how fast do these bikes go ?
Liked 759 Times
I used to be a 17-18 mph rider on my old Trek road bike. That was for 'pretty flat' centuries with around 1300 feet of climbing, and drafting other, stronger riders like a madman.
Now I have a lowracer and I typically do around 20-21 mph on century rides, no drafting required. That's rolling average; I rarely do centuries for elapsed time - rides are an excuse to eat! The last century I did for elapsed time, I did it in 4:38. As for max speeds on flat ground, I've been clocked at 39 mph. I should add that I still have an upright bike, and my speeds on that have actually gone down over the years; so I can't blame it all on being in better shape.
I started riding a Sun EZ Sport CX with a Mueller fairing in Sept. 1, 2006. I typically rode 11-12 mph on my mountain bike. I started at 11 mph in September on the EZ Sport and now ride 13-15 mph and it is increasing slowly over time. Last Friday, I rode 53 miles at 13.5 mph. I could never have done that on my mountain bike. As your legs build and you lose weight, the speed goes up. I have lost 25 pounds since September. That helps quite a bit.
Bikes: Actionbent Suspended Road Runner, Optima Baron, Rans Tailwind
15 to 17 on the flat and 67 years old. Couldn't come anywhere close to that on an upwrong. (Couldn't last long enough to get an average!)
BTW, I think Jeff-o forgot to mention that his average is on THREE wheels! Right?
...........jim
...........jim
Eschew Obfuscation
Bikes: 2005 Fuji Professional, 2002 Lemond Zurich, Folders - Strida, Merc, Dahon, Downtube, Recumbent folder
I am a roadie who just got 'bent. It's reassuring for me to read about improvements when converting because I'm frustrated that I can't go as fast on my 'bent (yet). I got to get my 'bent muscles up to speed and get used to the heavier bike. So tell me more about how I'm going to slice through the wind and sprint up the hills on the recumbent .
Recumbent Ninja
My last century was 4:45min in over 100 degree heat. I'm pretty close to BlazingPedals in speed. That same century (the only one I've been clocked on) my average for the first 60 miles was 22.7, and it dropped off after that. One that same ride, there was one stretch of brans new pavement, totally flat, where my 10-mile average was 33mph.
I was shooting for time though so that's not my "normal" pace - just what I am capable of. I'll usually cruise in the 18 range - that tends to be fairly easy in Texas.
Super Modest
Bikes: Trek Domane+, Trek Emonda, Giant Propel, Colnago V3, ICE VTX WC
Liked 5,156 Times
Some of you guys are pretty fast. My fastest century last summer was 5:10 (100.4 miles) total elapsed time including all stops and about 80% solo. That was on a Baron. FWIW, I'm 55 and 60# overweight, so yeah, I'm faster on a recumbent than an upright.
Keep the chain tight!
Super Modest
Liked 5,156 Times
Not to go off-topic, but aikigreg, did you ever get your M5?
Liked 759 Times
A 5-hour century is a respectable goal. I started riding bents with a goal of 2.5 hours for a 50 miler. That took a couple of years to attain, which I did by way of fairings. I never managed a 5 hour century on the old V-Rex, although I had some good 50-60 mile rides that were easily on-pace. The real breakthrough happened when I got my lowracer. I imagine that a highracer would also do the trick, but a 'standard' bent would require more training and improvement than I could manage. Of course, adding more hills will drop your averages no matter what you ride. I have lots of small hills, but no major climbs or steep grades.
shaken, not stirred.
Bikes: I've lost count.
Liked 1,083 Times
I wish I was fast.
Gee, I wish I was as fast as everyone else. According to my log on bikejournal.com I am averaging between 12-16mph. That is mainly commuting with lots of stop-start and some other rides with some small but steep hills. I have done 29mph on the flat, and then I just run out of lungs. I am just an unfit commuter, but I am faster than I was on my old DF beater.
Eschew Obfuscation
Just out of curiousity, how much does your lowracer weigh? My high racer is 37 lbs and I think that's part of my problem....
Originally Posted by SesameCrunch
Blazing:
Super Modest
Liked 5,156 Times
Low racers can vary from ~18# (VK2 and SL-II) to ~32# (stock Barons, steel M5s).
My Fujin SL-II weighs 21# with pad and pedals. My Baron the same way is ~27#. In my flat part of the world, my SL-II has little advantage over my Baron as far as speed goes. In fact, my fastest century has been on my Baron.
Eschew Obfuscation
Originally Posted by Ric
I don't know about BP's Lowracer but my Bacchetta weighes in at 26 to 27 lbs. What High Racer do you ride at 37 lbs or is that loaded down with gear?
Should I be concerned about doing a double century on 20" wheels with front suspension?
Liked 759 Times
The last time I weighed my Baron was when it still had a fiberglass seat and caliper brakes. It was 27 pounds. Since then I've converted to disc brakes and replaced the fiberglass seat with carbon. The carbon seat is lighter but the brakes are heavier, so overall it's probably still about the same weight as before.
I am new to 'bents, and I have a converted full suspension mountain bike using a kit from cruzbike.com. I am now thinking I should put that kit on a 20" folder I have. That would get the weight down to the high 20's and get me some better performance, perhaps at the sacrifice of comfort. I'm not a racer, but I do like to do fast recreational rides as opposed to slow touring pace. Also, I live in the SF Bay Area. It's hard to find a ride without climbs, so weight is a big deal here.
Eschew Obfuscation
I'd like too know why you chose to do the conversion instead of just buying a recumbent.
I had the bike and used it doing all the crazy things mountain bikers do. Well, 6 weeks ago, I had a bad accident on it - fractured my neck, injured my shoulder. Got helicoptered out, spent 2 days in an ICU. Also, the MRI's showed degenerative condition in my neck. Had a lot of time in the hospital to think, and decided to give up mtb-ing (at age 51, it's about time). The Cruzbike allowed me to exact some poetic justice on the bike that tried to kill me. I neutered and turned it into a recumbent , which was better for my neck.
I like the Cruzbike setup overall. The FWD is very intriguing and offers some bio-mechanical advantages. I think it makes for a nice touring setup - comfortable for long range cruising. However, you're right, the combination of the full suspension bike, plus the 9 lbs that Cruzbike adds add up to a heavy bike. I have too many hills around here for that. My own riding style is more sporty recreational. I do like to go fast. So, what I have decided to do is to take the Cruzbike kit off the mtb and put it onto my Downtube folding bike. This would give me a 27/28 pound 20" mid-racer. Plus, I think I can preserve some of the folding features. Gonna get working on that asap. Oh boy, another bike build project !
Sorry for the major thread hijack. I'll start another one on the folder conversion.
Recumbent Evangelist
Bikes: Rebel Cycles Trike, Trek 7500FX
...........jim
...........jim
Recumbent Ninja
I'm also considering having a full shell made for the bike so I can compete in the streamliner classes as well.
"Yup, three wheels... and a front fairing."
Seriously? OK, I've just been looking at two-wheeled bents assuming that trikes were God awful slow. Obviously I've misjudged the trikes. I think I'll be staying on thread by asking.......How fast are trikes in relation to two-wheelers?
But the rolling resistance of a 3rd wheel is very noticeable, especially compared to a 2-wheel bent. Sure, 2-wheel bents are faster, but with a trike, you're bringing a chair whereever you're going.
I also have a HP Velotechnik Grasshopper, and I love it just as much.
They're just two different beasts with different ways of being enjoyed.
Yep, it's true. Between a comparable trike and 2-wheel bent, the 2-wheeler will usually be faster, simply because of the reduced weight, frontal area, and rolling resistance. It all depends on what the trike was designed for...
Super Modest
Liked 5,156 Times
Originally Posted by aikigreg
Not yet - Bram still has the durned thing and is taking his sweet time getting it together. And once it gets shipped to Garrie, it'll take more time yet since Garrie is building me some goodies to go with it. It's supposed to be slightly sub-20 pounds from Bram, and will have his innovative brakes as well. I expect it to be right at that or even less once Garrie gets done - he's adding wheel covers and a carbon front boom.
