New stem for Kilo, help please?
Bikes: Mercier Kilo TT 2013, custom BMX 2010-2012, Vintage Fuji fixed-gear conversion 1978, vintage fuji sports 12 1986, Bianchi XL ev2 2001
Hello all,
This is a really dumb question, I know that. EVEN SO... please bear with me.
I received Cinelli MASH bullhorns for Xmas and when I tried switching out the Cinellis with the stock drops, as I predicted would happen, the Cinellis didn't fit the stem. I obviously need a new one (and I was already planning on getting a new stem anyway) so what should I get? Or... is there anything I can do to salvage the old stem? Also, can you tell me the measurements for everything? Thanks.
Fixie Infamous
My pro came 1 inch no shim.
Maybe my mind's become fuzzy, as I replaced my stem at the LBS as soon as I got the bike back in October 2011. I vaguely recall seeing a shim left on the steerer when I lifted the stock stem off, but eh, OP will find out soon enough.
Bikes: AristoNYC's PedalRoom
Liked 6 Times
You need a stem with a 31.8mm clamp. Because Kilo forks are 1" threadless (and it's tough to find 1" threadless stems having a 31.8 clamp), you will need to buy a 1 1/8" stem and use a shim.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Liked 8 Times
Funny, there seem to be few problems that someone hasn't made a solution for. That doesn't mean the solution is available and worth buying, but ...
