7 Speed to 8 speed upgrade
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 47 Post(s)
Liked 42 Times
Thinking of going from 7 Speed Freewheel to 8 speed for touring. Been using 7 speeds for years but do I actually gain an thing upgrading to 8 Speed?
Trying to decide if the cost is worth it. My trips are anywhere to 20-50 for day trips and 400+ for touring with front and rear panniers.
The bike is a 20 year old Diamondback Parkway which has been my daily riding bike for years
Quoted: 1074 Post(s)
Liked 295 Times
The thing to do in a situation like this is first to decide if you’re doing it for the fun factor, or If you’re looking for utility value.
If UV, have a good think about where you think your current setup is coming up short.
I could see a point in going from 7-speed freewheel to 8-speed cassette, as that would gain you some top end while not changing the gaps between ratios too much.
I could also see a point in gettingthe more reliable rear axle design that comes with cassettes.
If you stay with freewheels, you’re basically getting one intermediate gear somewhere in your range, and a more stressed rear axle. And a hub that needs re-spacing and a wheel that ideally should be re-dished. I’d probably not do that.
It's possible but not likely that a 20 year old bike has a "freewheel."
I expect it is a cassette.
And the answer might be to run 8 speeds of a 9 speed cassette on the 7 spd freehub body. Sheldon has an article on this. Of course.
Quoted: 1557 Post(s)
Liked 1,732 Times
Your shifters will also need to be replaced with 8 speed shifters.
Quoted: 1815 Post(s)
Liked 1,693 Times
Your first problem is that they don't make 8 speed freewheels. Nor is it advisable even if they did make one. You would have to swap to a wheel with a cassette hub. Luckily those are plentiful on Craigslist or your local bike co-op.
Likes For alcjphil:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
IMO, you should be well aware if you are unhappy with your gearing. If not, you can save your money and just keep running what you have.
Likes For ThermionicScott:
Quoted: 47 Post(s)
Liked 42 Times
My hub is a freewheel and found many 8 Speed free wheels on Amazon & Ebay.
Aware of needing new shifters and was planning on going from grip to thumbs shifters due to a wrist issue,
along with derailleur and chain. Looking to get a wider gear range .
Nothing in concrete yet, just thinking about possible upgrade for the winter months and longer tours next year.
Thanks for the assists
Liked 1,693 Times
Oh, you may also have to modify your frame to allow the longer axle to fit
Likes For alcjphil:
Quoted: 47 Post(s)
Liked 42 Times
I know more research needs to be done before I start buying parts, that's why I request info from this site
I also need to look at the cost factor
Liked 2,563 Times
+1. I would definitely replace or rebuild the rear wheel to have a cassette hub, especially for touring loads. You can use pretty much any hub that is designated 8, 9, 10, or 11 speed. There are some good and inexpensive options in 8-speed cassettes, still. Be advised that your frame will either need to be adjusted for the wider spacing, or you will need to pull the dropouts apart slightly when installing your rear wheel.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
If I had a 7-speed drivetrain and wanted to upgrade, I'd skip right over 8 and 9, and go with 10 speeds. In fact, that's what I did, with an old Trek 1100 a few years ago. It is not *that much* more expensive. It's immeasurably more work than continuing with your current setup, but about the same amount of work as going up to 8 speed.
Quoted: 1943 Post(s)
Liked 2,164 Times
I still have 1 freewheel bike. All the rest were upgraded, or originally set up as 8, or 9 speed.
As others have said, it all depends on what you need from your setup that your current 7 speed freewheel lacks.
For example, if you find an 11-34 8 speed freewheel instead of a 13-34 7 speed, all you are gaining is more top end speed. You get nothing else from your change. If that is what you lack, it will help at the expense of durability.
It might be better to analyze your chainring options. This may still mean some expense, but depending on what gearing you need, that might be an option.
Freewheel to cassette upgrades tend to include wheel upgrades. Unless you have a compelling reason, or a good source, those generally lead to asking if this bike is worth the investment, or should a person move on.
John
John
Quoted: 2493 Post(s)
Liked 738 Times
Quoted: 1604 Post(s)
Liked 2,569 Times
When you say worth it, do you mean bike value or ride value? If everything is in working order, I'd go with replacing the shifters. If you want to change the ride quality, I'd try some new bikes. Trek makes an FX that is similar and you could probably find a used one on Craig's. Used these shifters as a twist grip replacement.
https://www.modernbike.com/product-2...hoC464QAvD_BwE
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Like this 1999 Diamondback Parkway? Has a 28-38-48 crankset and 13-34 7 speed rear cluster. Can’t imagine you need more than a 34/28 to get up hills, and a 48/13 will spin out around 28mph.
If it were me, I’d go ahead with the swap to thumbies (which seems to be the over riding reason for change) even if that means friction instead of indexed.
Aside from that, would spend money on good tires/saddle and call it a day.
Likes For rccardr:
Quoted: 47 Post(s)
Liked 42 Times
and the research goes on. Thanks
I have enough bikes as it is in the garage.
