Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Stem came today and I can't immediately use it because the height is shorter and I need more spacers. I was already short one and used a headset bearing race as a spacer, now at least I'll have a proper set. I may also flip it. I'm getting older and riding crouched may not be optimal for me anymore. It is also shorter by 5mm, my current stem is 105 and I went with 100.
All of these little things may add up to a more comfortable ride. I'd like to put a 28mm tire on too but I can only do that in the front, the rear will barely fit a 25 and then only if it is perfectly centered and even when it is it doesn't stay that way an entire ride or at least the stress moves it.
Quoted: 20810 Post(s)
Liked 9,456 Times
Getting ready for some tunes, podcasts and audiobooks.
Likes For WhyFi:
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Box-1 Back Pack
Missed one of these last year...
Perfect fit! Life just got easier! Only weighs 32lbs...not a comfortable handle after a while!
1989 hats! ‘bout two dollars apiece for three...great under my bike helmet! That is my last Airgas welding helmet hat...out of the loop on the welding equipment...
Likes For billnuke1:
Quoted: 451 Post(s)
Liked 364 Times
Quoted: 4717 Post(s)
Liked 1,882 Times
I've just retired and I have nothing better to do than to re-tire my bikes.
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
Three sets of Enve wheels (3.4, 5.6 disk,7.8) on the way. Excited, though I can't say I'm proud of myself.
Likes For Noctilux.95:
Liked 9,456 Times
Got a SH-MT301 with 25% discount
Liked 1,882 Times
Quoted: 376 Post(s)
Liked 124 Times
One at half off at competitive cyclist with the other two using the trade in program (alloy wheels) for $1700 out the door for each wheelset. The 3.4 clinchers will replace my Mavics on the TCR, 5.6 disk will go on my new Cervelo R5, and the 7.8’s will be used on my Madone SLR with speed tri-bar set up. This morning I’m riding my humble gravel bike with humble wheels on the filthy roads after heavy rain pour the last two days.
In any case I'm not going to pin any improvement on a few mm of tire width.
I have my rear wheel off because the bike is on the trainer and have it up next to the front wheel. The rear GP4000 is clearly wider than the GP5000 in front. This then begs the question, if a GP5000 in a 25 is the same size as a GP4000 in a 23, where is the advantage? Just because it is stated as being larger it won't make much difference on the ride over what I have if in actuality it is the same size.
I know I can't fit a GP4SII 700x28 on my Tri-A.
Would it somehow fit a GP5 700x28 from above? The place that rubs is the cross bar on seat stay where you have the brake caliphers attached when I tried the 700x28 GP4.
For my commuter, currently on GP4 700x28 thinking going cheap for the Ultra Sport II 700x32, or try the GP5 700x32 - that from above seems will be similar to what I have currently?
Advocatus Diaboli
Quoted: 4756 Post(s)
Liked 1,537 Times
So GP5000 size won't balloon as GP4000?
https://www.bicyclerollingresistance...000-comparison
Likes For Sy Reene:
Newbie racer
Liked 1,569 Times
I went from 23mm 4000's on a wheelset to 25mm rear and 23mm front gp5000 on a wider wheelset recently and the CRR change at low speeds was noticeable. Like, I could see fewer watts routinely when just farting around at like 15mph to 17mph.
Also, the geometry isn't 1:1 that a 4000 23mm is now a 5000 25mm. It's somewhere in between. So, since it's in between you "might" be able to fit something different there.
Thanks to a killer Black Friday deal, I was able to pick up a R5 frameset...with the slickest color scheme I've ever seen.
Likes For melikebikey35:
Bikes: Shmikes
Quoted: 10182 Post(s)
Liked 5,882 Times
Likes For MoAlpha:
Advocatus Diaboli
Liked 1,537 Times
Very Christmasy
From this comparison review at BRR, see the below actual measured width and height on their wheel. You could try and measure your GP4s to determine difference.
After all, no weekend is complete without a trip to Home Depot or Lowes.
Liked 1,882 Times
Quoted: 376 Post(s)
Liked 124 Times
New Enve 7.8’s on my Madone SLR.
