For the love of English 3 speeds...
Liked 167 Times
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Liked 620 Times
While at a Sports/ Bicycle(Giant) shop in a neighbouring town this morning, I spied these in an old drawer while looking for a brake hanger for centre pull brakes. I picked up some tubes and pedals and the springs were thrown in for free. Looks like a lifetime supply of both SA and Shimano pawl springs. Must be more than a 100.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Bikes: Raleigh Sports
Thinking about it the sprocket is a larger diameter but the chain only wraps around half of it.
So my my link per cog theory could be flawed.
I did change a crank from 46 to 48 tooth recently and it needed 2 links pressed in.
This particular chain had 1/2 links where the masterlink joins that look like this.
Left to right is first a half link , then a masterlink w/link, then link, pins & plates.
boattail71
Bikes: Too many to list. Raleigh carbon racer (17 lbs.) and fast to a '37 Columbia (17 lbs. wheels alone) Even an Aerocycle (not ridable yet), love the middleweights too.
They were made with either a curved upper down tube (called a "loop" frame or "crescent") or a straight upper down tube, what most would call a typical ladies' frame, probably in 20" or 22" but I'm not certain about that. I'm sure a Tourist pro will chime in with specifics.
boattail71
So, I did go out last weekend to pick up this tall frame, as well as a box of assorted useful parts.
Attachment 604833
Turned out to be a stalled project bike. The young owner had trouble with the cotters and moved on to a 1962 Glider 3 speed instead. His Glider inherited the hub from the Robin Hood and I, in turn have the '62 hub.
His '62 turned out quite nice and he'll send me some photos which I'll post.
I'll post some shots this weekend and update the progress.
BTW, I managed to get the cotters out with a couple of good whacks..
Attachment 604833
Sorry for my ignorance
[QUOTE=boattail71;20249035]What is a "Glider?"
Sorry for my ignorance[/QumUOTE]The chain case is vinyl fabric on Holland dutch sucks sjob for chain cover sucks. I meant it. Yes I am continuyion. derilliom.ciramic disicetirorum
boattail71
Phyllo-buster
Liked 2,069 Times
Sorry Glider is a Raleigh rebrand, distributed in Canada by The T. Eaton Department chain. Pretty much clones of the Raleigh line from the 60's on. The Glider name goes further back than Eatons Raleigh though, I had a twin bar beauty that was probably pre-war and was a Birmingham bike. No pics, but it happened.
boattail71
--Ignorant but trying.
Liked 167 Times
Western Flyer? Were some of those made in England? I always thought they were all built in the U.S.?
Yet another candidate for a cotter press!
If you whack them out, you run the risk of damaging the bearing cups, bearings and bottom bracket axle, the crank arm(s), plus the cotters themselves. If your whack is unsuccessful, drilling might become the only option, and the resulting damage to the axle can be heartbreaking- they are not that common any more. The original cotters are usually much harder than the new ones you find these days, and if your bike has the 'Raleigh nuts' retaining the cotters, they probably won't be usable with a replacement.[...]
The first ones I had to drill out after having smashed them attempting removal. Even with the press, I've found it tough to remove the old cotters without bending them. I've ended up drilling a couple sets. I am fortunate in having a drill press which makes it easier, but it's still sort of an adventure with the drill press quill rotating in close proximity to the chain ring. Anyway, if they must be drilled, it's not too bad. A 6mm or 1/4" bit will find the softer material of the cotter and won't damage the spindle. That's my experience, anyway.
Cheap cotters can be had, but the R nuts won't work on them -- or any new cotter, as far as I know. The cotter material is really quite soft and easy to file. Just file them to about the profile that bikesmith shows for Raleigh cotters and if they press in about the same amount on both sides, well, Bob's your uncle.
If you're trying to save the old cotters, I've found that applying heat helps. Put the press on and crank it down so there's a bit of force on it but not enough to bend anything and while the press is in place, heat that puppy up with a heat gun and it's likely to come free.
Bikes: 1969 Raleigh Sports, 1980 Lotus Excelle
I made a cotter press from a top beam clamp and an old machine nut. I put the nut on the back side of the cotter to give it a space to go as the clamp is putting the pressure on the cotter. Works great!
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
Thanks, Club. So Gliders are not common here in the States. Yes? Hence my ignorance as a life-long Coloradoan. I'll try to be happy with my limited knowledge of my shy English stable including Raleigh, Hercules, Robin Hood, and Western Flyer (Norman), and I think I have a Sun somewhere. Regardless, I'll try to glide over arcane brands I'm likely not gonna see anytime soon. Logic appreciable? Gliding info is appreciable of course - don't wanna sound callus. Thanks all! And keep informing me/us.
And another
[ATTACH]27vxgmf.jpg[/ATTACH]
Liked 445 Times
here's a recent glider project of mine
Attachment 604942
and another
[attach]Attachment 604944[/attach]
Attachment 604942
and another
Using the inflation calculator, $31.50 in 1933 works out to $588.00 today.
After my first adventure trying to extract original cotters from an old Raleigh Sports I bought a cotter press from the BikeSmith guy. It's a bit older design than his current, but works fine. I hart my cotter press.
Will be replacing a stripped AW hub axle (early 70s) with a NOS one. A kit of replacement parts came with four axle washers, the ones that prevent the axle rotating in the slot in the dropout. Two pair, slightly different in size and detail. Anyone know the reasons for the two different types? For different hub models?
Look:
https://www.sheldonbrown.com/harris/...her-parts.html
I think you are talking about part #20 Part# HMW155 and HMW494.
Liked 620 Times
Bikes are okay, I guess.
Liked 2,452 Times
boattail71
I have a men's/women's Norman built Western Flyer purchased new by my folks in 1958 from a Western Auto in Wyoming. The men's bike has the much maligned Sturmey SW hub. I also have a more common US made Western Flyer one-speed probably built by Murray.
Yes, two different anti-rotation washers. One is like HMW155. The other doesn't show in Sheldon's list, the tabs that fit in the dropout slot are straight, not curvy, and the washer's outside diameter is slightly bigger. But they fit the same size slot and axle. I could use either but HMW155 is a snugger fit. My real confusion was whether both sets are supposed to be used, one inside the dropouts, the other on the outside. But now I think no--either type could go inside or outside the dropout, but if used on the inside, I'd want to have a plain flatwasher under the axle nut. (The photo shows the difference.)
Ha! I don't think it will make a big difference which I use. Just glad I found a NOS axle so I'm not clapping on another old clapped out one. Just for the record, I love the English bikes with these 3-speed hubs and it bothers me to see so many unappreciated, abandoned here on the sidewalk, getting beat up by the elements until eventually there's nothing left. The open frame (girls) models especially get no respect. Also I'm glad after all these years to have an excuse to rebuild one. I've never tried that before.
