Unable to remove crank threads partially stripped
Quoted: 236 Post(s)
Liked 171 Times
Hey all - new bike and when I went to take off the drive side crankarm found this:
Someone ground down the threads on the crankarm - aaaaargh! I'm unable to thread on the extractor tool .. what can I do to fix this?
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
I made a thread chaser out of a broken crank extractor--cut some tap-like slots into the nut--and that works sometimes. Sometimes I can carefully repair the leading threads with a utility knife. If those tricks don't work I get out the pickle fork (automotive ball joint separator).
Likes For andrewclaus:
Quoted: 2026 Post(s)
Liked 1,096 Times
Uhh, did you remove the crank fixing bolt (the hex head bolt in the middle of the opening) first before trying the extractor?
Quoted: 236 Post(s)
Liked 171 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
failing that, a pulley remover rented from auto stores also works. you get your money back when you return the tool
like this....
like this....
i have never done this, just a hypothesis, remove the left hand crank, lock nut and cup,
now the rt crank can rest against the fixed rt cup, take off the bolt, remove the washer, put the bolt back in then back it out maybe 1/8th inch, put some pb blaster oil in there, or liquid wrench, get a drift punch or piece of round stock, tap on the spindle pretty good and see if it pops off,
or buy a bottom tap of the same thread size and chase it,
Quoted: 668 Post(s)
Liked 529 Times
Beaucoup threads on this.
Heat, 2 pickle forks, Jacobs chuck wedges are some of the methods to remove cranks with stripped out extractor threads.
Gear pullers generally haven't worked for me, but the one thook posted looks like it might have a chance of not slipping off. Put it on, get some tension on the arm, heat the arm with a heat gun, retension the puller, then tap the side of the crank arm sharply with a hammer to help vibrate everything loose.
If none of that works than break out the hacksaw...
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 1074 Post(s)
Liked 295 Times
5-arm crank?
The generic pullers tend not to work well on those. They don’t center right. If you insist, they tend to slip off under load. 3-arm pullers might do less poorly. Chuck wedges, pickle Forks work better. Or cutting the BB spindle.
Klaatu..Verata..Necktie?
Quoted: 10413 Post(s)
Liked 11,874 Times
Chuck wedges. Do a search for them on BF.
Likes For genejockey:
Quoted: 668 Post(s)
Liked 529 Times
I bought a set of Jacobs chucks but haven't had need for them yet. I replaced the 35 year old stripped out crank with a campy ultratorque unit. Crank extractors suck.
Liked 11,874 Times
I've used a single pickle fork with some sheet metal shims to protect the bike, but someone on here suggested using two pickle forks. that would be most excellent. Pickle forks have the hammer helping to vibrate stuff loose as well.
another trick is to leave the bolt off and ride the bike for a while,
of course you want to monitor things closely so
1) you don't crash
2) you don't butcher the taper
and don't stray too far from home.
1) you don't crash
Likes For cjenrick:
