Frame sizing on vintage bikes
Quoted: 161 Post(s)
Liked 267 Times
My recently purchased Schwinn VSP is a fun ride. Nimble with nothing in the bags, yet planted and comfortable when the bags are filled with groceries. It is a 21”, 21.5” top tube, 170mm cranks, 74 degree head/seat and 27” wheels. With the amount of stem and seatpost showing, it looks like the frame is too small for me, but when I bought the bike I also tried a 23” version and it was too big for me. My nice bike is 56/56, 73/73 with 650b and it fits quite nicely and looks proportionate.
I’m trying to figure out why this bike looks small though it fits perfectly the way it is set up. Would a dirtdrop stem make the bike look more proportional?
ambulatory senior
Quoted: 1954 Post(s)
Liked 3,658 Times
Looks pretty good to me. If you want the 23" your stand over might be too much. Personally I don't worry about stand over but it's not a bad thing to be aware of. If that works for you and you have enough stem insertion I think you're golden.
Likes For 52telecaster:
Quoted: 1557 Post(s)
Liked 1,732 Times
People typically eyeball frame sizes by looking at the headtube length. But on a bike like this- there is a huge amount of air space between the fork crown and the top of the tire. So the fork is longer and the head tube shorter, and that makes the frame look like it's a size smaller than it is.
But to answer your question- yes a 90 degree (or more) stem would look better in this situation.
Likes For icemilkcoffee:
Quoted: 3498 Post(s)
Liked 2,911 Times
Looks OK to me. The stem is up high, but that isn't an indicator of proper frame size; more like a comfort thing. Seatpost is right there in the range.
Likes For smd4:
Quoted: 1946 Post(s)
Liked 2,004 Times
Why do you think the 23” version is too big? Was it too tall or too long? By how much?
I’d say that if you need that much stem to get the bars where you want them, AND you have an opportunity to get the next larger size, get the next larger size.
Likes For Classtime:
Quoted: 161 Post(s)
Liked 267 Times
The 23” hurt. It pressed on my taint. Plus I bought this while on vacation, so I’m nowhere near the bike. The 23” was only a few dollars less and nowhere in as good of condition.
Likes For Lbxpdx:
ambulatory senior
Liked 3,658 Times
With that info I'd say you bought the right bike. All my stems are pretty high. It's an arthritis thing and I don't care what people think!
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
You like it so thats all that matters.
Back in the day, bikes tended to the bigger size seat tube wise. I remember the Varsity in the early. 1970s coming in 22, 24. and 24 inch frame size. Typical was about one hand width worth of seat post showing. I was sized to a medium, 24 inch. Now I am comfortable on a 21 1/2 inch. Sold my 24 inch bike years ago.
I like dirt drop style stems for comfort too. Its one reason I am attracted to the drop bar conversion on a rigid frame MTB.
Likes For wrk101:
Quoted: 3804 Post(s)
Liked 6,643 Times
With that short of a head tube, looks more like a 19” frame than a 21”.
Likes For nlerner:
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
You must be about my size. The bikes which fit me best are the Bianchi, the Carlton, and the three Capos, all of which are 55cm C-T. The UO-8 is a 21-incher, but proportionally long in the top tube.
1959 Capo with Nervar Star crank and Campag. 980 derailleur upgrades and new Brooks Pro saddle.
Likes For John E:
Quoted: 5888 Post(s)
Liked 3,471 Times
That bike looks on the small side to me given how high the bars are. That said, it seems to work for you. I hope you have enough of the stem inserted into the head tube for that to be safe. You are running a Nitto technomic stem (or a tall stem from a different manufacturer), right
Likes For bikemig:
Liked 2,911 Times
Quoted: 161 Post(s)
Liked 267 Times
Liked 3,471 Times
You're kidding right? Did you bother to read the rest of my post? If the OP is happy with that set up, who cares right as long as the stem has sufficient insertion.
I dunno about what kind of expertise you may have but I worked in a bike shop selling and fitting bikes throughout the 80s. . . .
Likes For bikemig:
Liked 2,004 Times
Do the Voyageur SPs have high BB? That is the only way taint pressure can occur with so much seat post showing.
ps: I’m a pretty good internet fitter given woefully imperfect information.
Quoted: 3464 Post(s)
Liked 2,827 Times
I would need to see the rider on the bike
Liked 2,911 Times
If the rider gets proper leg extension with the saddle at that level, it’s not too small at all.
Worked as a wrench, also selling and fitting, 10 years, 1985-1995.
Likes For smd4:
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
Do manufacturers still make some sort of rando handle bars? The kind that allow a couple of centimeter height to the bars relative to the stem? I am sure there is a proper name for those. Just an idea.
Your frame size looks correct. A 23 could be very challenging.
Liked 3,471 Times
I did read the rest of your post. That was all well and good. Obviously, I took issue with your assertion that the stem length had anything to do with proper frame sizing.
Likes For bikemig:
Likes For Steel Charlie:
Quoted: 2480 Post(s)
Liked 2,948 Times
Frame angles of 74 degees parallel for a 21" touring bike? Seems unlikely. That's '80s Italian criterium bike/track bike territory.
Likes For Trakhak:
I agree with Steel Charlie. I would address the seat first by leveling it. That would also require adjusting seat height. Then the reach to the bars would be improved allowing the rider to drop the stem further into the head tube. This set up looks very uncomfortable and the bar position is compensating for poor saddle position.
Quoted: 4225 Post(s)
Liked 2,945 Times
I have to agree that it looks like that saddle angle would be uncomfortable for me and everything else might change if that did. On the other hand, if that saddle angle works for you, go for it.
