For the love of English 3 speeds...
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 614 Times
I wondered why a new shifter cable came with a full length housing when both my bikes run the housing just a short way to a fulcrum stop at the front of the bike. I see this bike has the housing run to the rear of the bike and no pulley. Is there any advantage? Because when I eventually set up my Peugeot mixte conversion, I could do it either way (but I won't need a pulley as the long diagonal tubes allow the shift cable to go straight to the dropout).
bikes intended for the Canadian market came with the full length cable and no pulley in the early seventies. I did is this way simply because it came that way and felt no need to change it. I have a '71 Robin Hood the same way and have rebuilt various Raleigh built variants like Supercycles that used the full cable.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 445 Times
It would appear that a lot of
I think it looks better and as stated, probably performs better.
I just cut and modify the new replacement cables to suit.
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
That's what I did when I installed the new cable on my step thru and I wondered why the long housing and didn't actually get it until now.
Quoted: 351 Post(s)
Liked 614 Times
Quoted: 1299 Post(s)
Liked 103 Times
Yeah, there's a whole bunch of different aftermarket cables out there for various bikes with 3 speed hubs. Different cable and housing lengths. Some with ball end ferrules, some with threaded ferrules. Some of them have crimped on ends that are too fat to fit properly into the shifters and can be stuck when you try to remove them. The newer ones have cast on ends that fit nicely in the shifter and plain ends intended for pinch bolt adapters to connect to the indicator pin.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 704 Times
Loose bearing assembly at factory ????
I am doing bearing lube on a 64. Reassembly of the bottom bracket with the loose balls was fairly easily accomplished with laying the bike on one side, and dropping the balls into the fixed cup loaded with grease, and etc, etc, etc for head etc, etc, etc.
My question is, how did the factory do it? Kind of hard to envision workmen after a long day or a hard weekend showing the same concentration as a hobbyist working on his valued vintage ride. I kind of picture the factory floor littered with globs of greasy ball bearings and new bikes missing a few on occasion.
Liked 103 Times
Liked 445 Times
Pretty sure both cups were packed with grease and bearings, the fixed cup screwed in, spindle set in place then the adjustable cup. What I do, since it's such a bear to remove the fixed cup, is to load grease and bearings in the adjustable cup, lay some grease in the fixed cup with a stick, put grease on the drive side of the spindle and lay the 11 bearings in the grease. The grease holds the bearings on the spindle. Then I thread the spindle through the fixed cub and hold the end in place after it comes through while I screw in the adjustable cup.
I leave the fixed cup in place and lay the bike flat, fixed cup down with a black (t shirt) cloth underneath.
I load from underneath and the insert spindle and other cup.
It's a little time consuming but worth it.
A repacked BB should last another 30 years or so.
Or, just stuff an old sock in there as I found on my 1953 BSA..
This could be an example of the very rare "Sock Option" that was briefly offered in the early '50's.
Liked 445 Times
I'm sure they had a "system" at the factory that sped up the assembly.
I leave the fixed cup in place and lay the bike flat, fixed cup down with a black (t shirt) clothe underneath.
I repacked BB should last another 30 years or so.
You really need a good wool sock in there.
It's worth the extra cost.
Quoted: 350 Post(s)
Liked 24 Times
Liked 445 Times
This Canadian Superbe is for sale again @ $200.00 here in Toronto.
The stamped eye on the heron would place it as a 1961 or earlier.
Hard to tell but the forks look a bit suspect...
Quoted: 589 Post(s)
Liked 704 Times
Handlebar bend choices
I searched this thread and didn't see much on the topic, but do see several pics. My 64 has the factory bars that were common to the era and kind of narrow and bent well back, so steering is kind of like a tiller. This doesn't seem to give as much control to me. From some of the pics I see, it looks as though Raleigh handlebars in the 70s were a bit more splayed out at an angle. I think I may look for some like that at my local bike co-op. They would need to have a bit of patina to match the rest of the bike.
I have other bikes to suit different jobs, but thought just a bit more bend and rise might be nice on this casual bike. What do others like, considering a vintage look too? Bike has a B72 saddle for somewhat upright riding position.
Steve
Steve
Liked 445 Times
Here's a nice step through at a reasonable $125.00.
These forks look a little pushed in as well..
Liked 103 Times
Steve
Steve
Quoted: 887 Post(s)
Liked 335 Times
I think the person you responded to was talking bar width, not diameter. I have seen Sports bars from 21 to 25 inches wide.
Quoted: 802 Post(s)
Liked 760 Times
sturmey archer aw3...
I am confused by IGH hubs. How does the hub's axle length work in regards to the bike's OLD?
I have a '74 raleigh supercourse that has been spread to 130mm and I'd like to put a 3speed hub on it. Is it simply a matter of spacers between the hub and the dropouts?
For example, this hub seems nice, but I have no idea if it would play well with 130mm (as I assume it was built for a 120mm bike?), and if it could be simply fixed by buying a 130mm axle and adding spacers.
Thanks.
https://www.ebay.com/itm/NOS-1969-St...pe!92128!US!-1
Thanks.
Quoted: 3832 Post(s)
Liked 6,859 Times
S-A axles came in two sizes: 5 3/4" for 115mm rear spacing and 6 1/4" for 120mm rear spacing. I don't think the latter will be long enough, i.e., you won't be able to get good purchase with axle nuts, in a frame spaced to 130mm. I'd suggest cold setting the SuperCourse rear triangle to 115 or 120mm and hope that the rear end of that frame hasn't been through lots of respacing over the years!
Quoted: 802 Post(s)
Liked 760 Times
So there's no possibility of buying a replacement axle and building the hub around it? I guess for the frame's sake it's probably best for me to buy a newer hub based around a 130mm OLD rather than cold set it again.
Quoted: 351 Post(s)
Liked 614 Times
Royal Nord President Brampton 3 Speed
The Belgium Royal Nord President is home as of this evening. What a mix of components, Spitfire mudguards with plane icon stamped in the alloy, Weinmann 810 brakes, Dunlop Imperial 28"x1 1/2" tires (made in Canada) Brampton hub and shifter and lots more to discover! Really thrilled to have this bike and intend to refurbish and treasure it. More to follow.
The rear rack is marble painted to match the frame. I believe it will polish up beautifully.
Quoted: 589 Post(s)
Liked 704 Times
Yes, mine are narrow
Liked 103 Times
Yes, they are 15/16", Not only Raleigh. Many other older English bikes also. But there's plenty of 22.2mm (7/8") stems with 1 inch clamps to choose from. You might need to make up new cables if you move the shifter and brake levers too far from their original positions though.
Quoted: 589 Post(s)
Liked 704 Times
Might see what co-op has
