Why new chain with new cassette
Old 12-30-15, 04:15 PM
kenshireen
Quoted: 33 Post(s)
Why do you have to replace the chain if you are replacing a cassette.
My chain isn't stretched.
kenshireen is offline
Old 12-30-15, 04:22 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,349 Times in 856 Posts
Are you sure? Have you measured ? a New chain 1/2" pitch per link .. so 12" of chain (24 centers of pins) is 12.00"
Got a etched steel 12" ruler ? I suggest Buying one.
fietsbob is offline
Old 12-30-15, 04:32 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 640 Times in 361 Posts
However much wear your chain has, it will wear down your new cassette to that point in short order. If your chain only has a few hundred miles on it, you might not mind wearing your cassette by that amount.
Retro Grouch is offline
Old 12-30-15, 04:37 PM
HillRider
Quoted: 2025 Post(s)
Liked 1,085 Times in 733 Posts
Unless a chain has very few miles, it won't mesh properly with a new cassette cogs, particularly the smaller, most used ones. The result is it will "skip" under load. As to whether your chain is "stretched", that is most commonly measured by using a good ruler over 24 pins. A new chain should measure 12" exactly. A measurement of 12-1/16" is really marginal and 12-1/8" is the "throw both it and the cassette away" point.
HillRider is offline
maartendc
Bicycle Mechanics
7
06-02-19 01:44 PM
zhongyuan9817
Road Cycling
17
06-07-17 09:50 AM
Steve M.
Bicycle Mechanics
4
07-31-14 09:27 AM
nickp08
Road Cycling
34
05-11-12 04:27 PM
TomD77
Fifty Plus (50+)
18
10-05-11 06:46 PM
