Am I just too heavy to go fast?
I have been riding quite a bit for over a year, can ride for distance no problem, but I just can't seem to go fast. I had a too heavy hybrid, and could never get above 22/23 miles per hour. Got rid of it, got a road bike, and can't get above that speed! I'm just too heavy, right? I weigh about 245 when according to my height I should be about 190.
Throw the stick!!!!
Sounds like you just need to ride more. It all comes down to power/weight ratio so as you get stronger you will get faster. To give you an idea I'm 5' 10", a couple months ago at 220+ I averaged over 20 mph solo on a 60 mile ride with around 3,000 feet of climbing.
I may be fat but I'm slow enough to make up for it.
Liked 3,111 Times
On the flats, weight isn't really an impediment to going fast. In fact the fastest TT'ers and sprinters tend to be big muscular guys. That's because on the flat, the relevant metric is power to frontal area. In the hills, it's power to weight.
I'd say keep riding, and throw in some interval work. Look at the sticky called BF Workout Cookbook at the top of the racing subforum. All sorts of ways to make yourself hurt in there.
Portland Fred
The good news is that even if you're not in shape, you'll still be faster than the skinny guys when going downhill
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
Con forza e velocitŕ
Bikes: Spesh S-Works - Tarmac SL4, Spesh S-Works Venge, BMC Team Machine SLR01, Spesh Allez - FrankenForza
When started riding in 2009, I struggled on 20+ mile group rides @ a 16-17 mph pace. I worked my way up to being able to hang onto the 20mph pace by the end of the season. In a sprint, I still only topped out in the 25-26 mph range.
This season (i.e. now) I can hold onto a 24mph paceline for a pretty good distance and not feel like I'm going to die. In a well led out sprint, I can brush up to nearly 35mph. Of course I can't hold it there for very long, but it's far faster than I could hit last year. At the beginning of this year I weighed ~210lbs. Since then I've dropped 50+ lbs. I definitely attribute part of my increase in speed to not having to lug around that excess flab.
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Liked 5,760 Times
caloso has the ticket. Sprint intervals build power and cardio stuff too. Go all out and then recover. Repeat til you puke or feel like you will.
The advice about spinning faster is good if you concentrate on a really smooth circular spin. To my way of thinking a you feel a good spin equally in both legs at all points in the revolution. This should be smooth and easy enough you don't huff and puff @ about 90 to 110 rpm. If you're bouncing around in the saddle you need to adjust your seat height. If you can find a nice long flat for this it's ideal.
Oh, climb every hill you can find. Often.
Yes but here we're not talking about the size difference in a Contador and a Cancellara. The "big muscular guys" who eat up time trials still aren't anywhere near 245. Most aren't even 190. Thor is considered big by cycling standards and I doubt he hits 180 when it comes Tour time. I went from 225 to 166 (where I am now) and I promise you 166 me is way faster on any terrain than 225 me.
yes, you are heavy, I'm about your sized and similar performance though as it's gotten later in the year I feel so much more powerful going up hills whereas earlier in the year they were a struggle. considering I'm an avid golfer and don't ride nearly as much as many others here do (i do btw 200-250 miles a month in the warm weather months and almost no riding in the winter other than my commuting miles) I'm fine with it, but i know even as a heavyweight I could still train myself to go a lot faster based on training i've done for other sports. I used to run a 4.7 40 yard dash at 6'3" 235lbs so i'm no slouch, just not trained on the bike and I enjoy the long endurance type rides anyways.
Bikes: Salsa Vaya, Fuji Aloha, Giant OCR2, an older Giant XTC, and a couple of singlespeeds
To the OP - do you do any (leg) weight lifting? That, as well as the sprint intervals mentioned above, should help a lot. I'm wondering if working on your cadence might help too - but that seem to require more info on the gearing your are using as well.
Hills hurt.. Couches kill
Bikes: 1991 Specialized Sirrus Triple, 2010 Trek Madone 6.5 Project One, 2012 Cannondale Caad10, 2013 Trek Crockett
Going fast on the flats is about power/aero drag or Watts/CdA. In your case losing weight would make you more efficient by not having to fling around extra dead weight on your legs but more importantly losing your gut will allow you to achieve a more aerodynamic position and greater speed.
I would forget about intervals and sprint training and focus on long steady rides and limiting your food intake. If you drop 50 lbs and lower your riding position, without doing any special training I guarantee you will be much faster.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
as one of my cycling coaches said, "lose weight."
not all of us that weigh 240 have that much weight we can easily lose. i'm 6'3" 240 18% bodyfat. If i got down to 12% body fat I'd still weigh around 225. My real problem is that I have a torn ACL in my left knee so that limits the strength i have in that leg. i got into biking as a way to keep that leg healthy since I don't have insurance. With all the money i've spent on bikes in the past 18 months, I probably could have had knee surgery but I wouldn't have had as much fun!
On your right
Bikes: Specialized Roubaix Elite
OP asked what he needed to go faster. I remember when Davis Phinney catabolized (under a doctor's supervision) a bunch of muscle mass so that he could be a GC contestant in the old Coors Classic (which he won). It is possible to remake your body if you want to go fast on a bike, but it's not necessary if all you want to do is have fun.
I'd say about 30 or so in spurts, and be able to ride steadily at the 22/23 mph pace that is killing me right now.
I definitely know more about how to go about this than when I began the thread, thank you for all the replies.
