Clear chain stay protector
Old 09-20-22, 07:29 AM
TakingMyTime
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times in 540 Posts
I'd like to replace the stock clear plastic chain stay proctor that came on my bike with something that has a little more coverage. From what I understand "Helicopter" tape is the way to go. What is the process for removing the old protector from a carbon frame? Also, once the helicopter tape has been attached how easy is it to remove and refresh with a new piece?
TakingMyTime is offline
Old 09-20-22, 07:35 AM
oris
I like speed
oris's Avatar
Bikes: Cannondale SuperSix Hi Mod, Specialized Allez Sprint, Bottecchia Emme 4 SL
Quoted: 77 Post(s)
Liked 121 Times in 61 Posts
A heat gun/blow dryer and some Goo Gone is your friend.
I've personally used the 3M clear film from Amazon to wrap the chain stays. Spray the adhesive side with soapy water or alcohol to allow it to be positioned easier. Then use low heat on the heat gun/blow dryer to help it conform to the bends and curves. Otherwise replacing it is straight forward by peeling it off.
oris is offline
Old 09-20-22, 07:47 AM
TakingMyTime
Thanks! I had been watching a few videos and there seemed to be opinions on removing it from either matte or gloss finishes. I'll be ordering some soon.
Old 09-20-22, 07:51 AM
streetsurfer
Quoted: 96 Post(s)
Liked 292 Times in 155 Posts
If you have a rigid protector: Some use fine floss to “saw” back and forth under applied badges and the sort.
I’ve applied gorilla tape.
streetsurfer is offline
Old 09-20-22, 08:02 AM
Mojo31
Quoted: 9653 Post(s)
Liked 6,365 Times in 3,505 Posts
Just peel it off pulling the tape perpendicular to the chainstay.
I've taken it off cars, and it is not hard. If you get to a tough spot, the best thing to use is a steamer to soften things up.
If you use a heat gun be careful as you can burn off the paint pretty easily.
Mojo31 is offline
Old 09-20-22, 09:04 AM
msu2001la
msu2001la's Avatar
Quoted: 1461 Post(s)
Liked 1,485 Times in 870 Posts
I don't know how hot a heat gun gets, but I've read many stories of carbon wheels being damaged by hot car exhaust systems, when the racks place the wheels too close to the pipes. So, I'd proceed with caution here.
msu2001la is offline
