2007(?) Specialized Allez Elite
Bikes: 1987 Schwinn Mirada, 1989 Trek 420, 1995 GT Timberline, 1979 Schwinn Super Le Tour, Co-Op DRT 1.3
Quoted: 103 Post(s)
Liked 85 Times
Just acquired a very nice example of this and know nothing about it, other that it appears to my untrained eyes to possibly be some sort of triathalon bike. Not finding a lot of information online. Any good resources out there for older but not vintage Specialized road bikes?
Thanks in advance.
Thanks in advance.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2567 Post(s)
Liked 5,599 Times
Pictures would be helpful
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For Miradaman:
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Thanks in advance.
Thanks in advance.
There are no resources for a 15 year old Specialized road bike, but really no resources for any year's bike if I understand how you use the word 'resources'. What are you looking for though, in terms of resources? Like do you want to know about the components or how to maintain it? If so- neither of those is unique to the bike as they are questions that have universal answers- maintaining that bike is nearly identical to any other road bike from the early 90s thru late 10s.
Your bike is a 2005 model, to be clear.
Its a road bike- you can obviously use it for triathlons, but it is not a tri specific/designed bike.
Its an aluminum frame, carbon fork, and has a 3x9 drivetrain.
https://bikeindex.org/bikes/3670
Quoted: 103 Post(s)
Liked 85 Times
Sunshine
Liked 7,473 Times
The fork had Zertz inserts which were advertised as vibration damping, but really do nothing. The seat tube shape is more aero, for what that's worth.
Likes For mstateglfr:
Quoted: 103 Post(s)
Liked 85 Times
It's been 17 years, what's actually on the bike may be different from stock. That's easy enough to determine though since it's in front of you.
Quoted: 103 Post(s)
Liked 85 Times
Sunshine
Liked 7,473 Times
Then suddenly, Zertz disappeared because Specialized moved on to other ways to claim compliance and vibration reduction. Based on internet comments, Zertz had long run its course as a marketing tool.
To be clear, there is no harm in having them. It's not like they slow you down.
OM boy
Bikes: a bunch
Quoted: 504 Post(s)
Liked 631 Times
The Dims were almost the same (by size) as the Tarmac models. Some small changes for adaptation to aluminum frame.
Geometry Geeks has the 2004 model of your bike in a 56cm size listed _ I expect it's pretty much identical.
Yours is obviously a bit bigger 58 or maybe even 60..
https://geometrygeeks.bike/bike/spec...t-triple-2004/
What you're seeing on the seat tube aero flare is trickle down from the earlier Top-O-Line models of the Sworks Tarmac.
Allez was not indented to be a Triath specific bike. But as noted by others; no reason it can't be used for Triath.
The bike, with good tires and components, wheels in good shape; is going to be a quick handling, excellent club racer.
Of course, the motor makes all the difference.
Ride On
Yuri
Likes For cyclezen:
Likes For Camilo:
Quoted: 103 Post(s)
Liked 85 Times
The Allez models were designed to be full on race bikes. Alu is sometimes preferred by some riders for short course races, such as Criteriums and circuit races.
Ride On
Yuri
Ride On
Yuri
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
The Allez Elite has generally been Specialized's entry level road bike generally it had decent enough components to give you a little performance gains but nothing exceptionally special. Not a bad bike through most years sometimes they dipped down to Tiagra instead of 105 but in the end a free bike is not a bad deal. Even if it sucked there is nothing real invested in it and you might could just get some money for a nice meal or alcohol or bike parts and the best is you get a nice bike out of it which it seems like you got.
I should clarify when I say entry level I do mean it, I don't just mean the bottom end as some people take it as (not calling anyone out at all). It is a bike that is a good place to start, decent enough to get you going and upgrade if desired but also reasonable enough to ride as is.
