For the love of English 3 speeds...
Quoted: 1299 Post(s)
Liked 103 Times
The lists of serial numbers you'll find isn't very reliable. Many anomalies. We can find a reasonably close date with frame features, graphics and accessories. That information was gathered by catalog pictures and Sturmey Archer hub dates on known examples. So not perfect, but pretty close. I can see from the shape of the steering tube lug front that the frame is 1955 or later. I think I can see a bit of the joint from the steering tube lug and top tube enough to see a shape that is 1957 or later. The next frame feature in the timeline would be the shifter cable guide wheel. Is it brazed onto the top tube or clamped on the seat tube? All through the 50s, the wheel had a mount brazed on the top tube. Then around 1960-1961, they changed to using a clamp on steel wheel with a gray finish and 2 piece band. Somewhere around 63 they changed to a plastic wheel with a one piece band. Also around that time, they eliminated the oil port in the bottom bracket and the full chaincase mounting lug on the drive side chainstay. The fork is a bit less conclusive. Safe to say that if it has the bullet shaped ends where the dropouts are brazed in, it would be 1964 or later.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,451 Times
Here's a Hercules with a little extra muscle.
https://richmond.craigslist.org/bik/...561867664.html
1970's Hercules motor bike 3spd - $300 (Goochland)
70's model Hercules 3spd hub and Bike Bug motor. Bike and motor appears all original and very low usage. Inside of tank looks like brand new. I got it running and riding but will need a rubber grommet for the gas tank and the original tires are dry rotted but hold air, parts available from bike bug online. Ate oh 4-8seven4-6994 text or call and leave vm
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 445 Times
Major Tree Failure Toronto
A BIG limb broke off last night landing on the garage
during the ice/wind storm.
Vintage bikes and cars are all OK.
Missed the shed which has 7 bikes inside...
Liked 103 Times
I see you have a ladder up. Me, I'd wait until the snow was off that shed roof before I started to limb that tree out. Not much pitch on the roof, but still, slippery snow on a roof puts me off on chainsawing.
Liked 445 Times
Thanks
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 614 Times
Close call there @gster ! We have a lot of small stuff down here in Port Dover this morning but nothing big came down. Other than the sump pump running almost continuously we (and the bikes) are doing fine. Nasty storm.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Liked 445 Times
Liked 2,451 Times
During the PO's tenure our garage was hit by lightning, the neighbors tell us. Quite a show, evidently.
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 276 Times
Just got my hands on an alloy Stumey Archer FM 4-speed hub from 1956 with matching 4-speed shifter. I'll probably have to take it apart and spend some time finding a 40-hole wheel that fits the bike but it looks like I'll be turning my Gazelle Superlicht into a clubman racer.
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
Another gripe about my '74 Sports. The OEM Brake calipers are soft and bendable. The pads keep catching in the seatstay when applying the brake. Good thing I have a '67 Hercules. I'll end up swapping everything over in time. I really like the 23" frame of the Sports. Fits me perfectly, but the quality of the 67 is of no question.
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
While researching some ideas for a custom cycling cap, it occured to me that it'd be fun to put some classic-styled Raleigh decals on my drop-bar 3-speed, which is built on a 2008 Raleigh One-Way frame. The question is, what style exactly? I'm a big fan of the old script logos (1930s style like on Tourist chaincases, and also the style seen on some 1970s bikes), and I feel like the build has a bit of "Clubman" style to it. Thoughts, anyone?
Bikes: Raleigh Sports
Quoted: 202 Post(s)
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
Big Chief posted a tutorial on fixing a bent crank a while back.
I followed his advice and was able to straighten a bent crank last year.
Attachment 607452
I used a pipe lined with cardboard to straighten the crank on this ’61 Superbe.
https://threespeedmania.wordpress.co...ider-progress/
Big Chief says:
“The best check is to put the pedal back and test ride, but you can save some time by holding a spare crank arm against the one you’re adjusting. When the light between the two arms is symmetrical like this, you’re close. This arm was badly bent. I took this picture before I did the test ride and it was spot on. No wobble. Didn’t need any further bending.”
Attachment 607453
Attachment 607452
Big Chief says:
Attachment 607453
It's amazing what you can do with a length of pipe - I watched a bike mechanic fix the curve of one of the fork blades from my DL-1 with a piece of pipe. It's one of the bike tools on my 'must get' list
Glad you and your vintage mechanicals survived. I once left the house and returned to a tree in my driveway right where my car had been.
Liked 445 Times
Thanks Gster, that checking against another crank for straightness reminded me, as the bend in mine was closest to the pedal end, I used a right angle square to check against the pedal.
Quoted: 350 Post(s)
Liked 24 Times
As kids our bikes would fall over--all by themselves!--and the cranks would get pushed in. Eddie at the bike shop had a big notched crowbar he'd use to pry them straight again. Then he'd tell us to get lost.
Liked 445 Times
The fact that they get bent in the first place suggests that they can be re-set.
Overdoing projects
Quoted: 786 Post(s)
Liked 1,269 Times
All I have been able to find are the Velocity Dyad 700C @ 525 gram and the Velocity Cliff Hanger 650B @ 600 gram in 40 hole vs the CR-18s 440 gram.
Then again, I believe the bike has 700C wheels + fenders with plenty of space so the Dyad probably makes more sense. Just curious what else is available.
Liked 103 Times
Sun CR-18 in 40H 590 are still for sale on Amazon. I hope they're not out of production.
https://www.amazon.com/CR-18-40-hole.../dp/B001CJVGOM
Overdoing projects
Quoted: 786 Post(s)
Liked 1,269 Times
From Santucci-cycles:
Sun CR-18 Rim. Sun has unfortunately decided to discontinue the CR18 and we have acquired the last known stock. Once sold out, we won't get anymore. Webshop stock is current. a truly beautiful and inexpensive double-walled rim for vintage or touring builds. Available with 32 or 36 holes.
@gster - Wow. Sorry about your tree falling. Glad to hear you, your family as well as your structure and bikes are all ok.
What kind of tree was that? Was it healthy? What you gonna do with the wood?
Quoted: 7391 Post(s)
Liked 2,546 Times
@agmetal, I would go with the early 1960s style decals with the large capital letters.
Quoted: 350 Post(s)
Liked 24 Times
HarrisCyclery also has them but Sun's own website doesn't show them in 40H anymore.
Quoted: 351 Post(s)
Liked 614 Times
How about this style @agmetal ? In the white of course.
