Immersive waxing / it should be more popular
#476
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I've never heard of wiping the chain when pulling it out, when the wax is sufficiently hot (90C+) it would only leave a sliver of coating anyway. It sounds like it could perhaps be a worthwhile extra step for indoor use to minimise flakes, but I don't think it is worth the hassle for outdoor riding.
Interesting with the magnet, do you think these are mainly chainring shavings that get flushed out? I'll give that a go as I think the molybdenum in the MSW is not going to stick to the magnet, so that could be a great periodic step to remove shavings from the wax!
you need a fairly strong magnet
#477
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
I always thought that the fine black powder was road debris and factory grease residue.
Likes For SoSmellyAir:
#478
Liked 1,463 Times
#479
Quoted: 345 Post(s)
Liked 237 Times
I actually do it there as well but only after the initial mineral spirit soak as I don’t recycle that batch ( it stays cloudy from the packing grease)
#480
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
Given the lifetime of a chain I think it's worth going to the effort of a few spirit shake ups and final alcohol rinse to get any residue off.
It's going to be a long time before I have to go down that path again but this is the method I would use next time:
- 10-20 minutes initial soak in mineral turps (aka white spirits in the US), then shake and pour out
- Then add new mineral turps and shake it up in a sealed container, for as many times as needed to make it run perfectly clear
- Flush it with boiling water to get most of the solvents off
- Final isopropyl alcohol shake up and then hang to evaporate completely (or finish it with a hair dryer, if impatient)
There's no mistaking the bone dry feeling after the alcohol flies away.
There was this one time when I asked a bike shop to fully strip a new chain and despite the ultrasonic and soaking it in degreaser (granted, bio degreaser, probably not the strongest stuff) it was still tacky to the touch on the outside, so when I shook it up in solvents at home it still got all cloudy. Better to be thorough and have it absolutely stripped so the wax can adhere and work to its full effect.
https://www.bikeforums.net/general-c...ng-chains.html
personally i see o reason to pour out the chemicals, they can be used over and over until they just don;t work any more. i also know i can decant or filter out the jars but why, then i have that crap to clean up. my own way is pretty darn clean and quick. i'll share if anyone cares to know.
#481
I used a magnet and laces to sweep around in 6 week old MSW (supported approx. 1500km of riding across 3 chains) and the first sweep showed these metal shavings on both sides.
Good to see this stuff flushed out of the chain and it seems like a worthwhile step to periodically decontaminate the wax to make a batch run cleaner for longer.
Likes For yaw:
#482
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Is there a lucrative business opportunity here, selling bike scented candles to 41ers?
#483
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
I usually just warm the hardened pot of wax enough to plop the wax out and with a serrated knife cut off the bottom 1/2" then add more candles as needed. I figure the heavy stuff like grit and metal all sinks to the bottom before the wax hardens. A magnet won't gather the grit.
#484
So when using these it is best to ensure the chain that goes in is as free as possible of superficial grit (microfibre cloth or cloth plus a few sprays of iso to wipe the chain externally before immersing it). Even so not much comes off riding in mostly dry conditions. To extend the life of the wax one could still shave off the bottom at some stage but I prefer to have all the friction goodies and will rather start over with fresh wax at that point. Pulling out the metal shavings is probably as far as I will go.
If I was just using some straight wax base then I would put a shallow steam tray in the pot to keep the chain off the bottom and with no need to stir up the wax you'd be immersing in the clean upper layer.
How do candles work for you? Have you ever compared it to other bases or specific chain wax? I keep hearing that candles are the worst option, but I am sure there's significant differences in mineral oil content there and some could work better than others.
#485
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
Commercial blends like MSW and Silca have a bunch of low friction additives that you would lose as these also settle at the bottom.
Likes For SpedFast:
#486
Opinions after running a season with five bikes using Molten Speed immersion wax. Context: I use KMC chains with YBN quick links. I used primarily RNR Gold previously.
Good:
Waxed drivetrains stay spotless and never need degreasing again.
The waxing process is far easier than people think. I degreased new chains in (cleaned out and fully degreased) old peanut butter jars using a few washes in odorless mineral spirits and isopropyl alcohol, that's easy and fast. After that, taking off the chain and rewaxing it is no harder than having to clean and relube a wet lube chain. It's also kind of a fun process and gives you a chance to service your bike with the chain off which makes several tasks a bit easier.
Bad:
Rust. I've found that waxing is terrible at preventing corrosion. I ride hard and sweat a lot. I also occasionally ride in damp, drizzly conditions. I am a fastidious maintainer of my bikes, and try to get all of the sweat off my bikes and drivetrains after every ride. Still, every single waxed chain I've used has rusted fairly quickly. I have been using KMC chains for many years and have never had an issue with chains rusting before when using traditional lubes. Frankly, this is a deal killer on the road.
Frequent rewaxing is necessary. In my experience, chains start to get loud after only 175-200 miles. I have weeks where I ride 250 miles so this is a little annoying. Using drip-on wax emulsion lubes like UFO or Silca Super Secret is an easy and effective way to extend this time.
Verdict:
I like waxing on my gravel bikes and mountain bikes as I ride a lot in very dusty conditions that cause a lot of wear to the drivetrains with wet lubes. I guess I need to find a new chain that's less prone to rust for those uses. I'm less sold on waxing for road use and I've gone back to using modern wet lubes like Silca Synergetic on my road bikes. That stuff is utterly fantastic.
Good:
Bad:
Verdict:
#487
Quoted: 3241 Post(s)
Liked 2,512 Times
Good:
Bad:
Verdict:
Good:
Bad:
Verdict:
#488
Yeah no way around this, if you get the chains wet then a boiling water flush and immediate re-wax is the way, or coating it in drip on wax if you need to store it until you can get to it, and then do the boiling water flush before the next wax dip. I now have 5 chains rotating on 2 bikes so it works for me that way, though I stay out of the wet mostly.
#489
Liked 1,463 Times
#491
Quoted: 1975 Post(s)
Liked 232 Times
OMS leaves a minor oil residue that some claim will inhibit wax retention, I haven't found any difference, but the recommendation is boiling water or denatured alcohol/rubbing alcohol as a last rinse prior to waxing. You don;t have to dry you can just drop directly in the warm wax and it will boil off
#492
Liked 1,463 Times
Theoretically, any residual OMS should also dissolve into (and slightly dilute) the molten paraffin.
#494
When taking a dry chain off, I just wipe it with a microfibre and chuck it in the wax pot, but since a wet chain attracts all sorts of road spray, it's good practice to just rinse it with boiled water first to take all the superficial contamination off, and then dry it or chuck it into the pot directly. Just to keep the wax pot cleaner.
If it's already rusted then solvents and a stiff brush are probably required, but I've never gotten to that point. I would certainly do what I can to avoid having to use solvents beyond first time prep.
#495
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 158 Post(s)
Liked 138 Times
#496
Just Pedaling
Bikes: YEP!
Quoted: 328 Post(s)
Liked 516 Times
I've never understood the reason to pour boiling water on the chain and then immediately put it in the wax bath. It seems to me there's a good chance of water wicking between the plates and into the pins. Since wax is hydrophobic I would think it would not flush any trapped water and the water would keep the wax from flowing into the exact places you want it. Just a though, no testing on my part.
#497
Liked 1,463 Times
#498
Liked 232 Times
#499
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
#500
Quoted: 3942 Post(s)
Liked 7,283 Times
The longer this thread goes, the more apparent it becomes why chain waxing isn't more popular.
Likes For tomato coupe:
