What is your preferred jockey wheel size?
Quoted: 529 Post(s)
Liked 255 Times
What is your preferred derailleur jockey wheel size?
Do you think it matters? Or is any size OK?
Quoted: 6934 Post(s)
Liked 10,940 Times
Round.
And yes, size does matter, but that’s a separate issue.
Likes For Koyote:
Expired Member
Quoted: 3654 Post(s)
Liked 5,391 Times
Buy a decent derailleur and it will come with the correct size pulleys. You may have more significant issues to ponder.
Likes For shelbyfv:
Quoted: 4385 Post(s)
Liked 4,827 Times
Quoted: 1943 Post(s)
Liked 2,164 Times
I like my blue bullseye for the lower wheel. Still using centeron upper wheel.
John
Edit added: I think it is 10t.
John
Quoted: 6177 Post(s)
Liked 4,794 Times
If I'm loosing performance because of the size of my Jockey wheel, then I'm not good enough yet to determine that. And most certainly there are more things that will give me more benefits that I should worry about before that.
SE Wis
Quoted: 2740 Post(s)
Liked 3,387 Times
Whatever they came with from the factory. Honestly never counted them, nor do I plan to.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Standard size, whatever that is.
Likes For cxwrench:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
A better question might be "what is your favorite jockey wheel color?"
I choose basic black, as it goes with everything.
Likes For Phil_gretz:
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Quoted: 18397 Post(s)
Liked 15,492 Times
On a related topic - what adverse effect comes from a worn tension pulley? Obviously, a worn guide pulley does negatively affect shifting precision and speed. But I suspect that with the tension pulley, given it spins freely and there is no play in the bearing, there shouldn't be much difference up until it is worn near round.
Am I wrong in thinking this?
Quoted: 4790 Post(s)
Liked 3,917 Times
That said, I don't do index so I could be wrong about the new (and now ubiquitous) systems.
Liked 2,944 Times
prefer the ones that are marked clearly for orientation, don't make noise, & don't harbor gunk. Not a fan of riveted in place ones either.
-Oh Hey!
-Oh Hey!
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
You can buy a nice complete bike for $1700
Liked 2,944 Times
Likes For Troul:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Kogel sells larger ones that fit the OEM cage on the newer Shimano "R" series of RD's. I think you can go up to 12/14 on the factory cage. Like $150 on sale.
I went that route as I'm a TT nut and a half watt is a half watt more than I can train more for. Bigger reason was to go "matchy matchy" on gold chain and gold pulleys. The half a watt is whatever.
Liked 15,492 Times
Likes For indyfabz:
Quoted: 3241 Post(s)
Liked 2,512 Times
Horsing around with aftermarket jockey wheels might not be a good idea. I don't know if they void warranties or not.
Expired Member
Liked 5,391 Times
Likes For shelbyfv:
Zip tie Karen
Liked 1,542 Times
Most times, changing out derailleur pulleys is simply chasing after the wind. Replacing a worn or cracked one is fine, though.
Sr Member on Sr bikes
It depends on what size of jockey tire I want use on the jockey wheel.
Dan
Dan
Likes For _ForceD_:
Liked 15,492 Times
Likes For indyfabz:
Liked 2,512 Times
Liked 2,944 Times
