Need creative or obvious way to carry single golf club on the bike
Quoted: 2333 Post(s)
Liked 2,097 Times
Duck tape to the chain stays
Quoted: 1397 Post(s)
Liked 1,877 Times
my kid carries tools in a baseball backpack similar to backpack in pic
Quoted: 2482 Post(s)
Liked 2,954 Times
When I find myself similarly stumped, I tell myself, "A solution is at hand within 15 feet of where you're standing right now."
Example: a mountain bike front derailleur whose spring anchor point had snapped off. Jammed a twig into the derailleur to lock it over the middle chainring. Rode home, looked around, spotted a slit inner tube I'd thrown in the trash, cut a section out of the tube, rigged it to replace the spring. The derailleur shifted just as well, and maybe better. Used it that way for a couple of months until I got around to picking up a new front derailleur.
Likes For Trakhak:
Quoted: 2952 Post(s)
Liked 3,106 Times
I'd just get a length of cord slightly longer than the club, tie an end to each end of the club, and sling it over my shoulder. As I think about it, surgical tubing would be even better than cord because it would be grippier.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I like that saying, and it's probably time for some thread drift. A few times I'd find myself in the backcountry having forgotten to pack something. Once was eating utensils. Then I realized there are sticks lying all over the place and about a billion people eat with sticks all the time. Now I don't worry about packing utensils any more.
Likes For andrewclaus:
Yes, but more elegant - especially if yo are going to do this regularly: wrap strips cut from innertube around the headtube and seatstay/seat lug. Then tie the club to the top tube with innertube ties at those wraps. (Or wrap your club at those locations and keep the bike looking nice.)
My avatar photo shows a 24" chainwhip lashed to the top tube of my fix gear with an innertube wrap at the seatstay and around the tool handle. Toestraps secure it. (I made the tool with a piece that fits the seatstay to make it more secure. This was for week long tours, not a three mile trip to a golf course.)
Quoted: 1944 Post(s)
Liked 2,164 Times
Quoted: 6963 Post(s)
Liked 10,963 Times
I want to ride my bike 5 mins to the nearby soccer field to hit practice golf balls.
I would love to ride and not take the car.
Balls fit in my pocket, but how can I carry a golf club?
Stick in backpack, half exposed?
Lay across handlebars? Unsafe?
Someone here has to have a good hack!
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Burley makes (or once made) a trailer for this kind of thing:
This would also allow you to use all of those useless golf features on a Garmin watch.
Quoted: 18413 Post(s)
Liked 15,536 Times
Likes For FBOATSB:
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
Watch that you don't short the terminals on your battery.
Likes For shelbyfv:
SE Wis
Quoted: 2746 Post(s)
Liked 3,394 Times
Quoted: 1609 Post(s)
Liked 2,590 Times
I wrap a fishing pole to my top tube with a long bungie, but I bet you could just slide it down the back of your shirt.
Liked 2,164 Times
For the amount of time spent on this thread, the OP could have walked there a dozen times.
John
John
Likes For 70sSanO:
Quoted: 346 Post(s)
Liked 398 Times
You could find a $5 ancient BAG BOY pull cart from your local Goodwill or from a garage sale.
Many of the BAG BOY models from the 1960's and 1970's have a pull handle which is almost infinitely adjustable as to the angle of the handle.
You'll see it when you see it.
Most others have a fixed angle of the handle stem which can't be adjusted (the golfer pulling, or pushing the bag has to use his/her arms to lift/lower their hands to the most comfortable and effective position for use.
Many of the various pull carts from the 1950's, 1960's and early 1970's were very well built, with quality axles and frames and very strong and sturdy with quality steel ball bearings and almost indestructible wheels. Most before the early sixties have narrow one inch hard steel wheels, like from a fifties era child's red radio line wagon, or from a fifties era garbage can cart, or from those triangular shape garden cart-wheelbarrows from the fifties.
If one was to find two front wheels from junk childrens' bikes ( example:spoked steel with innertube with schrader valve and not too agressive tread...no severly knobby-motocross like tires.... ideally,.you want normal, unagressive rubber tread pattern on the tires.) You could maybe find similar innertube & tire, pneumatic tire, garden cart-dolly type replacement wheels at Harbor Freight but junk bikes laying on a curbside trashpile might be the best low-cost solution.
Essentially, you adapt the ancient pull-cart in the same way that a purpose built bike trailer attaches. (e.g. like that Burley trailer that someone posted a picture of earlier)
My guess is you'll need scavenged used bicycle wheels to replace the original golf pull-cart wheels BECAUSE the pneumatic tire and shrader valve innertube bicycle front wheels scavenged for this DIY conversion will allow for a much smoother, more cushioned ride for the clubs, and a more stable ride for this DIY trailer golf cart following behind your bicycle. These ancient, strong, well built metal pull-carts already securely cradle most any size or shaped golf bag. The DIY part that you'll be faced with would be adapting the handle-arm to safely and securely attach like a bike trailer to your specific bicycle.
One important thing that you should remember to do each and every time AFTER YOU BUILD THE DIY trailer type attachment.....
**You'll need to use a golf bag that has the Snap On or Zip On "rain cover" or "airline travel cover"......whatever you want to call it......you know it is that which stores in the large long side pocket of the golf bag and seldom ever gets used by hacks and duffers, or folks in Southern California where it never rains, but good golfers who play all the time in the rain know the importance of trying to keep the grips dry.....thus the snap on rain hood is wonderful in rainy conditions. THE REASON THAT YOU WOULD WANT IT ATTACHED, SNAPPED ON OVER YOUR CLUBHEADS, FULLY ZIPPED, is Because it Will Keep The Clubs Contained Within The Golf Bag, Should You Go Over Any Bumps, or Irregularities in the Road while you are pedalling to the course with your clubs following your bike at 18 mph. You don't want the clubs to bounce straight up........the secured , fully closed up snap on rain hood will keep your clubs from doing that while in the DIY ancient golf cart trailer.
pictures of some really ancient type of golf pull carts that might give you a good DIY idea..............you'll likely find something like those for about $5 at Goodwill.
Lots of country folk in the South, find and look for those old golf pull carts to make low cost but effective DEER CARTS.
https://www.bcgolfhouse.com/history-of-golf-pull-cart
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,034 Times
Please don’t quote this post in the Di2 thread.
Likes For MattTheHat:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
History of Golf Pull Cart |
You forgot the possibility of building a small dirigible airship capable of lifting the club and controlling it as a drone while riding.
Likes For livedarklions:
Tragically Ignorant
Liked 9,098 Times
Seriously, how many ways can there be to accommodate a relatively small object for a 5 minute ride?
OP keeps disproving the old saying about there being no such thing as a stupid question.
Quoted: 790 Post(s)
Liked 348 Times
I rode across town with a weed-eater on my back the other day by taking a length of it's string and tying it to each end of it to make a sling that I could put over my shoulder like a messenger bag.
Likes For beng1:
Sr Member on Sr bikes
This thread/question reminded me of a thread that originated more than a decade ago, but was resurrected at the end of last year (2021). The premise, to me, was kind of humorous. But, maybe it can provide the OP with a solution.
https://www.bikeforums.net/general-c...word-bike.html
Dan
Dan
Likes For _ForceD_:
Tragically Ignorant
Liked 9,098 Times
Things I carried on my bike when I was young and stupid:
A cello
A mandolin
An end table
A floor lamp (bulb removed)
And the ever-popular pony-riding a second bike.
I regularly rode with my violin, but I had a proper case for that complete with a shoulder strap, so I don't count that as stupid.
A cello
A mandolin
An end table
Quoted: 2700 Post(s)
Liked 486 Times
To be fair the amount of people telling him to mount it to the top tube (where something as heavy as a golf club could easily come loose and get caught up in a wheel) shows that even stupid questions can have dumber answers. OP learn to ride one handed... or your backpack idea isn't terrible but id rather just ride one handed. You really dont need much skill. "hopping curves" is much harder than riding one handed and you have to do that on your 5 minute commute
