budget trainers
budget trainers
Old 12-10-12, 08:35 AM
bonz50
Bikes: 2013 Synapse 4
Quoted: 70 Post(s)
budget trainers
right after the holidays i'm going to pick up a trainer, i have, for budget reasons, set my upper limit at $200 (lower would be a bit better). this puts most of the fluid trainers out of reach it seems.
any experiences with some reasonable priced trainers that are worthwhile??
bonz50 is offline
Old 12-10-12, 08:39 AM
canam73
Quoted: 11 Post(s)
Liked 5 Times in 2 Posts
How are you aiming to use it, as in what type of work outs, how long, how often?
canam73 is offline
Old 12-10-12, 08:41 AM
bonz50
Quoted: 70 Post(s)
a few times per week so I don't totally lose myself over winter. probably in the ballpark of 3-4hrs per week.
bonz50 is offline
Old 12-10-12, 08:43 AM
simonaway427
Bikes: 2010 S1, 2011 F75X
You'll be able to find a used Kinetic for 200 - don't skimp on a trainer, especially if you plan on getting any real results from it.
simonaway427 is offline
Old 12-10-12, 08:46 AM
seymour1910
seymour1910's Avatar
Quoted: 5 Post(s)
Liked 6 Times in 4 Posts
Most will tell you Kurt or Cycleops, but if you are not looking for that much and don't want to spend the coin you can consider used. Personally I use a Blackburn trainer and have no issues, it does what I need it to do. Also, I have heard good things about the Travel Trac fluid trainer from performance. More advanced cyclist or wannabe racers won't go for it but for what you are looking for it should be fine.
https://www.performancebike.com/bikes..._400006_400037
seymour1910 is offline
Old 12-10-12, 08:47 AM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 15575 Post(s)
Liked 3,528 Times in 1,763 Posts
Have you considered rollers? You can get an inexpensive set for $100-150, that's what I use.
Addiction is all about class.
datlas is offline
Old 12-10-12, 08:55 AM
gsteinb
out walking the earth
gsteinb's Avatar
Quoted: 891 Post(s)
Liked 698 Times in 322 Posts
when it comes to trainers you really get what you pay for. Cheaper units have a less realistic feel, and they seem to gather dust quicker. A good trainer is generally money well spent. If you're going to buy rollers that curve is a bit more forgiving, but if you're going to go with a real wheel fixed trained consider the kurt kinetic even though it's out of your set budget, or at least be sure to test whatever you're going to buy first.
gsteinb is offline
Old 12-10-12, 08:59 AM
Ultraslide
Ultraslide's Avatar
Bikes: 73 Raleigh Supercourse, 99 Specialized Stumpjumer, 08 LeMond Tourmalet
Rollers are great for improving your pedal stroke and balance but they lack the ability to do high force, low cadence reps because of the lack of resistance. It is also very difficult to do an out of the saddle sprint or climbing effort on rollers. Ideally you'd have both roller and a trainer but if you are a casual cyclist and not a racer I'd say the Performance fluid trainer would be fine. The Cycleops Fluid 2 and Kurt Kinetic Road Machine are best of breed trainers and are easy to find on Ebay in the $250ish range, sometimes cheaper.
Ultraslide is offline
coasting
Still can't climb
Quoted: 12 Post(s)
Liked 3 Times in 3 Posts
my tacx trainer lasted about 3 weeks 2 winters ago.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
coasting is offline
Old 12-10-12, 09:01 AM
gsteinb
gsteinb's Avatar
Quoted: 891 Post(s)
That's really not correct. Many rollers come with resistance units.
gsteinb is offline
Ultraslide
Ultraslide's Avatar
For $200?
Old 12-10-12, 09:02 AM
bonz50
Quoted: 70 Post(s)
a riding buddy of mine has a fluid 2 he swears by, looks like i'm gonna have to demo a couple and see.
bonz50 is offline
Old 12-10-12, 09:05 AM
gsteinb
gsteinb's Avatar
Quoted: 891 Post(s)
dunno, but minoura rollers can't be far off that. I've had a set for twenty years that I still use to warm up at races, and I bet performance and/or nashbar hit that category near that price point.
gsteinb is offline
seymour1910
Quoted: 5 Post(s)
How many different ones does your LBS carry? Will they let you test them?
If you have a performance store close to you I know they do in store demos.
Old 12-10-12, 09:13 AM
topflightpro
topflightpro's Avatar
Quoted: 1797 Post(s)
Liked 581 Times in 364 Posts
I would not suggestion you buy this Travel Trac fluid trainer: https://www.performancebike.com/bikes..._400006_400037
I think it is a horrible piece of crap. Riding the trainer is rarely enjoyable. Riding a horrible trainer like this is even worse.
Stick with CycleOps or Kurt Kinetic if you can.
topflightpro is offline
Old 12-10-12, 09:16 AM
bonz50
Quoted: 70 Post(s)
got my bike at a local perf bike, but the other lbs's in the area have a variety of brands.
bonz50 is offline
Old 12-10-12, 10:02 AM
jkuper
jkuper's Avatar
Bikes: Yes
You can definitely find a used CycleOps for sub 200 and Kinetic for not much more. Check ebay, CL, etc.
jkuper is offline
Old 12-10-12, 10:34 AM
svtmike
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
I tried the budget trainer route -- a couple of the higher end budget trainers at Performance -- before getting my Kurt Kinetic. I would use them for one winter, with the resistance progressively getting higher all winter until the trainer was unusable. Thankfully Performance has a great return policy and I was able to just turn it in for a new one, and finally for a full refund when I got tired of the annual return game.
I bought the KK three years ago and it's been great -- trouble free and consistent. If you watch carefully for them on sale, you can get one for around $230. You should definitely be able to get one used for under $200.
svtmike is offline
Old 12-10-12, 10:48 AM
bonz50
Quoted: 70 Post(s)
mag or fluid??
bonz50 is offline
Old 12-10-12, 10:57 AM
svtmike
I believe the budget trainers were mag. The KK is always fluid.
svtmike is offline
Old 12-10-12, 11:04 AM
canam73
Quoted: 11 Post(s)
Uh, no. The KK Road Machine and Rock and Roll are fluid and are the models most people talk about. But KK does also make wind and mag trainers.
canam73 is offline
Old 12-10-12, 11:05 AM
NRZ
HTFU and ride outside.
NRZ is offline
Old 12-10-12, 11:09 AM
svtmike
Well what do you know. I've never seen anything but a Road Machine or Rock and Roll in the wild.
I have a Road Machine.
svtmike is offline
Old 12-10-12, 11:11 AM
svtmike
If you do it right, the trainer is the true HTFU method. Training (not just riding) outside in the freezing cold and winter conditions is for the birds.
svtmike is offline
Old 12-10-12, 11:12 AM
vwchad
vwchad's Avatar
Bikes: 2013 Focus Izalco Pro, Soma Grand Randonneur
Craigslist is your friend. I picked up a fluid trainer for $30 that is like new. Don't remember the brand, but it works well for me.
vwchad is offline
