Understanding cog ratios
Quoted: 21 Post(s)
Liked 9 Times
Hi guys,
I currently have a setup with a 42T front chainring and a 14T rear sprocket. I really like the resistance this gives me for riding around my area, however, I am wondering this:
If I switch to an 11T rear sprocket and 33T front chainring, this will give me the exact same ratio but will it give me the exqact same pedalling experience on the bike?
What would I be losing by making this change? Surely there has to be something?
Quoted: 1819 Post(s)
Liked 1,693 Times
11 tooth cogs wear out much faster than 14 tooth cogs
They also are not as smooth https://chain-guide.com/basics/2-2-1-chordal-action.html
Likes For alcjphil:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 297 Post(s)
Liked 675 Times
I've found Gear Calculator good for comparing cogs:
https://www.gear-calculator.com/?GR=...N=MPH&DV=speed
The 'Compare' button at the bottom right lets you compare two setups directly.
Likes For Aardwolf:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Switching from a 42t to a 33t probably means switching to a triple crank - some people like them and some don't... but it'll be different.
Quoted: 2333 Post(s)
Liked 2,097 Times
A 54 x 18 is more macho, a 33 x 11 is a bit weenie aside from wearing out faster and adding more friction
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Post #2 answered your question perfectly. What more do you want to know?
Quoted: 4806 Post(s)
Liked 3,928 Times
Tell us what your bike is and what crankset you are using and we might be able to help you more. (Not being able to use bigger than 42 teeth? It's an unusual bike that won't allow bigger with a standard crankset if it as a regular road bike that takes 27" or 700c wheels. Most single speed and fix gear bikes and wheels are designed to use a chainline a set distance from the center of the seat tube. (42mm if I recall correctly.) That chainline virtually always allows as big a chainring you you can get.
Chainlines - they should be straight for SS and fix gear. You should be able to sight up the chain from the rear and see no "S" turn to it. If your bike is a conversion from a double or triple, it may well be that the small chainrings are inside that proper chainline and not aligned with the rear cog. (Knowing nothing of your bike or setup, this is all speculation. But Diablo Scott's comments may well be on the widths of various types of cranksets pressed into single speed duty.)
It's MY mountain
Liked 2,980 Times
33t requires a different BCD - like the kind that triples come with.
You almost certainly cannot swap the 34 you have now with a 33... you might be able to find a whole new "sub-compact" double crank that has a smaller ring.
So it's just an availability issue.
Hi guys,
Liked 1,693 Times
Maybe we should all recall this thread: https://www.bikeforums.net/singlespe...-possible.html
Likes For alcjphil:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
^^^This.
OP is in a "throw parts at it and see what sticks" phase of his project
