Front Derailleur Left Limit Screw connects to nothing.
I have a hybrid bike with Shimano Gears and am referring to the front derailleur, and specifically the left limit screw.
I've seen this question/issue dotted around the internet so I wanted to run this by the experts.
My Front Left Derailleur limit screw connects to nothing at all. I can't upload pictures yet.
I've just realized that this is probably because, at least on this bike, the left limit screw is not needed. The Derailleur is clamped so close to the vertical seat post tube that the internal mechanism of the derailleur which would normally allow left or right movement to set the left stop limit, is already limited by the vertical seat post tube. It looks to me like the Derailleur has been fitted this way to forcibly guarantee the correct spacing between the left derailleur guide and the chain (around 1mm or so).
The right limit screw allows for left and right movement of the Derailleur chain guide, but for the reasons explained above, the left limit screw does nothing. Even when screwed right in, it barely touches the mechanism inside the Derailleur.
Are my assumptions about this correct. Does the way this derailleur has been mounted automatically set the left derailleur guide limit in turn doing away with the need for the left limit screw?
Also, is this common practice to build bikes this way?
If you want pics, I'll have to DM them to you. This forum doesn't allow me to upload photos because I haven't made ten posts yet.
Thanks.
Thanks.
Quoted: 424 Post(s)
Liked 442 Times
I don't think it's common but it happens. I noticed it on two of my road bikes when I switched from standard 53/39 to compact 50/34 cranksets and had to lower the FD a tad.
The bike came this way and nothing has been changed on it.
Country too many videos on this topic the cable feeds into the derailleur from the top so the spring mechanism is not under spring tension when the chain is on the smallest cog furthest to the left (at the front).
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
In discussing derailleur limit screws, it's much better to use terms high/low or inner/outer than left/right.
Quoted: 4260 Post(s)
Liked 1,458 Times
It isn't by design. The derailleur is being stopped by something else - like the seat tube or cable tension. It is an example of poor frame design or incorrect part specification. Or something is bent/broken.
Quoted: 5703 Post(s)
Liked 2,433 Times
The combination of a fat seat tube and inboard crank position can create a situation where the FD fully bottoms out against itself in low. Note, either alone can cause the same issue.
In extreme conditions, it might be bad enough that good low gear trim, and or downshifting is problematic.
The fix is to move the crank out 2mm or so, if possible. Or buy a more recent FD, designed after fat seat tubes were SOP.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 6100 Post(s)
Liked 4,732 Times
That low limit screw is sort of a last resort. So is the high limit. In a perfect world, they don't need to be touching anything. They just help prevent over shifts that might drop the chain. And typically the limits are set without the cable installed on a new installation. And if they are aligned correctly don't need to be reset ever again so long as nothing else changes on the bike.
Likes For Iride01:
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Does it shift fine? If so don't' worry about it.
Quoted: 444 Post(s)
Liked 404 Times
Likes For KerryIrons:
Quoted: 444 Post(s)
Liked 404 Times
Indeed - you could probably make those work together by using a different axle or crank ... people want narrow Q factors but they want triple chainsets and they get grumpy when their heels clip the chainstays and why are there so many widths of hub and cassette? It's a never ending story of compromise and innovation and new standards and non-standard ...
Liked 1,458 Times
In the end I figured this out. Thanks for all the replies and help.
All the instructional videos show the right derailleur stop on the far right. On my bike, it's on the far left.
That's why the limit screws seemed to do nothing. I had them the wrong way around. I'm happy to say that I'm riding around now and the bike is going very well.
Likes For Dominover:
Thanks for all the replies. I eventually worked things out. My right limit screw is the one closest to the frame. On all the instructional videos it's the opposite. The bike is going very well so I appreciate all the input. I'm only learning about bikes all over again because the last time I owned one things weren't as complicated.
Quoted: 1080 Post(s)
Liked 681 Times
