Addiction 2021.3
#451
Mostly Harmless
Bikes: Have two wheels
Quoted: 13794 Post(s)
Liked 4,635 Times
#453
Bikes: Shmikes
Quoted: 10234 Post(s)
Liked 5,958 Times
We have video phones here and I once started a morning call with a mid-level admin person while shirtless. Fortunately, she took it in stride.
Likes For MoAlpha:
#454
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Tree trimmer showed up yesterday. $2800.00 later.
Hopefully, the contractor will come and remove the landscaping soon. Since I'm pushing the mower, I'd rather not cut around all that junk.
Likes For ls01:
#455
Quoted: 9682 Post(s)
Liked 6,405 Times
#456
So it is
Quoted: 11485 Post(s)
Liked 4,887 Times
Likes For LAJ:
#457
he said member
Bikes: yes please
Liked 1,951 Times
Also, on the way home from work yesterday, the Avalanche developed a vibration in the front end. Also seemed to be struggling in local traffic, like I was pulling an invisible parachute. Once home I could smell the brake lining and boiled fluid. Hung drivers caliper. The Lazer thermometer read 475 degrees after 10 minutes of cooling time. No Tuesday night ride again for 4 weeks in a row. The folks that did ride got caught in a pretty bad T-storm.
I need to make a pressure bleeder for bleeding it's brakes. It's almost impossible to get all the air out of the system with gravity bleeding.
Luckily I knew it was coming when the passenger side did it, and already had the replacement part on hand,, plus a quart of new fluid.
Oddly, it never rained @ my place.
#458
he said member
Bikes: yes please
Liked 1,951 Times
#459
Bikes: Shmikes
Liked 5,958 Times
#460
he said member
Bikes: yes please
Liked 1,951 Times
Think next week I'm going to pull the gutter guard, and clean the gutters out.
#461
Liked 6,405 Times
#462
Liked 6,405 Times
#463
he said member
Bikes: yes please
Liked 1,951 Times
#464
Liked 6,405 Times
He's "my guy." I'm not letting him get away.
#465
Quoted: 18589 Post(s)
Liked 16,075 Times
Likes For indyfabz:
#466
Fat n slow
Quoted: 3266 Post(s)
Liked 2,100 Times
I just got quotes on a couple of pines, one of them is on my neighbor's property but significantly overhangs my house, that one is $3K, the other is in the back of my property on the wood line, that one is $500 it's amazing how much proximity to a house changes things.
#467
Liked 6,405 Times
Back in about 2000, we built a house, and when it was done started on the pool. There were three big Elm trees in the back where the pool was going that had to come out. The pool company said, "We got this." I said, "Don't let those trees fall on the house."
Later that day, I got a call from the wife. Two things happened that day. You know the first. The second was that the guy taking down the trees ran over my then 2 year old son's ball and popped it. Not sure which one caused more tears.
#468
Quoted: 10309 Post(s)
Liked 5,279 Times
If it's 11 speed compatible, it will have a 1.8mm spacer on the freehub. If that spacer is not there, an 11 speed cassette won't fit on there without modification.
https://www.youtube.com/watch?v=cazQt5oleo4
thanks!
#469
Klaatu..Verata..Necktie?
Quoted: 10639 Post(s)
Liked 12,289 Times
And that's even without mentioning that when I hit the top of Leith Hill and started the descent, I spun up to 45 virtual mph and a noise started, at a buzzing that got louder and louder. I looked at the flywheel on the Kickr Snap, and one of those tape chevrons was coming loose and hitting the base, and maybe the floor, every time it went around, and it was going around REALLY FAST! I thought maybe I could press it back down by pushing it back down with a cloth, starting from the 'stuck down' side and moving across, but the whole thing just came off. I don't know whether those are decorative or functional, but everything seemed fine the rest of the ride.
#470
Liked 6,405 Times
#471
Administrator
Quoted: 12035 Post(s)
Liked 6,817 Times
Too fast for you?
#472
Fat n slow
Liked 2,100 Times
Can't just let the stuff fall on a house.
We're pushing the neighbors pretty hard to have the pine on their property dropped. It's probably in the neighborhood of 110 feet tall and would do some serious damage if it came down.
#474
Administrator
Liked 6,817 Times
So I dropped him and went with a guy charging just $800. Fine, quality work.
#475
Mostly Harmless
Liked 4,635 Times
