27 inch tire blowing off the rim
Good morning - first post here. I'm restoring an '61 Legnano Gran Premio with original Fiamme 27 inch clincher rims. I've tried Panaracer Pasela as well as Gatorskins tires, both have blown off the rim with the tire exploding. No bead on the rim. The tires were "too easy" to mount so I had suspected this may happen and slowly pumped it up checking every 5 pumps. Thought it was going to be successful when a few minutes later: BANG! Any suggestions with what tires to run here? Thanks.
Quoted: 18320 Post(s)
Liked 4,489 Times
What is the tire size you're running, and what pressure are you running?
Quite a few of the 27" rims were "Hookless", and not particularly designed for high pressure.
Are the sidewalls of your rims straight, or is there a hook near the edge?
Bikes: A bunch of old bikes.
Quoted: 265 Post(s)
Liked 821 Times
Even with the wire beads, some will work better than others.
I've had good luck with the wire bead Panaracer Pansela, I don't inflate over 80-90.
Quoted: 4719 Post(s)
Liked 3,034 Times
+1, you required non-folding, wire bead tyres. The beads in folding tyres are too flexible and require a hooked rim to to aid in seating
Likes For T-Mar:
Likes For alcjphil:
Quoted: 1088 Post(s)
Liked 1,204 Times
Same here -- I ran wire bead non-folding Paselas in 27 x 1 1/4 at around 60-70 psi and never had any issues. First ran them on vintage Super Champions, then Weinmann touring rims from a 1985 bike, so neither rim set had hooks. It was a commuter that I rode 2-3 times a week for a couple of years.
feros ferio
Quoted: 1384 Post(s)
Liked 1,295 Times
Quoted: 559 Post(s)
Liked 1,032 Times
Not much to add beyond what others have said about tire compatibility. I recently put some Vittorias on my non-hooked rims and it took a bit of fiddling but all seems okay now. If it is still a problem, tubular rims/wheels would be very appropriate and nice ones can be found for very good prices. I bought a vintage set with entry level Campy hubs for $60 and they spin like butter.
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,274 Times
What brand of rims on the Legnano?
Quite a few old Weinmann clincher rims were prone to blow-off at modest pressures as low as 75psi using almost any wire-beaded 27" tire.
I think that the quality control of the diameter was the reason that some rims did or did not suffer this issue. Newer (still hookless) rims seemed to improve on their bead-retaining ability, and I remember 1970's Japanese single-walled rims reliably containing 100psi.
All the Super-Champ 27" rims I've seen had at least some bit of a bead-retaining lip or nub, and none have given me trouble.
But pre-~1977 Weinmanns are a crap-shoot it seems.
Friendship is Magic
Bikes: old ones
Quoted: 26251 Post(s)
Liked 10,233 Times
...if you really want to experience what your Legnano is capable of in terms of speed and handling, it behooves you to rebuild those wheels with a more modern, hook bead rim. The rims will be lighter, so less rotating weight. You can switch to 700c so you can access better tyres. And you can inflate them to pressures that will allow faster riding, if you weigh more than 120 pounds soaking wet.
Even paying someone to do it is well worth the investment. There are a number of candidate rims, with the Sun M 13ii one of the more economical choices, that still look reasonable on an older bike.
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 273 Post(s)
Liked 919 Times
Agree, wire bead is key for hookless rims. For pressure, I started with 50, let it sit for a day, then increase it 5 lbs a day. For the rims I had 65 would work. 70 would blow off eventually (lot's of fun if in the middle of a ride). I did pick up some hooked rims, and they made the riding experience much better.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
