Confused about wheels!
Apologies for the amateur question...
I bought a bike that can supposedly accommodate a 42mm tire. It came with 700x38 road tires and is very comfy around town. However, I found a local trail (light gravel) that I'd love to ride. My goal is to get a second set of wheels on which I'd mount gravel tires. I read an article on REI about wheels and I have to admit, it's over my head.
I'm looking for a dummies guide on wheels.
Here's what I can tell you:
- The bike has 700c wheels with the front one having a quick-release skewer and the rear one bolted on
- It's a single-gear bike (46T x 16T), so I don't have to worry about a derailleur
- The bike has disc brakes, so the new wheels must be disc-compatible
- I feel comfortable installing 6-bolt discs
- I can replace tubes and tires myself
What I'm confused about is hubs, cogs, and overall fit/compatibility (i.e. spacing). I looked at various wheel options on Amazon and other sites and I'm struggling to make heads or tails. I see that some wheels are for geared bicycles and some may require spacers (which I don't have experience with). I can't tell what will and will not fit. Can someone point me in the right direction please?
P.S. If it helps, following are the original wheelset specs according to the seller's website:
RIM : HJC-DA-300D 700x14Gx32H DOUBLE WALL ALLOY BLACK.
F/HUB : JY-D041DSE ALLOY BLACK W/QR. , R/HUB : JY-D244DSE ALLOY BLACK NUTTED.
SPOKE : 14G STEEL BLACK W/BRASS NIPPLE.
Thanks for the guidance.
Likes For attackontitan:
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1294 Post(s)
Liked 719 Times
What you need to determine is the dropout spacing in the fork and frame. This is the inside distance between the fork and frame dropouts where the wheel axle is inserted. The fork dropout spacing is most likely 100mm, so any wheel should fit. However, the rear could be anything from 120mm to 142mm, depending on the frame. Once you determine this, we can better assist you in finding the correct rear wheel.
Likes For TejanoTrackie:
Thanks man, appreciate it. I measured the front dropout spacing as 4" and the rear as 4-5/8". That would convert to 101.6 mm up front and 117.5 mm in the rear, but it's certainly likely that my measurements are a tiny bit off, so I'm going to go with 100 mm and 120 mm.
Veteran Racer
Liked 719 Times
I assume the rear of your bike looks something like this:
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Mustard
You should do what ever you want to do ultimately.
but in my case I would just send it on that trail. Then asses what you actually need after. Wider tires and finding the right gearing for you and that trail is where I would start.
if you really want a second set of wheels. A set of beach cruiser wheels would be cheap and easy to find and throw on some nobbie tires.
Bikes: Lugged Steel Single Speed Beater
Quoted: 41 Post(s)
Liked 167 Times
Mustard
sealed bearings are good but I’ve read on this forum enough times to consider for myself that loose ball bearings last just as long if you maintain them accordingly.
Quoted: 41 Post(s)
Liked 167 Times
PS. Besides, sealed hubs are relatively cheap (Formula, Novatech, Oigin8, etc) or as cheap as old school loose ball hubs, but in my experience, even the freshly re-packed loose ball hubs and bottom brackets I’ve assembled don’t spin like my used sealed hubs. Definitely no reason not to upgrade.
What has your experience been like with both?
Mustard
your going to use absolutes?
you can but sure won’t
my personal experience is that sealed bearings works great but take some fun out of maintaining a bikes performance. I like to be hands on therefore don’t mind the extra work.
Just to be clear my perspective of what your suggesting is to purchase a set of hubs and have them installed. I estimate those hubs are at least $30 each to your door and another $60 each to install them. Not mention the cost of spokes if the hubs have a different size flange.That’s $180 or more upgrade on a 30/40$ set of wheels. How logical that is. Is really up to the op.
Quoted: 41 Post(s)
Liked 167 Times
Mustard
inferior wheels may have better odds than you think against said slight bumps. In my experience 60 year old steel Schwinn wheels and 10 year old aluminum wheels off an Electra bc are good enough for slight bumps and in my case 20+ mph gravel runs with inches of air time.
in the end it up to the op where he puts his money and how much of it.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
700 x 38 tires are gravel tires. Lower the pressure a little and go ride it.
Likes For c_m_shooter:
Thanks man. It's been a hassle trying to find exactly the right wheel, so I might just go ahead and ride it as-is. It's not an extreme trail, so as long as I don't get a flat, I'll be able to use this bike as a dual-purpose.
