quoted: 100 Post(s)
Liked 57 Times
Hi. I just got a new pair of Sunlite city pedals; as on most new pedals in my experience, the bearings are set way too tight. The problem is, on these pedals the circular hole in the pedal body around the adjustment nut is too narrow for any of my 10mm sockets to fit inside. Can anybody recommend a thin-wall socket that works for this purpose? (Yes, I know I could just grind down the wall of another socket, but that sounds like a pain -- I'd rather just buy one that will work.) Thanks!
Quoted: 6177 Post(s)
Liked 4,794 Times
Are you certain it is not just the excess grease hasn't been pushed out of the way from use?
I usually find thin wall sockets at my auto parts store or other tool store.
On the pedals I use, the spindle along with the bearings comes out of the pedal completely. Then you adjust the bearings with what ever you have that fits. In fact, mine have a lock nut to tighten against the nut/bearing cone, so you'll be SOL if that is the case with yours.
Likes For Iride01:
I don't know what things look like inside that particular pedal, but for some of their pedals, Shimano has specialty tools - e.g., TL-PD33, TL-PD63 - to be able to engage the cone and the lock nut independently and simultaneously. It involves one socket that can fit through the clear bore of another socket.
Likes For John Valuk:
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,364 Times
...this doesn't sound like any of the adjustable pedal bearings I've worked on. Maybe post a photo of what you have in front of you.
Most of the pedal being assemblies I work on here have a 15mm cone ( the Campy crank bolt wrench works for this one). Then there's either a 10mm or 12 mm lock nut and a washer that holds that in position on the threaded nd of the pedal shaft. (Any properly sized socket for that locking nut works.) You need to be able to hold the adjustable cone in place, and still be able to tighten down the lock nut.
Quoted: 513 Post(s)
Liked 445 Times
I understand your need, having overhauled pedals by Lyotard and Campagnolo. It's tight in there. So I will make a suggestion instead of criticizing your request. Have you tried entering "thin wall socket set" in your browser search window?
https://www.mcmaster.com/thin-wall-sockets/
I've heard Snap-On and SKS sockets are thinner than Craftsman, and Harbor Freight advertises thin-wall sets.
Likes For oldbobcat:
Quoted: 1104 Post(s)
Liked 1,824 Times
Snap On non impact sockets are thinner than other brands. I have a chest full them and they're all I use. That said, they weren't purchased for bicycle repair work.
That said, you might be able to buy another set of pedals for what the Snap It Off In Ya man wants for a single socket.
Quoted: 980 Post(s)
Liked 580 Times
I've also heard them called "deep-well" sockets. I have a set of these ("Husky" brand, probably imported) that have served me well for many years.
Most of the pedal servicing i've done has been on MKS pedals on my folding bike. Once the plastic () end cap is removed, a 10mm socket reaches the locknut (this doesn't have to be deep-well), and a 12mm (or maybe 13mm... it's been a while) reaches far enough in to engage the cone. There's a non-rotating washer between the cone and locknut, so it's not necessary to be able to hold the cone while tightening the locknut. If the adjustment winds up a little too tight, the cone can be backed out against the locknut. It's easy.
I have Shimano SPD pedals on a couple other bikes, and as Iride01 said (post #2) the bearing assemblies come out in one piece and don't have to be disassembled for lubrication. In the case that adjustment is needed, the deep-well sockets can be used in the same way.
When those wear out get these. Much easier to work on and if cared for last a life time. Amazon.com : MKS Sylvan Touring Pedal Double Sided : Bike Pedals : Sports & Outdoors
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I actually use a needle nose pliers to adjust the bearing pre-load before slipping on the dimpled washer and then the locknut. The dimpled washer keeps the preloaded nut from turning while you tighten the locking nut. On my pedals I've been able to get a craftsman deepwell socket in to tighten the locking nut. I also find that if I put too much torque on the locking nut it adds more preload to the bearings, which is frustrating. Good luck BTW=lots of cheap Chinese sockets are really thin walled.
Likes For Bigbus:
Quoted: 980 Post(s)
Liked 580 Times
I wish I could... those have a nice, easily removed end cap. The AR-2 EZ pedals that I am limited to (folding bike; pedal comes off twice a day) have plastic caps that *look* like they ought to unscrew... but they don't. I have looked for a tool that would somehow grip the 4 holes on these caps, but to no avail. They can be pried out with a small screwdriver, but they eventually break and have to be replaced. Replacements are available, luckily. I have about 15,000 miles on one pair, but they've required a lot of service because the in-board (crank-side) seals are poor. Otherwise, they are excellent pedals. I've found that a good front mud flap goes a long way toward extending the pedals' life.
Quoted: 100 Post(s)
Liked 57 Times
Quoted: 100 Post(s)
Liked 57 Times
Quoted: 980 Post(s)
Liked 580 Times
At any rate, having a deep-well socket that will reach the cone allows loosening up the bearing by turning the cone counter-clock-wise, effectively tightening the assembly. There is much less fiddling to get the proper tightness.
Likes For sweeks:
Quoted: 100 Post(s)
Liked 57 Times
FYI: I bought a thin-walled 10mm socket. It's too big to fit in the hole on the Sunlite pedals. I took it to my LBS -- they couldn't figure out how to adjust the locknut either. And then, the tight bearings caused the left pedal to back its way out of the crank while my wife was riding the bike; on its way out, it stripped the threads of the pedal hole. My LBS was able to chase the threads, but I gotta say that these are the worst pedals ever. Don't buy them. It's too bad, because they look really nice on a modern city bike (a Priority Continuum). I've had much better luck with XLC pedals in the past and now have ordered the PD-C09 to replace them.
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
Cheap deep socket and a bench grinder to make it whatever OD you need - Done.
Likes For dedhed:
Quoted: 800 Post(s)
Liked 2,962 Times
have adjusted many of these XLC bearings.are tight as well but the bearings are easily assailable with a common 10mm socket.good brand IMO for the $$$.
Campy Fan
Bikes: COLNAGO V1-r Disc, FOCUS CAYO Disc, BH Ultralight RC, Ramiko Disc, TILON Custom Ti, Cannondale OCLV 5500, CIÖCC SL, Fiorelli, KTM AERA PRO, TST Ti, Cannondale M400, HARO Impulse, Miyata XXX, XCAD Track, TREK 400, SEARS Spaceliner, Schwinn Pea Picker
9mm 11mm Pedal Tool
I will post on a tool that I have for adjusting the 11mm cone nut and 9mm lock nut for pedals. Since I am new to the forum I have to wait to post pics and I think it’s necessary to see them to get all of the details.
Quoted: 2479 Post(s)
Liked 2,947 Times
I dimly remember from my bike shop mechanic days wedging the wide blade of a big flat-blade screwdriver against one face of a pedal's adjustable cone to keep it from turning while I was tightening the lock nut.
Likes For Trakhak:
Likes For boozergut:
Campy Fan
Boozergut
Maybe the same concept but turned and bored on the lathe with a welded handle, nice little tool.
Likes For JohnnyRAD:
Campy Fan
Trakhak
I have used the screwdriver method, but never completely trusted that the nuts were tight. The tool I have makes the adjustment more precise and secures the lock nut.
Quoted: 1943 Post(s)
Liked 2,164 Times
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Just having dealt with a keyed washer that wasn't fulfilling it's function on a set of Miche Primato pedals, I am wondering if there's a solution that doesn't involve going through Shimano for tools. These pedals used the 15mm adjustable cone with a 12mm locknut, so Shimano doesn't produce a tool set that would accommodate these anyway. I prevailed when I found a cheapo spanner meant for a recessed lock ring (not related to bike work) that managed to fit into the bearing enough to hold the cone while I used another cheap 12mm spanner over it to finish tightening the lock nut.
I understand that a generic set of tools would be too costly to develop for the expected volume without the set costing more than any of us are likely to pay, but a tool to make the job easy and repeatable is a satisfying experience.
The dropped
Liked 1,014 Times
I had a similar thought, just a graduated set of sockets with 'peanut butter tool' style handles on them that can fit inside the socket 2mm larger to cover 7- 15 mm. Make the 7mm socket the tallest, and the 15mm socket the shortest and Bob's your uncle. Maybe instead of PB wrench style, just use the same stamped steel they use for cone wrenches and put a ring matching the bore on one end instead, then weld that to the socket to spread the torque out.
