For the love of English 3 speeds...
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
You can pull that off if you have the spacers made from a single bit of metal (IOW not using washers) so that the axle can't flex. But the bigger problem that will likely shoot this down is that the axle isn't long enough to do this. You may have some thread left over, but not enough to secure the nuts properly, so they will strip. Cold-setting the frame sounds easier and how to do this properly is well documented. If you ever want to go single speed again, get a single speed hub that is the same over-locknut (OLD) dimensions as the SA hub.
Set up this way, the wheel is slightly to the left of the center line on the fender, so I can probably do something a bit narrower on the right side spacer and have the bolted down setup drag the wheel back closer to center. Big hold-up right now is that I need to add a couple of links to the chain, as I'm replacing the original 20t rear sprocket with a 23t.
I'm optimistic.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Quoted: 478 Post(s)
Liked 634 Times
I have done what you are doing though not 8mm per side; no problems so far!
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Hit my local Ace Hardware this morning (you should see their fasteners aisle!) and came up with a couple of proper width steel chrome spacers bored 3/8" with 3/16" wall thickness. They're far and away the heaviest alternative available, so I'm assuming this'll add a bit of structural rigidity to the assembly. Putting the wheel on, I found that by removing both the rear rack and massive kickstand (we're talking 1920's motorcycle kickstand - I think my old Indian 101 Scout had the same stand), I've narrowed it down to the point that the non-drive side nut bolts on with 1-2 threads on the axle showing. I'm assuming the drive side indicator chain bolt is fitting about the same.
I'm optimistic.
I'm optimistic.
Quoted: 221 Post(s)
Liked 237 Times
Check and see if the hub is centered, and that you get a good driveline with the chain straight to the chainwheel on the crank. If so, don't shift it; instead use a spoke wrench to take the dish out of the wheel (for this you have to know a bit about wheel alignment, if you don't, look it up on the web, its not hard). The hub allows you to move the sprocket back and forth a bit to fine tune the driveline. This is done by changing the spacers around (there are two, plus the sprocket itself) and often the sprocket is dished so you can reverse it if needed. If you do this right you may have to work with the spokes.
Syke
Syke
My shifter won’t stay in low. Is there someone on here that fixes these?
So the problem is you have to manually push the catch down from the top to get it stay in low which is almost impossible to do when riding. Cable seems to work smoothly. Bought a SA trigger shifter to put on it for now.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 444 Times
A small kink or frayed wire inside the housing can mess things up.
A nice clean sweep to the cable stop helps as well.
Sometimes the trigger itself is worn/bent etc.
Your's looks good.
astro
Bikes: Raleigh Sports, '72, Bianchi Volpe, '97 (no more, it died), Greenspeed GTVS6, '05, Trek 520, '13
Quoted: 43 Post(s)
Liked 51 Times
Restoring an English 3 speed hub (not on an English bike!)
Some of you might remember I posted about restoring my 1972 Raleigh Sports a couple of years ago. Something not done in that restoration was servicing the Sturmey Archer AW 3 speed hub. I've been wanting to do that, but a bit leery of it. Finally got the idea of practicing on my late wife's old bike which has a Sturmey Archer S3C hub - 3 speeds with a coaster brake. So the hub is English! The rest is Schwinn (a Collegiate from 1981 or 82). Anyway, here's a web page describing the restoration of the Collegiate, but mostly concentrating on the hub. Attached below is a photo of the restored Collegiate.
Liked 444 Times
I’ll put on a new cable when I put the other shifter on and set the whole assembly to the side. I wish it wasn’t riveted together. I don’t want to mess it up trying to get in it but I’m betting someone on here has before.
Liked 444 Times
But they're usually pretty bullet proof.
Unless there's a dent or a broken spring it should work.
Quoted: 12 Post(s)
I've fixed a couple of Sturmey Archer thumb shifters that would not stay in gear due to weak pawl springs. The shift cable is under the most tension in low gear, so, if the spring is the problem, that is where you would expect the problem to be most pronounced. There are two ways I dealt with the weak spring:
1. Drive out the rivet holding the spring in the shifter, bend the spring so that it applies more pressure, and reinstall. Dealing with the rivet, particularly during re-installation is fiddly. The rivets on your Hercules shifter have much larger heads than the Sturmey shifters that I've worked on.
2. Install a shim under the backside of the spring so that it applies more pressure to the pawl. You'll want to make the shim to that it is positively retained under the spring, otherwise it might vibrate out of position. I was able to do this without disassembling the shifter. I did it on a bike I owned in college, and it worked fine for the year or so that I rode the bike, but is certainly less elegant that the first fix.
Another possibility is that the low gear pawl stop (or whatever it's properly called) is worn round and will no longer engage the pawl. I've never encountered this, but imagine you could deal with it by disassembling the shifter and filing the stop back square. You might find that you also have to remove a similar amount of metal from the middle and high gear stops in order to maintain the correct amount of cable pull between the gears.
All of the above assumes that your Hercules shifter uses the same internal mechanism as the Sturmey shifters.
-Carl
Thanks for the advise @cszipper !
Likes For RobHalligan:
Quoted: 457 Post(s)
Liked 462 Times
A few drops of oil in the shifter to make sure ther springs can push bits around as they are intended to could get it working too.
Likes For jackbombay:
Quoted: 457 Post(s)
Liked 462 Times
So, I have a couple of worn S5 hubs, and need some parts, I have new 1st/5th sun gears, part number HSA269, but I still need sun gears for 2nd/4th, part number HSA141 and 8 new planet gears, part number HSA134, does anybody know where I might find these for sale? My hunch is the planet gears are still in ok condition, and the hubs will work much better with new sun gears, but as long as they will be apart I'd like to replace all the parts that wear...
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 458 Times
Trying to get more info on this HUMBER. It was suggested I ask here. More pictures at the link. Thanks!
https://www.bikeforums.net/classic-v...7939-what.html
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Likes For stevel610:
Quoted: 457 Post(s)
Liked 462 Times
The other one to check is that I have occasionally had the band clamp on the shifter be slightly too long, so the screw that holds it in place clamps on the shifter mechanism before the band clamp is fully tight, that compression of the shifter prevents it from working properly. Just loosen the mounting screw for the shifter a turn and see how it operates, if that is the issue a little scrap of inner tube under the band clamp will make the band clamp get tight before the screw applies any compression to the shifter itself.
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
He also sold me a couple of left side bellcranks for my S5 hubs that he adapted from shimano bellcranks. You can see them 1/2way down this page https://bikesmithdesign.com/SA/SA-tips.pdf
You could maybe try this guy? Internal Gear Hub Service
Likes For arty dave:
Quoted: 457 Post(s)
Liked 462 Times
Hes a great guy! I did buy the HSA269 sun gears from him, but he doesn't have the HSA141 or the HSA134.
That website does list the parts I need! Thanks you so much!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
edit
Likes For clubman:
Quoted: 457 Post(s)
Liked 462 Times
Free Raleigh Twenty
Finally dragged the Raleigh Twenty back out of the garage during a dry spell to take some photos. The work van does not make the most charming backdrop, but it was about as much effort as I was willing to put into photographing this. I posted about picking this up a few weeks ago, and haven't really touched it since, aside from pulling more pine needles out of various crevices. It certainly isn't in good shape, and I think free was about the right price for it. If I end up liking it, I'd consider re-painting. There's patina, and then there's just sad.
It's got some white splotches here and there that I think might be house paint, and rust galore. Rims are surprisingly not very rusty, which is nice, though the nipples did not fare as well. Hopefully they're not seized.
I did get the pair of tires I ordered for it in the mail, nothing fancy, just some cheap CST Decades to try the whole thing out. Whenever I get around to finding tubes and getting the hub moving that is. I was also gifted a white saddle that I think might look rather nice on this, if it doesn't end up being unbearable to sit on.
I'll post progress pics whenever I actually make some progress on it.
Likes For knittykitty:
