Addiction 2022.2
#9976
he said member
Bikes: yes please
Quoted: 2788 Post(s)
Liked 1,950 Times
Cycling related question: Recall I set up my Ultegra R8000 groupset a few months ago and have been quite pleased. I was even bragging that I did not need a chain catcher because it "never" drops a chain.
Now, with a few months a a couple thousand miles on the groupset, the evil eye must have gotten to me because the past two rides I have dropped the chain, a total of only 3 drops but each one is a nuisance. It's dropping when going from big to little chainring, sometimes it drops outright, sometimes the crankset seems to "lock" due to chain wraparound (if that's the right term) as part of the process.
Any suggestions on whether its a tweak adjustment in the chain tension? I know I set up the limit screws etc. perfectly so I had thought that was a once-in-a-lifetime setup but I am unsure what to do to fix this.
Ideas??
Ideas??
#9977
Quoted: 10234 Post(s)
Liked 5,177 Times
Looking at my footage from todays ride, I’ve reached the conclusion, I suck at filming.
Also, none of my footage grasped what I was trying to show.
Sigh, Velo made it look so easy. I also didn’t see how to use the slow motion function.
#9978
Quoted: 8259 Post(s)
Liked 8,980 Times
#9979
he said member
Bikes: yes please
Liked 1,950 Times
#9980
Quoted: 9648 Post(s)
Liked 6,363 Times
Likes For Mojo31:
#9981
Liked 8,980 Times
Likes For big john:
#9982
Quoted: 18397 Post(s)
Liked 15,485 Times
Facebook memory photo. Proofreading is fundamental.
#9983
he said member
Bikes: yes please
Liked 1,950 Times
So my 16 Tarmac is finally noise free. No more random tick, tick tick sounds. Turns out it was the seat post/internal (infernal) clamp. Last Thursday I had a little time before the ride so I pulled it apart to service it in a desperate attempt to make it stop. However. When the seat post came out the clamp went in...as in ,into the seat tube. Then when I flipped it upside down only half came out. The wedge portion went up the seat tube into the head tube. And while manipulating the bike it finally came to rest in the top tube. No matter what I did it went the wrong way. Then it got stuck in the top tube. I shook it and bounced it. Finally after about 10 minutes it came free and I hot it back into the head tube. But it wouldn't drop into the down tube. SO I had to pull the stem and drop the fork. Plop, there it is. I'm completely sweated through my kit by this time and getting grease everywhere from my over serviced headset. I fought with the post clamp for a half hour. Then it hit me. Lay the bike on its side. Insert the wedge and bolt parts , slide the post in. Stand it up and finish. Worked the first time. No more noise.
#9984
he said member
Bikes: yes please
Liked 1,950 Times
So my 16 Tarmac is finally noise free. No more random tick, tick tick sounds. Turns out it was the seat post/internal (infernal) clamp. Last Thursday I had a little time before the ride so I pulled it apart to service it in a desperate attempt to make it stop. However. When the seat post came out the clamp went in...as in ,into the seat tube. Then when I flipped it upside down only half came out. The wedge portion went up the seat tube into the head tube. And while manipulating the bike it finally came to rest in the top tube. No matter what I did it went the wrong way. Then it got stuck in the top tube. I shook it and bounced it. Finally after about 10 minutes it came free and I got it back into the head tube. But it wouldn't drop into the down tube. SO I had to pull the stem and drop the fork. Plop, there it is. I'm completely sweated through my kit by this time and getting grease everywhere from my over serviced headset. I fought with the post clamp for a half hour. Then it hit me. Lay the bike on its side. Insert the wedge and bolt parts , slide the post in. Stand it up and finish. Worked the first time. No more noise.
But, I almost missed my ride by the time I got it back together. Now that the weight of this bike is lower, I like it a lot more than I used to.
And the Spyre brakes are proving to be a hit. I like them, they work well. They don't rub, unlike the hydro units. I think they would be better with compressionless outer cable housings but for now I'm satisfied with them
Likes For ls01:
#9985
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,849 Times
#9986
Liked 8,980 Times
#9987
Liked 8,980 Times
#9988
Liked 11,849 Times
This reminds me of Roy Blount Jr., a Southern writer who took issue with Al Capp's "Li'l Abner" and the use of "Yo" in place of "You", when everyone knows "Yo" is a contraction of "Your".
Likes For genejockey:
#9989
Liked 15,485 Times
Do you remember NBA great Moses Malone? At the end of the '82-'83 regular season, after the Sixers had won 65 games (They had a chance to win what would have been a record-setting 70 regular season games, but Doc got injured late so they rested him.), a reporter asked him how he thought the playoffs would go. Moses responded "Fo', fo' fo'." (Back then, the playoffs consisted of three seven-game series.) The Sixers swept the Nets in four. They then won the first two against the Bucks but lost game three. Moses was again asked what he thought would happen. He responded "Fo', five fo'." The Sixers went on to defeat the Bucks in five and then sweep the Lakers in four.
Likes For indyfabz:
#9990
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,645 Times
What a bargain. Too bad there's not much scenery in Tulsa.
https://www.zillow.com/homedetails/4...zillowgonewild
#9991
Liked 6,363 Times
Plus, the finish out is really cheap looking.
#9992
Bikes: everywhere
Liked 7,645 Times
Ooh, eBikes making the scene at the German Film Awards!!!
#9993
Bikes: everywhere
Liked 7,645 Times
Yeah, whoever chose that front door and sidelights should be banned from Home Depot.
#9994
Liked 11,849 Times
#9995
Liked 6,363 Times
Elevators are costly to maintain and keep running. My future in-laws have one, and I'd hate to be dependent on it to get into or out of my living space.
I can walk around my house now in a clothing optional manner if I want.
As for decor, how about the water heater and laundry machines in the bathroom? And the cheap suspended ceilings? That's some luxury living. Nah.
That black mold is going to be expensive to eradicate! If you don't die first.
#9996
Quoted: 1390 Post(s)
Liked 1,848 Times
I have a late 60's or early 70's Stingray - I ride it often around our house (driveway, private road)
it's a blast to ride - big difference compared to contemporary bike ...
but gotta be careful if you get the (bad) idea to pop a 'wheelie' - anything more than a slight lean back and the front tire will be pointing at the sky
#9997
Liked 11,849 Times
Would not want to be living on the top of a golf tee in tornado alley!
#9998
Liked 6,363 Times
Peeing in the pool is actually bad for you: Peeing in the Pool Isn’t Just Gross—It’s Actually Bad for You (msn.com)
Good to know.
Good to know.
#9999
Liked 6,363 Times
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
