Artistic Cycling anyone?
For those that don't know what artistic cycling is, here is a video:
About a month ago, I discovered the sport and was drawn to it. I like its grace, gymnastic-like moves (called figures), and ability to be done anywhere there is some flat ground. I also love the sleek and simplistic look of the bike.
Here is what a typical artistic cycling bike looks like. Note the extremely steep head tube angle, the 3 bolt reinforced seat post, the curved seat, the road cycle type handlebars, which are balanced, the 1/3 size pegs, and the tires that are very close to each other. This bike is the biggest example of twitchy I've ever seen:
As far as I know, only two companies in the world make them—one in is located in Germany, and I'm thinking the other is Germany or a neighboring country, as the sport is only really done in Europe (and a small part of Asia). The bikes typically run for about $2500 USD., which is well beyond my means.
I built the monstrosity below to be able to do some of the same tricks. The bike is a 2013 BMX Diamondback Grind 20". The brake is there only to avoid the $480 'no brakes' fine. I replaced the freewheel cog with a fixie cog and had it welded in place.
The 45 degree stem will be replaced with an adjustable stem riser that is able to go straight up (90 deg.), thus keeping the handlebars more vertically in line with the tire, as an artistic cycling bike should be. The new stem (which is currently being shipped to me) is below. It was extremely difficult to find one that fit my needs (90 deg., 25.4mm handlebars, ability to insert a curved bar...):
Anyone have an artistic cycling bike? Any ideas or suggestions?
Likes For bedtime:
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times
I have been intrigued with artistic cycling for quite a while. The key to become any good at it is to first become really, really really proficient on a unicycle first. Since I am a framebuilder, I could build a artistic cycling bike myself. A few problems that I see: A) how does the stem work??? Does not appear to be a quill stem, or an a-head stem. B. Regulation bikes are suppose to use a 1 to1 gear ratio. I don't know how to do that on a fixed gear bike. Maybe use an ATB crank, and use a 22t chainring, to a 22 tooth track/ fixed gear thread on cog?? I don't know if you have studied the geometry, but the bottom bracket/ crank height is really, really high (even with the wheel axles) I mean 13" plus, I would feel as though it would much safer to have the cranks lower. (<11").
Likes For Brian25:
Quoted: 282 Post(s)
Liked 18 Times
Oh, I read your post again. The reason that the artistic cyclists use a non offset stem, is that when they spin the handlebars, they are the same regardless to which way they are when they stop spinning, and need to grab them again.
That aside, I won't be getting a true artistic cycling bike anytime soon, but I will be getting a bike that is as close to it as possible. Below is a bike that would cost me $200. It's not perfect, but it is as close as I've seen to matching such a bike.
Pros:
- close tires
- single speed fixie
- road tires
- head angle looks quite steep (though not as steep as a true artistic cycle); it's definitely not slack, at least
- peddles low to ground
- back tire close to saddle tube
Cons:
- unthreaded stem. As you mentioned, it will be more difficult to find a zero reach stem to use with this bike
- aluminum frame. Not sure how well it'll live up to crashes
- I'm quite sure that the tires are bottom of the barrel and will need to be replaced
Some other possibilities (all cost around $200 CDN.):
Damco:
Critical:
Has threaded stem at least, aside from that, it's a garbage bike.
This bike below was made in England (likely the best quality of the bunch?):
So, I'm looking for ideas as to which would be the best choice. I'm liking the look and frame of the orange bike the best so far.
I've got the bike, and it's at a 1:2 gearing. Good enough for many tricks but will need to be lower as you said. The bike has a vertical dropout, so it's not easy finding a chain link with the perfect tension.
Artistic bike
I have an artistic bike. You can message me if you need help with anything
Funny, I don't usually visit this forum but youtube showed me the below video and I was like, I wonder if those guys talk about this, and here we are hah
Trackstand game is so strong, it's funny that you've got your hardcore messenger types or whatever, track racers, and then these pretty girls in some olympic type sport, fixed gear is awesome across the board
