Ultegra BR-8070 caliper
Old 09-19-22, 03:44 PM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
Liked 910 Times in 487 Posts
Differences between front and rear Ultegra BR-8070 caliper
So I am finding the Ultegra BR-8070 disc caliper as being front and rear specific at several online retailer websites. I did a quick search on Shimano and I can’t find any references to them being different. Does anybody know if they are different or is it something ancillary like an included mount or adapter? The pads retaining screw on both of mine are seized with stripped heads.
Ghazmh is offline
Old 09-19-22, 04:07 PM
Iride01
Iride01's Avatar
Quoted: 6178 Post(s)
Liked 4,795 Times in 3,307 Posts
I think it's pretty much the mounting plates and maybe a few other little things that screw into it so it fits properly on the chain stay as opposed to the fork. The body itself is the same. Or at least appears that way to me.
Are you finding a big price difference between them?
Iride01 is offline
Old 09-19-22, 04:44 PM
Barry2
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times in 687 Posts
captain obvious reporting for duty!
Did you remove the clip from the rear of the screw?
Sorry, Had to ask
Barry
Barry2 is offline
Old 09-19-22, 04:52 PM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
Sorry, Had to ask
Barry
Good question Barry. I did
Ghazmh is offline
Old 09-19-22, 04:53 PM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
No difference in price but it seems like Competitive Cyclist currently only has fronts in stock.
Ghazmh is offline
Old 09-19-22, 05:20 PM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
OK, after taking a closer look at Shimano website it seems as if the fork mount is shown attached to the caliper. Perhaps thats the only difference. Id have to pull mine off to confirm if the caliper is screwed to that adapter or permanently attached.
Ghazmh is offline
Old 09-19-22, 05:41 PM
surak
surak's Avatar
Quoted: 871 Post(s)
Liked 726 Times in 436 Posts
There's no way it can be permanently attached as both front and rear should be usable with either 160 or 140 rotors.
Edit to add: when I took my bike in for some work, my LBS said the pad retaining screw on my rear caliper was super tight, probably also seized. They replaced the screw for me so I didn't need a new caliper just to fix that issue.
surak is offline
Old 09-19-22, 08:12 PM
Barry2
LR÷P=HR
Quoted: 862 Post(s)
OK I give up watching you guys
Here you go... you can see the Front and Rear specific parts.
All the best
Barry
Barry2 is offline
Old 09-20-22, 02:20 AM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
That’s what I was thinking but not certain. I drilled out the rear screw about 6 months ago and just use a cotter pin but I think the front is leaking oil from around one of the pistons. When I went to remove the pads to look for oil residue that’s when I found the seized screw and the thought of replacing them both entered my mind.
Ghazmh is offline
Old 09-20-22, 02:23 AM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
All the best
Barry
Thank you, that seems to confirm what I was hoping. I can order two fronts and simply remove the fork mount.
Ghazmh is offline
Old 09-20-22, 08:09 AM
Iride01
Iride01's Avatar
Why don't you just buy the proper front and back units then you won't have to hope you can cobble together stuff from the old brakes that you say already are giving you issues.
It's okay to use different online vendors. You don't have to order from the one that doesn't have what you want.
This place has both....
https://www.universalcycles.com/shop...s.php?id=90895
and other places claim that they expect new stocks by the first week of October which isn't that far off considering how long you seem to have been living with this issue.
Iride01 is offline
Likes For Iride01:
Old 09-20-22, 01:43 PM
Ghazmh
Ghazmh's Avatar
Quoted: 696 Post(s)
True, I could just wait a few weeks.
Ghazmh is offline
