Totally Tubular
#2351
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
It's a lot of practice.
1. Use glue instead of tape, and don't use too much (this is an experience thing).
2. Tape OR glue, leave a bare spot opposite the valve where it'll be easier to get started.
3. Thin tire iron helps a lot; both getting started and all the way around - steel works better than a Pedro's type.
Likes For DiabloScott:
#2352
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,856 Times
But I still really want to try the Corsa Speeds!!!
#2353
Bikes: many
Quoted: 1442 Post(s)
Liked 1,387 Times
genejockey Brute force works. I've yet to need to resort to tire irons too remove a tubular tire. As you've seen, adhesion to the edges goes a long way to minimizing the chance they roll off the rim.
Like DiabloScott I'm a gluesniffer user. My only experience with tape has been trying to remove it. I use paste/flux/welding brushes to apply the glue. With just a little experimentation you will quickly figure out the (light) pressure necessary to get the brush to fan out to the edges of the base tape or rim. Once installed, I pump the tire up to around 110psi to insure complete contact (edges and center).
#2354
It's MY mountain
Liked 2,977 Times
The tire ought to be damn hard, but not impossible, to get off. That's the sweet spot you need to find with experience.
I authorize buying the Corsa Speeds.
#2355
Liked 11,856 Times
New tubular guys usually hear a story about a rolled tire, and then read some article on how to glue tires, and then they use the "6-corner criterium in August" criteria, and then when it comes time to change one they have to cut it open and rip it off with a vice grip.
#2356
Yup! Only time I ever had a tubular rolled was at the registration table before a criterium. Wished he could be with me the next time I had a flat.
Likes For HM70:
#2357
Quoted: 1607 Post(s)
Liked 2,214 Times
I typically leave a bare spot opposite the valve. The result is a "ticking" sound as the glue next to the spot separates then bonds. this can happen for a few miles before it settles down. The last time I applied glue on the tire in that spot and not the rim. A bit better.
My thumbs object to much use anymore so a tire is the assist in removal. Thanks @DiabloScott for the reference for a thin one. Amazon.com : Tragoods Premium Bicycle Tire Lever Tyre Spoon Iron Changing Tool, Bike Tire Levers Premium Stainless Steel Levers to Repair Bike Tube, Best Tire Changing Tool, Set of 3 : Sports & Outdoors
Came back after reading the reviews. Not sure this item is what you would like. I have three different sets of which none are the best for tubulars. They include metal and plastic. The key is to get under the tire far enough to leverage it off the rim which is a challenge of overcoming the glued area.
#2358
Quoted: 1946 Post(s)
Liked 2,004 Times
I’ve seen guys use a single edge razor blade to remove a taped tubular tire🤔 if you can get those Giros off without destroying them, they will be good as a spare for the more delicate Corsas.
#2359
It's MY mountain
Liked 2,977 Times
#2360
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1079 Post(s)
Liked 1,802 Times
Last night while riding through the park, a gunshot rang out.
no, it did not. It was a 10-year-old tubular that blew out a side wall in the most spectacular way.
I watched two YouTube videos, both of them sounded like changing your tire was a three or four day process. I scoffed.
I started with a glue I had on hand. Tubasti, which is much more like rubber cement. Not having a paintbrush, I decided to spread it with my rubber gloved hand. Dumb idea. It basically adhered to my rubber glove.
since I have bottles of goof off, I took the glove off and just use my bare finger. It worked great. I felt like finger painting in preschool. And when I was done, a simple rubbing my hands together all of the glue balled up into a natural rubber eraser.
That soon ran out so I ran to the store to get some Vittoria Mastic’ One.
certainly not the same properties. It was goopy. And now, four hours later I still have residue on my fingers and can’t seem to get it off even though I’ve already used magic eraser and green scrubby pads.
I put a coat on the rim, I put a coat on the tire. After a couple hours of them being outside in 85° heat, I put another coat on the tire and put it in its place. Yes, I did get stuff on the side wall. I am frightened to use any chemicals to remove it lest I weaken the molecular make up of the tire so I will live with my mistakes.
The front tire is bound to blow as well at some point. So I am pre-gluing my other new tire, wrapping it in Italian newspaper, and using a Campagnolo toe clip strap to carry it under my seat.
All in all, I prefer the top one.
They (yes, they) say this is the most puncture resistant sew-up out there
Likes For Robvolz:
#2361
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,186 Times
Robvolz , I've been running Rallys on one of my bikes and been pleased with the performance. Are they as nice as $100 Vittorias? Of course not--- but a significant improvement over mid-range clinchers.
Bob
Bob
#2362
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,828 Times
With all the bikes I'm running I'm not afraid to confess a soft spot for Rally tires. The cotton casing gives a nice damped ride, imo. A new set going on a touring Rickert.
My only current comment is that I finished the last jar of mastic and converted to tubular tape lover. Having finished 4 tires with Jantex tape, what tape should I buy for the next builds??
#2363
Liked 2,004 Times
Have you changed a taped tire on the road?
#2364
Quoted: 4791 Post(s)
Liked 3,918 Times
Now I need to get spokes, build wheels and get sweet tubbies on the Pro Miyata I just set up. (What a ride! My Mooney's main triangle exactly! The rest slightly more spread out than the Fuji Pro I raced and loved but now I've got the stem and reach I should have had back then. Circa 1990, so I'm told. The heyday of steel racing bikes and it shows every ride. And suckers me into riding harder! Yes, true race bikes are faster. But it's not anything you can measure!)
So I need to find those hen's teeth, 302mm butted whatever/1.5/whatever DT? Sapim? in silver. Spent many hours getting nowhere a few weeks ago. A local shop can cut me black Sapims. Did a wheel for me but black does zero for my tastes. (For silver hubs and greybrown GP4s and silver 330s.)
#2365
Liked 3,918 Times
Couldn't you do Diablo Scott's trick of deleting one section between spoke holes at the rim seam? (Make mess of the scissors but could come in very handy in the field.) Or do you risk integrity cutting the tape so it no longer is completely stuck to itself? Disclaimer - I haven't used tape since Jantex in the mid '70s. Rolled a tire on a hot day. Next ride was on glue and I never looked back. But I hear the new stuff is much better.
#2366
Veteran, Pacifist
Liked 4,828 Times
#2367
“Senior” Member
What I know is as a tubular noob who started out with tape, the first time I had to change a tire I realized I could never do this on the road and that it took forever in the garage. So flats on the road would mean one of three choices to get home: 1) trying usually temporary or ineffective sealant which also precludes ever patching that tube later, 2) a walk, or 3) an extraction by special forces (Uber or preferably my wonderful wife).
#2368
Freewheel Medic
Liked 2,186 Times
@Wildwood I'm now a devotee of Effetto Mariposa Carogna tape. I like it that it comes in shop size rolls.
I've tried gluing, Tufo and Vittoria tapes. I recently had a broken spoke mishap with a wheel running a Rally with the Effetto tape. Obviously, I had to remove the Rally and tape to complete the repair. The tire was challenging, but removable. If I had been on a ride, I could have used the left behind tape to mount the spare for the ride home. The tape took work to remove, but came off cleanly and rim was ready for new tape and a tire with no other prep.
In my recent move I came across a set of wheels I had forgotten about. IIRC they were my last pair of glued tubulars. What a mess! And after climate-controlled storage for 4-5 years, the glue and tires seem to be seperating. My taped wheels look ready to ride.
Of course, YMMV.
Of course, YMMV.
Bob
Bob
#2369
It's MY mountain
Liked 2,977 Times
If you're using tape because it's easier and cleaner, you give up easy changes on the road... your choice.
But if you're using tape because you don't think glue is strong enough, you've heard too many rolled tire stories from folks who got in a hurry or didn't know what they were doing at all.
#2370
If I own it, I ride it
Quoted: 591 Post(s)
Liked 662 Times
I've never used tape, but this is a common complaint - it just has too much grip - very difficult to change a tire in the best of situations, damn near impossible to do it on the road.
Once I learned, I find tape tire changes are as easy as glued.
Likes For CV-6:
#2371
Quoted: 830 Post(s)
Liked 2,110 Times
@Wildwood I recently had a broken spoke mishap with a wheel running a Rally with the Effetto tape. Obviously, I had to remove the Rally and tape to complete the repair...
The only time I had to do as you describe was once I was out of town and broke a French-threaded Robergel Trois Etoiles spoke on a tubular wheel. Finding a French-threaded replacement spoke to fit the nipple was impossible. I called around every shop in the area and was repeatedly told me there was no such thing as French-threaded spokes, but I knew otherwise. Still, I did have to pull up a small bit of the tire to install a new spoke & nipple until I got home and was able to put in a matching French replacement spoke. A good reason not to tour on wheels with French-threaded spokes I suppose.
#2372
Bikes: many
Liked 1,387 Times
Ride report
I hadn't ridden my Redcay for quite some time. It was patiently hanging on a hook waiting. I took it out yesterday as a small tribute to Paul Brodek. He was my "Redcay guy," having provided the serial number decoder way back when. He was also from New Jersey where Jim Redcay spent his building years.
The bike has the NLA Veloflex Vlaanderen tires. Dang, they are like riding on pillows. I have the replacement ProTours on my Griffon. I don't think they are as nice.
At my coffee stop:
At my coffee stop:
Likes For smontanaro:
#2373
Freewheel Medic
Liked 2,186 Times
Bob, I don't see why you had to touch the tire due to the broken spoke. Why not simply remove the broken spoke, replace, and re-use the same nipple?
The original spokes seem to be unobtanium. They are straight pull, bladed, and have a unique head and 1.8mm threaded unique nipple. As best I know, the Roval nipples must be used with the Roval rims.
I've not been able to find any compatible replacements. I've attempted to modify a similar modern spoke and had success with re-shaping the head. However, it is threaded 2.0 mm. I tapped the nipple to 2.0mm but the nipple refuses to thread onto the spoke. I tried to cut new threads on the spoke, but with no luck. Frustrated, I set the project to the side in May, and have been busy moving south ever since.
Modified spoke head on left next to original Roval spoke on right.
The unique Roval nipple.
Bob
Bob
#2374
“Senior” Member
I have one with a flat to be repaired but it’s one of those not obvious leaks. No easily found source even under a magnifying class. Opened it up where the leak came out the sidewall. Nothing. Last resort which I have done before is to cut the tube and pull the whole tube, find the leak, patch it and reinstall the tube using a splice. BUT, when I opened this tube up (first time I have ever see this) they used so much glue under the seam strip it seeped inside the tire interior and made the tube stick to the casing. Could not pull the tube out. I guess I will open the tube in sections every 10 inches or so till I find the flat. What a pain.
#2375
“Senior” Member
