For the love of English 3 speeds...
Old Boy
Quoted: 985 Post(s)
Liked 1,716 Times
3-Speed Super Course, In-Process
The building didn't stop in my shop when Spring came this year. It slowed down a bit, but I had this project in the queue that needed dry ground outside so I could soda-blast the frame.
Here is what I started with:
The fork, fresh from soda-blasting:
I was surprised at the poor quality of the chrome plating under the paint. There were bubbles or pockmarks of some kind in the finish, which were hidden by the original paint.
Then I set to work with the rattle-can Rust-Oleum in Hunter Green and Almond Creme. Yes, this is a similar paint job to my Raysport Light Roadster, but the darker green on this one gives a more dramatic contrast.
The compound-curve, bamboo fenders work out really well with this color scheme.
These are only preliminary, test-ride/adjustment shots. The bike still needs a chainguard and proper cable-clips to replace the black zip-ties on there at the moment. Also, that's not the saddlebag that I will use on the finished project. It's just carrying the extra tube and flat-kit for these early rides. Another view:
I'm running a later model Sturmey-Archer AW hub on this bike. The one without an oil port. I've been draining and lubricating this one through the axle... Is that the correct procedure? Seems to work...
It will be complete in plenty of time for the ABCE (All British Cycling Event) in September. Depending on how it performs on longer rides, I may even ride this on next year's Lake Pepin Tour.
USMC 1981-1991 Semper Fi!
Bikes: Raleigh Sports
Quoted: 202 Post(s)
This popped up for $50. If I here back I am running over.
https://minneapolis.craigslist.org/h...621568343.html
Quoted: 1299 Post(s)
Liked 103 Times
Liked 103 Times
okay... so i tear apart the AWC coaster hub. Only problem so far is one ball bearing missing from left side retainer.
i dont understand how oil doesnt just leak all out?
and when oil leak out thru the bearing...isnt it washing the grease off of the bearings?
so like if you doing touring long distance...seems like you would need to add oil every day?
Quoted: 202 Post(s)
I have to blow the budget again at $75 for this one.
https://minneapolis.craigslist.org/r...601393020.html
Quoted: 331 Post(s)
Liked 333 Times
I've found that oil does leak out if you add too much. Which is a good thing if you're bringing a bike back on the road after a long time. It doesn't take much oil to keep things wet in the hub. It tends to spread around and last a long time. A few drops at the start of each season seems to work for me. I take mine apart every 5 years or so to regrease the bearings and there always is a nice thin coat of oil on the works and doesn't seem to degrade the grease on the bearings much.In fact, it might help it from drying out.
Liked 103 Times
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 614 Times
I have no problem with the left/rear brakes on my 1958 Sun Cresta and agree with @BigChief that they do look good.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Quoted: 202 Post(s)
Quoted: 202 Post(s)
Another nice one. Pre TI too. Again, English brake routing. Odd, most of the old 3 speeds I see here in New England except for rod brakes models were set up for right/rear operation. Personally, I like the look of the English style routing. The cables make a nice cross in front. Neater looking I think and I don't have any problem riding with them that way.
do is look at have
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
TI is a company called Tube Investments that owned some of the other Brit brands of bikes before purchasing Raleigh in 1960. They There's probably more thorough info out there, but it's explained in this Wiki article: https://en.wikipedia.org/wiki/Raleigh_Bicycle_Company
I like the earlier curve of Raleigh forks, like the curve on johnnyspags latest black step-through - I wonder if this is a pre-TI thing too? I don't know when they changed the curve.
Edit to add: maybe the fork curve is random? Sirweighsatonne has the curve I'm talking about, curvy all the way through to the drop-outs. Later forks seemed to have a sharper curve and then a straight just before the drop-outs. But Sirweighsatonne is a 70's DL-1 ?
Quoted: 202 Post(s)
got him
Quoted: 149 Post(s)
Liked 30 Times
Quoted: 149 Post(s)
Liked 30 Times
I've seen this colour scheme before and I really like it - black rims & tyres, dark green frame - looks great and like the cream in there too.
What kind of handlebars are you using? They look comfy. I have some that are very similar and would like to get hold of a 2nd for another bike. I find that handlebars for me make such a big difference to a comfortable bike. I think I must have about 10 spares at the moment from my quest for comfort. And on the roadworthy bikes I have different bars for different bikes.
Quoted: 149 Post(s)
Liked 30 Times
Quoted: 351 Post(s)
Liked 614 Times
Old Boy
Quoted: 985 Post(s)
Liked 1,716 Times
The blackwall tires were a happy accident. I originally ordered Panaracer Paselas in 700c x 32 with the tan sidewall, but when I went to mount them, the first one had a slit in it, like it was nicked with a box cutter somewhere. So I pulled these down from the wall and mounted them instead. I might keep them on there, and maybe replace them with blackwall Paselas when they wear out. That color scheme works.
Quoted: 149 Post(s)
Liked 30 Times
The handlebar is easy: Velo Orange Milan. I use these on bikes that I want to ride with a bit of forward lean.
Still kicking.
The dunelt is coming along nicely.
Appreciate the old bikes more than the new.
Liked 103 Times
This Rudge project is fun. Lots of stuff to fix. Right now I'm considering how to touch up the old cloth cable housing covers. They are in pretty decent shape, but there are a few frayed spots. Just need something to glue the fibers together and stick to the steel housing.
Quoted: 149 Post(s)
Liked 30 Times
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 445 Times
Someone told me to use the blue....
Liked 103 Times
I saved that link in case you lost it.
cloth cable
Quoted: 3831 Post(s)
Liked 6,846 Times
Perhaps a few coats of clear shellac would fix up those cloth cable housings?
