For the love of English 3 speeds...
Quoted: 457 Post(s)
Liked 462 Times
I like the way you think!
I used dual quadrant shifters to shift the sturmey 5 speed drum on my DL-1, and the big sturmey drum in front.
Rod actuated drum bakes - it has been fun make those work.
Quoted: 457 Post(s)
Liked 462 Times
So here is my resto mod hercules that I built up back on 2005, I think the frame is from 63' based on where the serial number is on the BB shell, but maybe you guys can confirm or refute that, the chrome fork crown cap was larger on the older Hercules I think, and this is the original chrome cap for this fork, so maybe it's newer than I think?
I had cable stops brazed onto the frame, got it powder coated semi gloss black, built up a nice set of wheels for it with some pretty darn light IRD 700c rims, I got a NOS 28 hole sturmey off Ebay for the rear wheel, and a 28 hole NOS Deore XT (From before there was XTR) front hub. I had a ti BB kicking around that I threw in there, but I did of course have to retap the BB shell, I used an old steel BB and cut grooves in it and spun it in and out repeatedly with a big drill, not elegant, but effective. Found some Mafac racer centerpulls in good condition that fit around the fenders and line up well, aluminum stem and bars, aluminum cranks, and thats about it, aluminum seat post. As it sits currently it is 25.6 pounds (about 12 kilos) Its a fantastic townie, and I've been cruising it on some longer rides too, this pic is on the beach at Lake Tahoe after I rode a century on it there,
And here I am putting a hurtin' on the emerald bay climb, I was able to average 16 MPH for the ride.
And another shot of me letting it roll down one of the descents on the west shore, according to Strava I hit 45 MPH right around here, seems about right based on the road biking I do.
I had the bike geared 52/24, which was pretty ideal for this ride, with that I spin out at about 22 MPH, and I never needed or wanted a gear lower than 1st, it worked well to do a lot of the climbing standing up in 2nd gear...
A shot of chrome and brakes,
How it's normally dressed for around town use,
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 444 Times
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I still laugh thinking about Peter Cook (the Devil) ripping the last page out of piles of Agatha Christie novels.
Jack, you are a hard man! Nice ride.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
I am curious- why not go with the stock 46 tooth in the front, with a 21 in the rear? This gives you exactly the same ratios, the hub is totally rated for it (they used to make tandems running the AW hub) and overall the bike would weigh less (although not by much). Finding that 24 had to be a bit harder- although I really like the way the sprocket is drilled.
Quoted: 457 Post(s)
Liked 462 Times
Quoted: 457 Post(s)
Liked 462 Times
What gear were you in when you blew up the hub? What gearing (chainring/cog) were you running with it?
Quoted: 76 Post(s)
Liked 19 Times
If there are any Colorado 3 speed fans there is a guy in the Arvada Craigslist selling off a large collection which looks to include a bunch of rod brake English bikes.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 470 Times
I'm having a hard time fitting my rear fender back onto the '50 Superbe. I think the Panaracer Col de la Vie tires are a bit bigger than the original. The front went OK with a little wiggling and adjustment, but the rear has been a pain. It is very tight right at the back where the fender reflector bolt end rubs on the tire. I'm wondering I could use a shorter bolt, but I am afraid to remove the reflector housing bolt. I suppose I will keep moving it around to find the best alignment. I think the trick is in where it mounts at the brake; there is something curious about the way they mounted the fender stay clip. I just have to run the shifter cable, install brake cables with original oiled housings, and dial in the shift adjustment before I install the 3 speed Cyclo derailer. I am very excited about the Cyclo unit because it will help on our local trails and my commute. I may even take it on an overnighter or weekender once I can trust it.
Quoted: 359 Post(s)
Liked 265 Times
I stand on the hub all the time, until about 5 years ago never thought there might be any downside. But I still do it- i just make sure the shift cable is properly set and the hub well vetted. Since you've already done serious climbing with yours, its a good bet that both of these factors are sorted on your bike. But it is a good thing to know...
Quoted: 457 Post(s)
Liked 462 Times
Yea, I'm the only person that has ridden/oiled this hub so there is nothing unknown in its past.
Phyllo-buster
Liked 2,055 Times
Just to be pedantic, the fulcrum stop clamp and axle nuts are equally important. If any of these 3 items move, there could be trouble. But you all know this.
Phyllo-buster
Liked 2,055 Times
Yup. Just take a coarse hand file or dremel to shorten it, making sure to clean up any burrs. I'm not sure which fender/brake mount is being used here but sometimes you can put a spacer between the chainstay bridge and the front of the rear mudguard to shift the whole assembly back and possibly give you a nicer arc to work with.
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
My latest 3-speed find: A 1935-ish Armstrong roadster, ladies frame. I'm rebuilding this one with the intentions of selling it to a WWII re-enactment group, the Woman's Land Army. These ladies put on some incredible displays, and most of what they've got are antiques, not something modern fudged to work.
Of course, what I'm lucked into is an "80% complete" bike, which means I'm looking forward to spending the rest of this year (at least) looking for the other 20%. Primarily: full chain case, and a lot of little parts for the rear brake. Hub is a Sturmey AW, although I'm not seeing any date stamp on the hub case, at least not in the places I'm usually used to looking at in '60's and '70's bikes.
If anyone knows of any sources for pre-war English bikes parts, I'd appreciate it if you'd pass them along. While I've done a number of '50's bicycles in the past few years, this is my oldest restoration attempt. Happily I've got my own DL-1 Tourist to check over if I start getting confused.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Likes For sykerocker:
Quoted: 515 Post(s)
Liked 167 Times
Quoted: 22 Post(s)
Just saw these on CL. Men's and Ladies All Gold Editions.
https://northmiss.craigslist.org/bik...907727264.html
Anybody near this location interested? I wish I was closer.
Quoted: 3811 Post(s)
Liked 6,717 Times
Quoted: 221 Post(s)
Liked 237 Times
Unfortunately not that I've seen. The group is from the Williamsburg, VA area (I've known the leader and her husband for decades, as they're Burnley and Trowbridge, my main fabric suppliers for the historical costuming I do), and they're set up every year at Military Through the Ages at the Jamestown Settlement in mid March. Will do some other looking for pictures. There's something on the Women's Land Army on Facebook, but it's a British group. They've already got their bikes.
Syke
Syke
Quoted: 221 Post(s)
Liked 237 Times
At which point, you may have just dated the bike for me. Thank you.
Syke
Syke
Phyllo-buster
Liked 2,055 Times
Looks like a 0 so possibly a 1940 model as a flyer. Early-war?
I'd expect to see more blacked out chrome near the end of war.
Quoted: 457 Post(s)
Liked 462 Times
I have a 1987 Dahon folding bike with a Sturmey Archer AW in the rear wheel, I pulled the hub apart and cleaned it and reassembled, but now I don't have first gear, 2nd and 3rd work as normal. I did adjust the shifter cable plenty tight and that is not the problem. The shifter does go into the first gear position even with a shift cable that I would consider somewhat too tight. Any ideas of what I reassembled incorrectly?
I think that maybe the axle needs to be sticking further out on the drive side of the wheel? I did not measure axle protrusion before disassembling it, for reassembly I put the non drive side cone such that the gear that is fixed to the axle was about a 1/16" from "bottomed out".
Quoted: 457 Post(s)
Liked 462 Times
I disassembled and reassembled using the vid linked below, and now it works fine, I think it was that I needed to move the axle towards the drive side...
Quoted: 1299 Post(s)
Liked 103 Times
https://www.youtube.com/watch?v=vNxwMwzS3Jo
