Cable Frame Grommets
Just call me Chris
I have a 2007 Kestrel RT700 (essentially the same as the RT800 & RT900 that followed). I am in search of the frame cable grommets that corrode and disintegrate over time. I had a stash but that is used up. The local Trek Bike shop has given up in their search. Does anyone know of old parts warehouse, know someone who might make it work or know of a hack to make it work? The bike shop is not willing to hack something up (they still have the bike, I get back tomorrow). I seem to recall that the frame shape was pretty common back in that day (sharing of molds in Taiwan?) and looks very similar to some of Motebecanes on BikesDirect.
Kestrel has not responded...
Any thoughts or leads are welcome. These pictures are of the grommet in question...
Grommets at top
Grommets at top
Sr Member on Sr bikes
Just “spit ballin’” here…but if you can’t find them…I wonder if that is something that could be created on a 3D printer.
Dan
Dan
Likes For _ForceD_:
Quoted: 2975 Post(s)
Liked 1,181 Times
Don't people use google to search anymore?
https://www.google.com/search?client...frame+grommets
Or how about Amazon?
https://www.amazon.com/s?k=bike+cabl...f=nb_sb_noss_2
Likes For prj71:
Just call me Chris
Quoted: 1438 Post(s)
Liked 1,092 Times
Maybe get yourself some Sugru and make some yourself? https://sugru.com/
Likes For dsbrantjr:
Quoted: 2604 Post(s)
Liked 1,928 Times
Just call me Chris
As an update, I have had much time to work on this due to life events, but have learned it appears the same grommets were used on the RT800/900/1000. I have also found Specialized parts on Performance Bike that are similar. The shop I took my bike to, which has converted to a Trek Bike Shop, tried a Trek part but is a bit too large. Also, the Kestrel part has bolt connection to the frame prior to the cable entrance which can be seen in the image above. The Trek part looks like the Ebay/Amazon parts.
Still no answer from Kestrel...
Just call me Chris
Kestrel RT900 frame cable grommets
jcbenten
Were you able to find any frame cable grommets for your Kestrel RT700?
I have a Kestrel RT900 with same corroded grommets and have not been able to find any at bike shops, online, or through Kestrel.
If you have found some, please let me know where.
Or, if you somehow obtained a stash of them, I would be grateful to buy a few off of you if that works for you.
If not, I will CAD them up and 3D print them in MJF and/or aluminum.
Just call me Chris
boby
I was able to pick one up from Bikes Direct...which is where I purchased the bike originally. (Cost $15 but also got a flask.....i.e., he forced a purchase of a flask and threw in the grommet. Although he did not say that up front...just quoted $15 for the grommet...I did not ask if he had more).
I even contacted Steven Harad (Kestrel Prod Mgr at the time) with a response but no luck. He had sent my original stash years ago. Tried contacting Preston Sandusky (Frame designer for the RT700) who currently works for Ibis but he did not respond. The ones who own Kestrel are not responding...although the brand looks to be gone for good. I had a friend, who teaches HS Physics, take one for a few months to try and build one on a 3D printer but he and his students never got around to it. I think this is the way to go. If you get ever get it modeled and printed, you now have a very niche business. Make the damn thing out of Titanium or Zirconium. I have been through at least a half dozen over the years. I have the bike up for sale, all fixed up, in the Austin area. If you ever get it 3D modeled, and I end up keeping the bike, I may be calling you.
Quoted: 2026 Post(s)
Liked 1,096 Times
I've never owned a bike using this type of grommet but what are they made of that they are so fragile you need a "stash" of replacements?
Just call me Chris
Seems to be a very low density metal matrix that corrodes from water and salt. Even moisture in the atomosphere. Mine have turned greenish/black but not always. Seems to be too light for copper compound so I think some type of Aluminum...cheap sintering process. If they were solid probably last longer but it almost like a foam. They look like plastic (ABS or similar) but are not.
Kestrel frame cable grommet
I just sent Bikesdirect an email and will also start on the 3D print route tonight.
3D printing might take a couple of iterations to get the geometry just right.
Frame Cable Grommet
jcbenton
Bikesdirect was able to send sent me qty 1 of the Kestrel RT900 Frame cable grommets (along with a flask - LOL).
I reverse engineered/designed it and should have several of them 3D printed by Wednesday.
For material, I am starting with MJF nylon. Many other bikes use cable grommets that are plastic.
MJF gets fairly close to as as molded strength and nylon is good for corrosion resistance so I am thinking it should be good.
I will get more of them printed once I prove out it is working as hoped for.
Let me know if you want some.
Just call me Chris
jcbenton
PS- Sorry it took me so long to respond...I am JCBENTEN (no "o" and so no notification.
I had one silly "mirrored/reversed" mistake on the strain relief tail on my first 3D print design but everything did fit.
I should have "fixed" 3D printed parts by Tuesday Nov 7 and then I will rerun the cable and see how it shifts.
How does 10 of them sound?
I should only be reimbursed for shipping as I can not do this for profit. It would be a conflict of interest.
Just call me Chris
I PM'ed you. Thanks Boby!
