Unknown 'star' frame
SAARF WAS WRONG!
Picked up this frame for cheap at a bike salvage yard. $25, I could not resist since it is pretty cool, Italian (?, bottom bracket has Italian threads), and is my size.
There are no discernable decals for identification. There is Campagnolo decal on the chain stay and some remnants on the fork blades (unknown).
Fork steerer tube has Columbus ridges and is stamped with a "3" and backwards "S". Bottom bracket shell is stamped with "54", "53", and backwards "S". Size: seat tube 53cm c-c, 54cm c-c, BB shell 70mm, rear fork 125mm, seat post 27.2mm. Campagnolo drop-outs front and rear (has what I know to be "portacatena" holes; thank you forum members!).
Likes For philpeugeot:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
That'll be quite the resto effort.
Belgian and Swiss bikes also frequently had Italian threaded BBs.
Very unusual to have the star without one of the points going straight up - ie your star is upside down.
Olmo used to use a similar right-side up logo.
Guerciotti had a star too, but it was kind of distorted and asymmetrical.
SAARF WAS WRONG!
Sorry, trouble with photos. I have an old Olmo with a star and it is not the same.
Here are more photos:
Likes For fabiofarelli:
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
I had one very similar to this that I posted summer of 2019. Unfortunately my computer died and I lost my photos.
I tried a search but couldn't recall the title.
MauriceMoss recognized it and there was an interesting story behind the production. Not saying it's not a Viner just confirming.
Edit: Mine might have been a Vetta
juvela might confirm it??
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,796 Times
Matches the Viner details in the link.
SAARF WAS WRONG!
Thanks all! I am not at all familiar with the name so I appreciate the input. Looking at the photos I now think the fork says "Prima Velocissma". Could that be a model, or just a catch phrase for the brand? The BB shell appears to have had heat applied I would assume in order to remove the cups. I will do my best to bring this frame back to life; I think it deserves it.
SAARF WAS WRONG!
I have just read the link write-up on these frames (Thank you fabiofarelli ). I now know that this is a "Special Professional" with Columbus SL tubing; outstanding! I will make sure it gets done right with a professional paint job (probably keep it the same color) and some period Italian parts. I wonder if there is a way to determine the year. There is that odd backwards "S" that is on the BB shell and steerer tube. Could it be a year indicator or the mark of the actual builder? I now need to see what the actual decals need to be. The fork crown must be fairly early as it is flat, there are bosses for a bottle cage, and braze-on shifter mount bosses. I figure more 70s than 80s with that crown design. Does anyone have a known year example?
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
Given the portacatena holes in the DOs it can be no earlier than '78 (and most likely '79 is more realistic for earliest date), most of the time those DOs were in use for 1980 models and pretty much dropped out of use by '85. Having recessed Allen brake bolts yet over BB shell cable guides makes me think kind of "in between" so I'd make my guess "1982". Give or take.
Quoted: 1088 Post(s)
Liked 1,205 Times
Quoted: 5888 Post(s)
Liked 3,471 Times
Did you buy this in the US or Italy? Gus Betat in New Orleans imported Viners to the US. I saw a number of these bikes. They had, I believe, fairly steep geometry. Folks who raced criteriums liked them a lot.
SAARF WAS WRONG!
Here is the thread, but it looks like the markings are different: https://www.bikeforums.net/classic-v...ry-bike-2.html
SAARF WAS WRONG!
I am sure that this should be asked in a separate forum/thread, but I will strike while the iron is hot. I am new to repairing stuff except that which generally easily unscrews without resorting to extreme methods. I would like to get this frame done quickly if possible and at least expense since I have acquired the proper tools and don't want to bring to a bike shop for this work unless absolutely necessary.
I assume that the BB was unable to be easily removed so I am going to first pretreat with PB blaster penetrant and then wrap in plastic and submerge in ice cold water until thoroughly chilled. I will remove it from the water and immediately warm it up with a heat gun (think higher temperature hair dryer; I use it normally for industrial heat shrink sleeving). I do not want to torch it as it looks like it has undergone that already (would that extreme localized heat cause improper tempering or weakening of frame connections?). I am thinking that going from rapid extremes of temperature will, due to expansion and contraction, help break the corrosive 'weld' between the cups and shell. Does this make sense, or am I nuts?
SAARF WAS WRONG!
Liked 1,062 Times
not sure since Viner appears to use different crowns as well as other frame bits in a haphazard mode, so may not point to a specific model or year, but for me a flat crown has some extra panache (DeRosa style points!) so I'd consider it a plus!
Can't go wrong with a Columbus SL Italian frame that cost you half of $75 (did I get that right?), it's a steal, despite the rust!
SAARF WAS WRONG!
Likes For le bici di jaco:
WGB
Liked 2,334 Times
