Bigger tires for hybrid?
Old 09-20-22, 12:52 PM
2ndtimeAround
2ndtimeAround's Avatar
Bikes: Hardtail MTB , Citi-Bike , Electra coaster, Schwinn coaster brake and 2 road bikes
Quoted: 19 Post(s)
Liked 36 Times in 15 Posts
cc
2ndtimeAround is offline
Old 09-20-22, 12:55 PM
tFUnK
Quoted: 425 Post(s)
Liked 452 Times in 311 Posts
If you are able to fit a 40mm touring tire currently, you should have no problem fitting a 40mm gravel tire. That's what it sounds like you're wanting to do - just to have a tire with more aggressive tread to do some light off-reading.
tFUnK is offline
Old 09-20-22, 01:00 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,692 Times in 973 Posts
Thanks for the great details in your post, very helpful. I have to ask, what tire pressure do you run in your current tires? I ask, because I set my 700 x 45 gravel bike tires at about 35 psi and they work pretty well on unpaved surfaces while still providing decent rolling resistance on the road. Pending your answer, maybe tire pressure is a possible answer
alcjphil is offline
Old 09-20-22, 01:15 PM
alcjphil
alcjphil's Avatar
Originally Posted by 2ndtimeAround
Im running about 36 PSI ft and rr. On paved road the kenda tires are fantastic. ( running about 50PSI)
And I appreciate both very quick replies !
I forgot to ask how much you weigh. I weigh about 155 pounds. If you are used to mountain biking, the narrower tires on your hybrid may feel unstable. I know that my gravel bike cannot compare to my mountain bike on technical trails no matter what tires I put on it. All that I do is proceed with caution knowing that many obstacles that my mountain bike can get over might not be doable on my gravel bike. I accept this, because the easier trail sections are so much more fun on the gravel bike
alcjphil is offline
Old 09-20-22, 01:23 PM
alcjphil
alcjphil's Avatar
Maybe, at 130 pounds you should adjust your tire pressure a bit lower, at least off road. You really are a flyweight. I am a great believer in doing the best you can do with what you have before spending money on things that may not be needed
alcjphil is offline
Old 09-20-22, 01:38 PM
alcjphil
alcjphil's Avatar
Of course, I can't see the conditions you ride in. The area where we mountain bike locally has some very difficult single track. There is one trail that we have named "rocky road", another that we have nicknamed the "Ho Chi Min trail". A few years ago a couple of my friends did a road trip out to Moab and spent a week riding there. I have been there myself so I know why that when they got back they couldn't handle our local trail network. These little local trails are very technical. About half of them are too difficult for me at 72 years of age to try on my gravel bike which probably is about equally capable to your hybrid
alcjphil is offline
Old 09-20-22, 04:05 PM
70sSanO
70sSanO's Avatar
Quoted: 1942 Post(s)
Liked 2,162 Times in 1,321 Posts
Here’s my take. I did a quick look at your hybrid city bike. The basic geometry is not that far off from a 10-12 year old 29er, except the chainstays are probably too long. I’m not saying it is comparable to a mtb, just looking at angles, wheelbase.
Since it is a flat bar bike and you sound like it will be a less technical replacement to your 26er, I’d approach it that way. Little more aggressive rear tire and a more rounded better rolling front tire.
You will probably be in the 400-500 gram weight for a folding tire. Obviously the more traction the slower rolling and the more grip the less durable… generally.
Also, the days of $20 folding tires are over. Even old 26” Fire XC Pros are running close to $50.
John
Edit added: You won’t have a problem with 22mm inside width rims. People were running over 2” on Mavic 217’s.
If you go to 42mm make sure you have frame clearance.
70sSanO is offline
Likes For 70sSanO:
Old 09-20-22, 09:26 PM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
Here's a place to start: Bike Tires Direct: Gravel Tires 700 x 40
I like a fish-scale or 'file' tread for an all-arounder, like the Schwalbe G-one, but if you ride a lot of really loose surfaces, then you could go to something aggressive like the WTB Nano, or any of the dozens in between.
Unless you're doing full sends on your hybrid, even a little bit of tread I'd going to be far better than the slicks you've got on there now
Ironfish653 is offline
Likes For Ironfish653:
Old 09-20-22, 10:12 PM
t2p
Quoted: 1387 Post(s)
Liked 1,844 Times in 1,062 Posts
Continental 700x40 Terra Speed and Terra Trail are two good options
both roll fairly well - especially the Terra Speed - and they weigh under 500 gms ...
(our 700x40 Terra Speed weighed around 460 gms and Terra Trail
weighed around 475 gms)
t2p is offline
Likes For t2p:
Old 09-20-22, 10:31 PM
squirtdad
squirtdad's Avatar
Quoted: 2336 Post(s)
Liked 2,804 Times in 1,532 Posts
I don't do 40 mm, but like the panaracer gravel kings in 28..... I would look at the Gravel King SK or SS in 38
squirtdad is offline
Old 09-21-22, 05:26 PM
Ironfish653
Dirty Heathen
Quoted: 889 Post(s)
It appears specs a 42mm . I've frame ,fork clearance ( tons) just a question of whether one would run that tire on a 22 mm ID rim . One thing for sure will be running a fairly low PSI . 130 lbs rider, dressed.
The BiekForumz answer would be NO, but that's because MTBs were only invented in 2010.
Seriously, though, the pretty standard setup for XC race bikes in the 1990s was 48-52mm (1.95"-2.1") on 17-19mm rims. (Bigger tires and narrower rims)
One of my vintage rigs is still set up that way, and I've got almost 100# on you. You're fine with 42s
Old 09-21-22, 06:43 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1786 Post(s)
Liked 1,259 Times in 868 Posts
........ I've frame ,fork clearance ( tons) just a question of whether one would run that tire on a 22 mm ID rim ........
Make sure the brakes open wide enough too.
Bill Kapaun is offline
Old 09-21-22, 09:52 PM
oldbobcat
oldbobcat's Avatar
Quoted: 513 Post(s)
Liked 444 Times in 334 Posts
It's a disc brake bike.
But do check the clearance between the tire and the fork unicrown. From the illustration in rei.com, it looks like you might be able to go 2 mm fatter.
As you can see, there's no room for MTB tire, unless you want to replace your wheels and fork.
And to get better traction and ride, your tires will have a more purposeful tread pattern and a more supple casing, so be prepared to spend more.
I'm most familiar with Trek and Bontrager products. Here's their price-point gravel tire: https://www.trekbikes.com/us/en_US/e...olorCode=black
And this one gets you more ride and traction: https://www.trekbikes.com/us/en_US/e...olorCode=black
oldbobcat is offline
Old 09-22-22, 11:39 AM
oldbobcat
oldbobcat's Avatar
Quoted: 513 Post(s)
For better cornering out of muddy or sandy corners, look for bigger lugs on the tread shoulders. For example, here are two comparably priced Bontrager gravel tires:
The deeper, more widely spaced lugs on the bottom tire make it better suited for rough, muddy, or sandy conditions, at the expense of speed and handling on hard, smooth surfaces. I can't tell you what to buy. All I can tell you is that a fat MTB tire won't fit in your frame. FYI, an inch equals 25.4 millimeters, so a 2" MTB tire is about 51 mm. Unless your current tires leave a gap of over 1/2" to the frame all around, they won't fit.
Old 09-22-22, 03:54 PM
2ndtimeAround
Quoted: 19 Post(s)
What has happened a dozen plus times now , I log in and post a reply - when I hit "post" I find myself being logged back in and clipboard has been cleared. ( had copied the info to the clipboard). When right click and "paste" nothing there. Gets exhausting rewriting over and over again . Happening to others ?
Anyways , I am still wondering about puncture resistance of the tires I mentions and there is a "SG2" on one make. Goatheads are an issue.
I can see the wider spaced lug tires making room for goatheads to sit in there .
Old 09-22-22, 08:22 PM
oldbobcat
oldbobcat's Avatar
Quoted: 513 Post(s)
I'm being limited on my posts . I did review the tire website. Found something I like the WTB Resloute .
Did I mention I think my rim is not "tubeless ready" , so I plan to run tubes. Was planning on going conventional anyways.
That tire is a little cheaper on amazon. It appears specs a 42mm . I've frame ,fork clearance ( tons) just a question of whether one would run that tire on a 22 mm ID rim . One thing for sure will be running a fairly low PSI . 130 lbs rider, dressed.
Of course your rims aren't tubeless ready. This bike is a price-point hybrid. Two more mm of tire width isn't going to make a bit of difference on your rims. And here's the tire marked down at biketiresdirect.com. https://www.biketiresdirect.com/prod...vel-tire?fltr=
This is a standup company, I've used them before, and I recommend them even if they might be a couple bucks more than your Amazon seller. But suit yourself.
Likes For oldbobcat:
