Are there 10-11 inch quick release skewers?
I bought a frame and wheels a while back off marketplace. Finally got around to trying to put a bike together, however, the back part for the frame is a thru axle type and the wheel hubs are QR.
The quick release are too short to make it through. Are there longer QR skewers? Or do I need to get a new wheel/hub for the back?
Thanks 😀
Thanks 😀
Clark W. Griswold
Quoted: 4331 Post(s)
Liked 3,955 Times
Thru axle wheels and QR wheels are very much different and have different spacing. Get the correct wheels but you might want to consider checking out your local bike shop as they can help you get the correct parts and measure things.
Likes For veganbikes:
Quoted: 2026 Post(s)
Liked 1,095 Times
Even if you could find a longer skewer, a qr hub has an axle too small (typically 10mm diameter) to locate properly in a thru-axle hole (usually 12mm). You need the correct hub and thru-axle.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
If you didn't know the difference between q/r axles and thru axles BEFORE you went ahead and bought the frame you should probably find some help putting it together from someone with experience. Lots of experience.
I have the 12x148 thru axle. I'll get a new wheel then. This is my 1st bike build. I have a newfound respect for the techs at my local shop 😄
I'll have to find a 12*148 hub or wheel I guess. Thanks again!
Likes For Khandor:
Quoted: 453 Post(s)
Liked 104 Times
Surprised the frame didn't come with an axle, as this is now part normally of the basic frame package when purchased, not the wheel
Also, if your building a current bike, effectively everything is in metric now (and has been for a while), searching for a 10-11 inch QR will bring few if any useful results
Likes For jimc101:
Looking only at the front wheel. Assume 12mm thru-axle holes in the dropouts.
Will the following work?
The hollow QR axle has a diameter of 9mm.
Find a nut, 12mm od, 9mm id, threaded on the outside (appropriate thread) and smooth on the inside. Width of the nut is the dropout thickness.
With this nut threaded into the thru-axle holes, will the QR wheel fit with the standard QR skewer?
Likes For anga:
Liked 1,095 Times
Ironically, Problem Solvers makes an adapter to do just the opposite of what you want. They sell a 12mm front thru-axle with the ends reduced to fit standard 9mm fork dropouts so you can use a thru-axle hub in a conventional fork.
Likes For HillRider:
You are describing reducer bushings (M12x1.0 or 1.5 OD by 9mm ID) and these would have to be custom made by a machine shop as I don't think anyone makes them commercially. The cost could be quite high and probably it would be cheaper to get the correct hub.
Or, google throws up a bunch of M12 reducer bushings.
Liked 1,095 Times
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
A constructive comment would point out that the wall thickness is 1.5mm not 3mm and cannot accommodate 1.5 to 1.75mm thread pitch; would work for 15mm thru-axles; can be modified by using a 1.5mm shim in the non-threaded hole and probably use something like solder to preserve the threads in the threaded hole and a thin shim(beer can thickness) to protect solder.
There are other solutions but wasted on dumb people like you.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
You seem to find it hard to differentiate between an idea, its final form, and implementation.
Quoted: 3489 Post(s)
Liked 2,909 Times
Likes For smd4:
All good. Now just waiting for the new wheel so I can finish this build. Thanks for your input. 😀
