SRAM AXS 56/43 dimensions related issue
meow
Bikes: 2016 Parlee Altum, 2013 Cannondale Super Six Evo Hi Mod Di2 only, 2011 Cannondale Super Six, Dura Ace 7800, 2007 Cannondale System Six Dura Ace 7800, 1992 Bridgestone RB-1, MB-2, MB-3, MB-5
I have a Parlee Altum rim frame in small, Di2 (6870) that I run with a Shimano 7800 56/39 chainrings (and with an 11-xx cassette in the back). It fits fine, and works totally fine. Zero issues whatsoever.
I am curious about SRAM's AXS 56-43 with a 10-xx cassette in the back. However, because the Shimano 7800 with the 56t big ring fits/works fine with the 6870 front der, is it reasonable to assume that the SRAM AXS 56/43 with its crank, and front der will fit/work fine?
I do know for the SRAM 56/43 that the upper fixation bolt height is 162.5, and the lower fixation bolt height is 154.5 (center of BB to center of fixation bolt on fd). Sure, I could remove my 7800 crank, and then measure as best I can -- I don't have a super-precise measuring device (but could get one) -- the distance from the middle of the BB to the middle of the bolt. But, before doing that, thought I'd ask here for your expert thoughts, such as
- if the Shimano 7800 56t works, then sure, the SRAM 56t big ring should work fine, or
- yup, I've seen SRAM 56t big ring on an altum, and it works fine, or,
- it depends, here are some other factors that need to be considered....
I'm also happy to be pointed in the direction of specs that would help me assess things before I buy parts.
Thank you.
Thank you.
