Was Debating Some Bar-Ends.. Picked Up Ergo Grips Instead
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
At first I was debating these:
https://www.amazon.ca/dp/B001KS3RFQ/ref=cm_sw_r_u_apa_fabc_Cr1-FbTQEEYXX?_encoding=UTF8&psc=1
I've been wanting some bar -ends which mount upwards to offer another hand position, but realized that I would need to either cut the end of my current crappy foam grips or install some.sort of special new ones.
I ended up going for these grips instead- picked them up for $20: https://www.amazon.ca/dp/B08DN959VL/ref=cm_sw_r_cp_apa_fabc_Bi6-FbXC3J1DH?_encoding=UTF8&psc=1
For those who have bar ends already, like them? Never use them? Are they useful?
Are these ergo grips worth it?
I have the Ergo 5 style (the longest they offer) and I have them on 3 bikes. They give you more hand placement options and the rubber takes some of the road vibration out.
Likes For neutrinocounter:
Clark W. Griswold
Quoted: 4252 Post(s)
Liked 3,866 Times
Ergon Grips are worth it, cheap knockoffs are not. Those grips don't look as ergonomic and the bar end is not adjustable meaning it can be in the wrong position and cannot be changed without changing the position of the grips.
Also this is what Coruscant is, a fine home for the Galactic Senate but maybe not the company I want producing my grips.
Likes For veganbikes:
Drip, Drip.
Liked 193 Times
I was looking for something soft and cushy along with the added ergonimics. Do they deliver?
As I said, I have the Ergon 5's on all 3 of my bikes which should say something about my opinion of them.
Ergons do help, but must be positioned correctly. If the palm support is too high or too low, it's worse than having normal grips.
If you want bar ends, they make Ergons without the horn and open ended to slide further up for bar ends.
Bikes: Cannondale Quick 2
Quoted: 27 Post(s)
Liked 30 Times
Best regards
I have a '95 Trek 730 Multitrack that is equipped with Trek's "System 1" bar ends that are similar to what you show first in your opening post (tubular aluminum).
Most of my riding is on the road, and I do spend quite a bit of my time with my hands on the bar ends. I have some Lizard Skins slip-on bar end covers on there that provide a little bit of cushioning and grip.
I considered the Ergon GP5 grips at one point when I was experiencing some tingling/numbness in fingers, but decided at the time to give the setup I already had a little more time.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 761 Post(s)
Liked 553 Times
FYI on the Ergon 5's
don't put too much weight on the very end and hammer down
did this myself and going full gas the grip came off and over the handle bars I went
Clark W. Griswold
Liked 3,866 Times
Make sure you properly seat and torque your grips as well. I have no doubt going full gas out of the saddle they could come loose but if properly torqued down in the correct position (which sometimes they are not) they are less likely to do so.
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
Instead of using Ergon grips and separate bar ends, just get some Ergons that already have them integrated:
Likes For Kapusta:
Quoted: 1062 Post(s)
Liked 665 Times
In my view the important thing is rotating your wrists. I found that ergo grips provided a tiny bit of rotation, but not enough. There are attachments that can make straight bars more comfortable, but there's also a reason why "comfort" bikes have swept bars, and the reason is... comfort. I've switched all of my bikes to swept bars.
Likes For Gresp15C:
Likes For gorillimo:
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Dew Deluxe,Zone Ltd. (frame, needs parts), Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, Fantom Cross Uno, Bridgestone 200
Quoted: 108 Post(s)
Liked 227 Times
I had a set of these on my Paratrooper, but after loaning the bike to a family member for a ride... I couldn't get 'em to stay together anymore. I'll just say he's a bit rough with the equipment.
I had another set of Ergons handy, without the extensions, and they're working just fine. I rarely rode on the bar ends anyway.
