Need GPS unit advice
Quoted: 1743 Post(s)
Liked 1,279 Times
I've been using Garmin units for 6-10 yrs. The first was an Edge 200 and a couple years ago an Edge 130 Plus. I typically use the Edge 130 and keep the Edge 200 as a backup. I like the simplicity and don't need a lot of the enhanced functions of some units. But, recently both units are giving me bad elevation data. I spoke with a Garmin rep about the 130 and reset it. It had been giving me very high readings. After the fix it worked perfectly for a few rides. Yesterday I did a 1300 ft. ride and it gave me 400 ft. The backup 200 read 800 ft. So, I'm looking for a unit that is fairly basic. Any suggestions or ideas about what I should consider?
Quoted: 3221 Post(s)
Liked 2,043 Times
I cannot suggest anything or any manufacturer for reliable elevation. You would want a unit that has a barometric sensor as that supplements the GPS elevation, but really I'd say the elevation issues is the most common complaint about all the units and is a problem in general as GPS just cannot accurately measure elevation, its the very nature of how the signals get received from the satellites. Then you deal with how the assorted tracking apps deal with the data sent from the device and what they think they know in their database. And it varies wildly.
Liked 1,279 Times
Quoted: 18883 Post(s)
Liked 10,646 Times
I would want to know what happened to make the units suddenly act this way?
Are you able to calibrate the barometer in the 130+? Or check the calibration?
If you want to fix the problem with money, the barometers in Fenix watches are spectacular. Typical for me is about 3 feet error per thousand feet of gain. But all barometers drift and are vulnerable to atmospheric effects.
Likes For Seattle Forrest:
The accuracy of the elevation data in the maps can vary from brand to brand. I thought I'd heard the Karoo2 elevation data (at least the grade %) can be off quite a bit. The Wahoo and Garmin units do a bit better I think. Most of these units also have a "climbing" function which shows metrics for a climb like which part you are on, the gradient, upcoming gradient, elevation covered, elevation remaining, etc.
Good luck.
Likes For maartendc:
Sr Member on Sr bikes
Dan
Liked 2,043 Times
Understanding the Accuracy of the GPS Elevation Reading | Garmin Customer Support
Liked 10,646 Times
GPS elevation is less accurate than GPS lat/lon for mathematical reasons. There's really no way around that. Barometric altitude is much better as long as the barometer is calibrated properly. Many bike computers automatically calibrate their barometers from GPS at the start of a ride, some do it continuously to addresses barometer drift.
Modern GPS units do a pretty good job with GPS altitude. It's rare in my experience for it to be off by more than 50 feet with a good lock.
climber has-been
Quoted: 3405 Post(s)
Liked 3,535 Times
It's a geometry problem none of the satellites below the horizon are visible.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Just use "Elevation Correction" in Garmin Connect until they stop messing with the GPS positions to confuse the Russians.
I use a Lezyne Mega XL. From what I have read about them, they use a barometer (GPS - Elevation Data Lezyne Customer Service and Warranty Support). I am at an elevation of 301 feet at home and I have my GPS unit consistently read between 297 and 303 ft.
Quoted: 9648 Post(s)
Liked 6,363 Times
I think if you go with a unit that has built in maps, it should accurately give you elevation data based on the map data. Units like the Wahoo Elemnt Roam or Bolt V2, or the Garmin Edge 530/830/1030. Or even the Hammerhead Karoo2. I think these all have built-in maps with elevation data in them. (double check each unit just to make sure).
Good luck.
Good luck.
Liked 10,646 Times
My Garmin said 1,984 feet of elevation gain yesterday (over 2.75 miles!) but the topographic map and route database both say 2,000 exactly. That's a total disagreement of 16 feet, or less than 1% difference from the best source available.
Quoted: 4242 Post(s)
Liked 1,343 Times
Strava used actual rider data (most of which is probably based on barometers).
Liked 1,343 Times
Garmin provides this for devices that don't have barometers (or have broken ones). This suggests that Garmin sees barometric data as better than map data.
