Replacing Dropout
Quoted: 3511 Post(s)
Liked 2,926 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
sometimes the frame/dropout is bent and that can't be solved with a new hanger, eh?
a Worn dropout can also cause mis-alignments.
Likes For maddog34:
Quoted: 1561 Post(s)
Liked 1,734 Times
I do agree with smd4 that typically you can bend a bent aluminum hanger back. I did that with my son's bike while I was waiting for the new hanger to arrive. It worked and I didn't even need the replacement hanger
Quoted: 4399 Post(s)
Liked 1,556 Times
Dang. I thought i just need to put the new hanger, then the rd and wheels, do some tune up and that’s it. Didn’t know i need to do alignment check. How do i align this though, would i need an alignment tool? Don’t have one. Btw the screws are bolted from the inside of the frame.
As Dedhed mentions, a rear QR wheel uses an axle of the same thread as the hanger, so you could thread a spare wheel in and see if the wheels are parallel (being careful to support the wheel's weight), or use a bare axle and get it to parallel the hub of the rear wheel.
The screws don't matter. Alignment is just bending.
You shouldn't, but many of these thin hangers and imperfectly molded dropouts don't end up straight. You can certainly just try it and see if you shifting is off. A bent hanger, not matter what direction, will cause the shifting to fail to go all the way across the range.
Anyway got a couple questions. Would a bent hanger do any harm to the wheel? This is a new set of wheels i installed recently. Also, if i decide to replace the rd later on, a Tiagra 4700 rd is compatible with a Tiagra 4600 shifter, right? Currently using 4600 shifters and derailleurs.
Liked 1,556 Times
Like what RJ the Bike Guy did? Yeah, i’ve seen him do it on youtube. Seems that could damage the thread though if one is not careful or experienced.
4600 is compatible with all the old Shimano stuff, 4700 is compatible with the 11 speed stuff. They aren't compatible with each other.
Quoted: 1109 Post(s)
Liked 1,200 Times
I agree with two things that have been written:
1 - align the new hangar, and check alignment on any bike that's been dropped or crashed, or isn't shifting perfectly
2 - get a spare. In other words, in this case, one to put on, one to keep as a spare. If they do get bent, it's not unusual for them to break when you straighten/align them
Oh, and 3 - it's called a derailleur hanger, not a drop out.
Liked 1,556 Times
A shop will do it for a minimal fee. If you want a tool for occasional, rare use, get one of the $25 ones from EBay or Amazon. They work fine for casual, occasional use, at least that's my personal experience.
If you're cheap, buy two rear axles and a couple of nuts or cones. Make one axle and nuts/cones as a dummy that will go in the dropouts using your QR. Take the other one and tighten two nuts together 1cm from the end, then turn that short end into the hanger from the inside. Now you have two axles 3cm apart that should be parallel. By eye; looking down, up and from the back; make them parallel. Done. You can probably find some beat up hubs or axles for next to free.
Liked 1,200 Times
The last shop I worked at charged $25 an alignment. By all means buy a tool.
Liked 1,556 Times
I agree with you - buy the tool and learn how to use it. But I was actually thinking of that sort of charge - $25 and it seems pretty reasonable to me, probably the minimum shop time? For someone who encounters this issue very rarely (most riders, me included with 8 well used bikes in the family) and doesn't care to amass tools (not me!), even inexpensive occasional amateur-grade ($25-$50 for a cheap one) I think the shop charge is a good deal. Double the good deal quotient if the person has no inclination or desire to do this stuff his/her self (again not me). I have one and have used it a couple of times but only once because the alignment actually functionally out and that was when I bent a hanger falling down (not really a crash). The rest was to just check things because I bought the new tool I like doing my own stuff just because it's fun and I avoid having to deal with uncertain quality and delays at the LBS. But most people have no desire to straighten hangers or buy the tool to do it, so $25 +/- is well worth it. MHO of course.
Likes For Kontact:
Liked 1,200 Times
Yeah, pretty biased sample population. Certainly apropos to the totally balled up measuring ruler vs chain checker thread. There's a good reason there's chain checkers regardless of the mechanics of chain wear.
Liked 2,926 Times
Liked 1,556 Times
It isn't. But some people seem to have very little innate handiness or 'empathy' for the machines they are working on. The kind of folks that just tighten bolts down without knowing what they do, can't hang a picture straight or turn the wrench harder when the thread doesn't go in right. In this case, replaceable hangers are often flimsy and connected to very thin carbon dropouts in a way that doesn't tolerate much fumbling. If you've never seen anyone straighten one and you don't have a good eye for making things parallel, you might find hanger straightening frustrating - especially with ad hoc tools.
So I've described how to do it with ad hoc tools, but I'm also warning that my description is for people that at least have a bit of clue about how to use tools.
Liked 2,926 Times
Of course, people should know their limitations. I can replace a light switch, but after doing that, and the light still doesn't come on, I call an electrician. Same for A/C or furnace problems. Or plumbing issues beyond cleaning a trap.
To me, aligning a derailleur hanger might be one of the simpler repairs. But if it's outside your wheelhouse, spend the $25 bucks and have it done by a shop.
Likes For smd4:
Liked 1,556 Times
Liked 2,926 Times
Liked 1,200 Times
I dont' think anyone said it is. But do you not agree that many, if not most cyclists, even very enthusiastic ones who ride a lot at a fairly high level, have not desire to do this stuff, have no knowledge how to do it, and might not even have the aptitude to do it. Heck, playing a piano isn't rocket science, but not everyone wants to or even can do it decently if they try.
This group is a very, very biased sample of cyclists and has an unrepresentative proportion of folks who want to and can do bike mechanics. And even here, there's a lot of folks who do not do any of their own work, do not want to, and probably wouldn't be good at it anyway due to lack of interest or basic mechanical experience or aptitude.
Liked 1,200 Times
The picture he showed was the bike with the existing bent hanger. He wants to replace that with a new hanger. There is generally no need to bend a new hanger.
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Likes For dedhed:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
For the doubters out there, here's a sampling of one.
It's spring cleaning and maintenance time for my backup (wet weather) bike.
I'm converting my 2018 Cervelo R3 from a genuine Cervelo "regular" hanger to a new genuine Cervelo "direct mount" hanger (DRH-SDM).
Left to right the new hanger is out of alignment twice (6mm) the shimano spec (3mm)
Top to bottom the new hanger is out of alignment three times (9mm) the Shimano spec (3mm).
For me at least, it was very worth the check.
All the best
Barry
BTW
IF you do this, remember to lightly grease & HAND tighten the hanger nut, add the wheel and torque the thru-axle, then torque the hanger nut.
All the best
Barry
BTW
