For the love of English 3 speeds...
Quoted: 1299 Post(s)
Liked 103 Times
I've been using marine grease because I've found rust inside wheel bearings while working on old neglected bikes. Marine grease supposedly had additives that protect against moisture. I have no idea of how effective it is at this. I take them at their word.
Bikes: 1973 Raleigh Sports, 1964 Raleigh Sports (Canadian?), 1969 Triumph Ladies, 70's Columbia Sports III, 07 Diamondback Venom
Quoted: 83 Post(s)
Will do sir, ill let ya know the outcome.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 445 Times
Thanks for showing me those shifters there Kinda cool, they would be noticeable "bling" that I am not familiar with on these English 3-speed type bikes.
So are those shifters the what would be originally equipped on the 67'-68' Dunelt 5-speed model?
Does that shifter set mount on the handlebar neck?
Do they need there own specific cables?
I did see that same shifter set on ebay for $35 today that is a reachable price.
I heard they may be troublesome but original equip. would be my preference. The bike has no other aftermarket with the exception of the brake cables. I am told/suggested the SA 3-speed standard trigger shifter will work just fine for left shift function on the.
I still need to deal with a bellcrank cable that appears a larger threaded thumb adjuster barrel than the 3-speed side of the hub.
Does anyone know off hand the thread spec for the bellcrank cable/lever?
I also stumbled across a bellcrank on ebay and it was $88....Thats a lot.
Attachment 582673
Attachment 582673
The decals are original so it hasn't been modified.
I'm jealous...
Bikes: Raleigh Sports
Quoted: 202 Post(s)
Those gouges will cause a stress point weaken starting at the void gouged in the tube to crack eventually. The good thing is you will feel it weaken before a catastrophic failure occurs. You have options of welding the bigger voids up that will maybe solve the problem although the structural integrity of the solid tube will never be the same.
If you are a easy rider you may never have a problem doing nothing to address the cuts. I know you really want to polish that rust off there.
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 378 Post(s)
Liked 905 Times
Correct - one of the few places you can grease an old-type Sturmey internal gear hub is at the bearings and in the bearing dust caps. The grease acts as a seal to keep oil in and to reduce oil leakage all over the rear wheel. You want oil in the transmission portion of the hub, grease in the outer bearings and dust caps. Even with good grease seals, it may leak a little oil. Just wipe it up is all.
The hub bearings are not picky about grease for the most part. A decent lithium (garage/home) grease will work. Garage/home synthetics work as well. I use a green synthetic by Lucas Oil, but used regular lithium grease as well for years. Avoid a "sticky" grease that actually increases resistance is all.
It's possible to run the hubs entirely without bearing grease, and just to keep oiling them. The bearings effectively run on just the oil, and this is fine. But it is very messy, and you'll go through more oil.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Quoted: 202 Post(s)
Who is this fella?
Who is this guy stamped on the left crank arm I on a bike assume is a Phillips But I found the same stamping on the Dunelt handlbar clamp.
Is this Phillips himself or is it Dunelt?
Quoted: 202 Post(s)
Liked 103 Times
Dunelt was bought out by Raleigh around 1950. This bike is badged Dunelt but was built by Raleigh in Nottingham. The little man is Sir Walter Raleigh.
Raleigh bough out a lot of their competition and continued making bikes with their badges. Phillips was later, around 1960. That's why you'll hear people talk about things like a
pre Raleigh Phillips. Meaning a Phillips made at the Birmingham factory before the Raleigh buy out.
Liked 445 Times
Super Superbes/ A Terrific Trio
A collection of three
Front to back
English built 1972
Canadian built 1976
English modified 1961
Front to back
English built 1972
Canadian built 1976
Gee @gster
You put the really interesting one in the back! I want to find one of those 61 Raleighs with the white striping and headbadge.
Liked 103 Times
Now that I have the green Sports sorted and it was a totally impractical restore, I'm going to try my hand at cold setting the old fork. I've never had a problem like this before, so it will be fun to learn something new. If it goes well, I'll report back. If I mess it up...well, I'll forget I mentioned it.
Liked 103 Times
Gee @gster
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,451 Times
No, no, and I did not mean to imply that. It's just that for those of us who love and respect the language, and who really read what's written, such gaffes are cringeworthy and we sometimes come off as martinets when pointing out the misuse we see. And I tell you frankly, it's getting tougher every day to face a page of text with what we've come to expect. I won't go off on a rant, but I will admit it's possible to both peddle and pedal a bicycle. A salesman peddles it and the rider pedals it.
Quoted: 887 Post(s)
Liked 335 Times
Liked 2,451 Times
I'm sure spellcheck plays a significant part but it's possible to correct such a correction if you know what you're looking at, and if you care.
Liked 445 Times
Gee @gster
I did spruce it up a bit today with the addition of some nice new MKS pedals...
Sorry, I meant petals.
Liked 445 Times
Quoted: 515 Post(s)
Liked 167 Times
Liked 445 Times
The bicycle accessory peddler pedalled to the park where he peddled his pedals amongst the petals.
Hopefully that clears things up a bit.
Quoted: 83 Post(s)
I know it's not from England BUT I landed a early 70's Columbia Sports III 3 speed today complete with speedo for $25
Quoted: 83 Post(s)
Quoted: 949 Post(s)
Liked 3,045 Times
Finished most of the build a little while ago. Jumped on for a quick neighborhood tear. Great fit and a blast to ride! Still a few adjustments till I get things just the way I want them. The pedal on the left is indeed wonky so I will go to my back up ones. The grips are not the ones I want to use but are the only ones close enough for now. Brakes are a little noisy but are new so will hear how they go after a few rides. I love the Carradice but not the size. Thinking I might want to work up a metal bike toolbox that was put out by ESGE. Will also begin saving for some CR18 rims to build a second wheelset for SS riding.
Backstory... tomorrow we drive out of town to drop the Son off at his Grandparents. This in preparation for my Wife's full knee replacement on Monday. After that... my life will be spent as nurse, cook, errand boy, apptment driver, schoolteacher and anything else that comes my way.
It will be awhile before I get some good miles on this Scorcher.
