Cannondale Optimo 1x conversion questions
Old 01-17-22, 03:59 AM
toksuede
Hello everyone. Please bear with me as I'm no expert.
So, I decided to get the Cannondale 2021 Optimo 1 with 105 groupset. As it was my intention, I want to make it into a 1x. It comes with a 50-34 / 11-30. The BCD on the FSA Gossamer crank is 110.
I currently ride a BMC Alpenchallenge Sora 9 speed with 50-34 and 11-32T. I only ride on the 50 and I don't use the top gear. I am also planning to ride this in Berlin and thereabouts and we have no hills to speak of.
Therefore I went to the trusty gear configurator to figure which chainring I will need and came to the conclusion that 46 paired with the stock 11-30 will get me fast enough on the top gear.
Here is the question. I want to get the oval chainring from Wolftooth, but the FSA Gossamer crank that comes stock with the Optimo does not have an option for a 46.
Therefore I need to get a new crank. Should I get the 105 crank or a GRX crank? Would the BCD still be the same 110 if I switch to a new crank?
Any advice will be very much appreciated.
toksuede is offline
Old 01-17-22, 07:12 AM
shelbyfv
shelbyfv's Avatar
Quoted: 2970 Post(s)
Liked 3,752 Times in 1,930 Posts
Of the two, only the GRX is available as single ring, 40t or 42t. If you intend to swap chainrings, keep in mind that Shimano 110 spacing is unique, not the same as traditional 110. Hope this helps.
shelbyfv is offline
Old 01-18-22, 05:09 AM
toksuede
Thanks. I went with the 42t from Wolftooth, combined with the stock crank and not the GRX/105.
Hopefully that will be okay. Will email Cannondale about the clearance between the frame and the new chainring.
toksuede is offline
Likes For toksuede:
Old 01-18-22, 10:09 AM
msu2001la
msu2001la's Avatar
Quoted: 896 Post(s)
Liked 869 Times in 501 Posts
I run a 1x Raceface 42T narrow/wide ring on an FSA Gossamer crank, on a Cannondale CAADX that originally had 2x 105 (but now has SRAM Force 1x).
It works perfectly. The only complication I ran into was needing new bolts for the chainring, as the bolts that attached the 2x ring were longer than the bolts needed to attach a 1x ring.
msu2001la is offline
Old 01-20-22, 04:26 AM
toksuede
That sounds great. How is the ride? Is your cassette similar to my ratio? Any tips on getting the chainline correct? So far I've managed to get all the parts for the upgrade except for shoes. Since I have wide feet, I am doing a shotgun approach and ordering as many shoes as I can and will test them to see which one will fit.
toksuede is offline
