I'm baaaack.
#52
I am potato.
Quoted: 1764 Post(s)
Liked 1,577 Times
It's unfortunate that tire sizes are printed that way - in this case 700X23C. Because the "C" refers to the rim size - 700C - not the tire size which is 23mm. The C attached to the tire size is really meaningless, and the tire size really is 700CX23. I have no idea why this is the conventional nomenclature on tires. A pet peeve of mine, but so ubiquitous nowadays (calling a tire size 23C, 25C, 28C,etc) that I just have to bite my tongue. We pedants will usually reply to such grievous errors by simply replacing 23C with 23mm rather than ***** about it.
But people know what you mean when you write 23C, meaning 23mm.
I don't expect to sell them any time soon. Nor do I expect a donation of a rod-braked roadster any time soon to use them on either.
#53
Quoted: 1106 Post(s)
Liked 1,197 Times
I wasn't sure what other 700 wheels there were. I'm fairly limited to knowing about 700C, 650C and 650B, and the 27.5 and 29" equivalents. And whatever version of 26" are on older MTBs. It's very interesting when, in referring to a 650B tire, like on a gravel bike, they might write the tire size with a C. "I got some 650B wheels for my gravel bike and I'm rocking some 48C tires."
#54
Quoted: 1619 Post(s)
Liked 3,087 Times
glad VegasJen is back. if 23's work for you (which, relatively suddenly, is no one), great. if they don't, great. thank goodness for choices.
for extra giggles, mix and match 23's and 25's on the bike, or better yet, 25's and 28's. so much fun planning for flats in that last instance...
#55
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,094 Times
I say "23c" because that's what's printed on the tires. I assumed it was synonymous with 23mm. Is there a difference. And for the record, the only reason I'm still running those tires is because that's what came on my bikes. When they wear out, and by that I mean cord showing, I'll try a 25 or 28c.
23c is correct, 23cm would be wrong.
I think it's a bad idea to wear these to the cord showing because they might blow out catastrophically before you get there, but it's at your risk, not mine.
#56
OM boy
Bikes: a bunch
Quoted: 502 Post(s)
Liked 623 Times
Normally a cable replacement and adjustment is a DIY thing, but for those who don't have the knowledge/skill or are hamfisted - best to have a shop do the work.
If 23c is a problem, move to 25c , same performance, a bit more tire on the road.
Bike Handling skills don;t magically happen. It's takes awareness, knowledge of how to handle a situation and good execution.
One should never be 'surprised' by road conditions. Alert awareness is easy, but often difficult to keep attention to. Not adapting to changes in your riding interface is a basic flaw.
Rain, standing water, sand, road snakes, potholes/chunking, a wheel overlap with a rider in front of you, the list of possible issues is ongoing.
We all make mistakes, lose attention at times. The key is to minimize this as much as possible and know how to handle and have the skills needed to handle...
Riding a bike is NOT about plowing ahead as fast as you can, oblivious. The journey is greatly determined by the process.
Ride On
Yuri
