Stiffer frame/bb for large rider
Second Trek SL5 62cm frame kaput due to dropped chain. Trek recommend a different model (SLR or Checkpoint) with a stiffer frame/bb. Wondering if I should be looking at a different manufacturer. Any thoughts? I'm 6'6" 250# so shop mechanic suggests there's too much of me for the SL frame. TIA for any input you can offer.
Quoted: 5781 Post(s)
Liked 2,578 Times
Stiffer how? Are you dropping chains because the seattube and BB are twisting under load? or simply looking for something stiffer to improve handling?
It's important to understand the EXACT issue you're trying to resolve before spending money on something that doesn't actually solve anything.
The reality is that unless you live in hill country, BB loads aren't actually that high, and the problem may actually be your riding style, vis. pushing high gears at low cadence, which will disappear completely if/when you address that. (plus your knees will thank you later).
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 4201 Post(s)
Liked 3,859 Times
To follow up on another recent thread's content- The industry's response is to eliminate the ft der all together. Of course other features need to be improved when there's no ft der, like rings with wide/narrow teeth that can only be had in even tooth counts. It's like a dog chasing its tail. Andy (who rode 50 fairly flat miles today and will likely be VERY glad the bike has a granny tomorrow when climbing out of Springwater, NY)
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 1819 Post(s)
Liked 1,693 Times
So, "Trek SL5" What? which model are you asking about? I have seen many riders who I consider to be abusive. I don't think that your problems are because of a frame that isn't stiff enough, it may be because of unrealistic expectations of what you are going to be able to do while shifting your front derailleur
Thanks for contributing to this post. I'm mostly repeating what the tech at the Trek shop shared from his conversation with Trek folk. Sounds like the bb is twisting under load. I live in SLC so do have elevation change. The most recent dropped chain was 25 feet off of a dead stop, seated, and switching to the large chain ring as I quickly moved off the line and gathered enough speed to warrant the gear change. I was in the middle of the cassette's gears as I did so.
Liked 1,693 Times
"I live in SLC "
Please for the uninitiated, Where is that?
If failure happens while changing front rings it is often caused by not easing up for the half second it takes to make the change. Frame or bottom bracket stiffness has little to do with this
Liked 2,578 Times
Pardon, but I'm struggling to connect the dots here.
As you describe the event, it seems like a straightforward shifting under load issue.
How did you get to a frame stiffness issue, and how exactly did the frame break (if it did).?
Without very detailed and specific descriptions, we're shooting blindly on a dark foggy night.
Liked 1,693 Times
As you describe the event, it seems like a straightforward shifting issue.
Liked 2,578 Times
It seems that the OP, Trek and the dealer are all agreed that it's a frame stiffness problem. If so, and if all the OP wants are suggestions for stiffer frames, I can't help him, though I'm sure there are others here who might.
OTOH- Based on the tiny bit of info provided so far, I'm skeptical that a stiffer frame will change anything. At this point I'm forced to wonder if this is a case of taking Pepto-Bismol for a headache.
FB
Chain-L site
FB
Chain-L site
Quoted: 18375 Post(s)
Liked 4,510 Times
Please explain what you mean. Is the frame broken? Did you drop the chain and tear something up with the dropped chain? Ripped off the rear derailleur? Broke the chain? Dropped the chain between chainrings?
There are a variety of drop stops and chain catchers available that help prevent dropping the chain on the inside. A bash guard will help prevent dropping the chain on the outside.
Liked 4,510 Times
I have heard complaints that some carbon fiber frames from about the year 2000 to the year 2010 were considered overly stiff. So that might be something to try, and might be cheaper to experiment with.
You could look at a steel frame with oversized or double oversized tubing. However, they tend to make the tubing thinner with the bigger sizes.
You could talk to a frame builder, and see if they had any suggestions. Perhaps use oversized MTB or touring tubes on a road bike build.
If you do want to stick with carbon fiber, I'd look at some of the cyclocross frames.
Quoted: 1397 Post(s)
Liked 1,877 Times
agree with replies above that suggest this might be other or more than a frame / frame stiffness issue
but for stiff frames for big / strong riders - back in the day there was one popular choice in our area : Cannondale
many of the big / strong mashers were on Cannondale frames ... both standard frame and the crit frame (with the even larger down tube)
Quoted: 1944 Post(s)
Liked 2,164 Times
As others have said there is too much going on to know the exact cause, other than the Trek dealer's response; which may or may not have analyzed the situation.
If I understand the latest situation, you basically accelerated two crank revolutions, (Estimate 7' circumference at 2:1 ratio = 28') and shifted under force and dropped the chain that (I'm guessing) tore up the chainstay. Generally modern drivetrains with ramps and pins to assist chainring shifting have eliminated a lot of issues, but trying to make a 16t jump (compact crank?), especially after multiple hard shifts may be more of a culprit.
Regardless of the actual cause, to be specific to your stiffer question, I'm not sure there is a lot of published data of bike frame lateral stiffness. Apart from that you may only get educated and uneducated guesses. I did find an article that provided some data, although it is 6 years old, it does give tested numbers for some frames. My recommendation is to pursue data driven recommendations and hopefully find testing of current frames. Possibly contacting "Tour" magazine for more current data.
https://www.cyclist.co.uk/in-depth/1...rame-stiffness
John
John
