Addiction LXXIX
#4326
VFL For Life
Bikes: Velo Volmobile
Quoted: 28629 Post(s)
Liked 1,858 Times
#4327
VFL For Life
Liked 1,858 Times
#4328
VFL For Life
Liked 1,858 Times
#4329
Administrator
Quoted: 11975 Post(s)
Liked 6,655 Times
Back in the stone age when wheels were first invented and it still had what we would call today "irregularities", but which at that time was the norm, was it not called a wheel?
Likes For BillyD:
#4330
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
As I understand it W' is the amount of work in Joules that you can do before exhaustion. W'bal is essentially an estimate of "matches burned." There should be an estimate of W' under your overall curve on your power page. I think if you plug that number in in the settings, it will do W'bal for you. I have read that this measurement is tricky to do right, so this must just be a rough estimate. My W'bal sometimes dips a little below zero, which is obviously impossible. However, it clearly behaves the way I feel and I like seeing that I didn't leave anything on the course.
What's Type III fun?
#4331
Quoted: 20810 Post(s)
Liked 9,456 Times
The bests are all related to finally getting a PM.
Type I Fun
Type 1 fun is enjoyable while its happening. Also known as, simply, fun.
Type II Fun
Type 2 fun is miserable while its happening, but fun in retrospect. It usually begins with the best intentions, and then things get carried away.
Type III Fun
Type 3 fun is not fun at all. Not even in retrospect. Afterward, you think, What in the hell was I doing?
I'll have to poke around more for the W'bal - thanks. That does seem like it'd be a tricky, tricky thing to pin down.
#4332
Administrator
Liked 6,655 Times
But that's just me.
Likes For BillyD:
#4333
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Hey phrantic09 - did you end up getting one of those Rapha hoodies? If so, have you gotten it/what do you think? I did not, but I see that they still have some Large available in decent colors. Complicating matters, though, is that they've now got a steep discount on the Explore Technical Hoodie...
#4335
Administrator
Liked 6,655 Times
Ive always thought or the body like a bicycle wheel. It starts off in fine shape, smooth bearings, true, shiny, etc. and gradually, it starts to wobble or run rough and the mechanic or doc puts it right and it rolls on again until the next time it needs attention. But eventually, spokes break, races fail, rims crack, or whatever and the wheel has run its last revolution.
#4337
Administrator
Liked 6,655 Times
#4338
Liked 9,456 Times
#4339
Mostly Harmless
Bikes: Have two wheels
Quoted: 13718 Post(s)
Liked 4,532 Times
#4340
Mostly Harmless
Liked 4,532 Times
Likes For phrantic09:
#4342
Super Modest
Quoted: 10963 Post(s)
Liked 4,621 Times
#4343
Mostly Harmless
Liked 4,532 Times
And a wall and a moat?
Likes For rjones28:
#4344
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
#4345
Quoted: 10238 Post(s)
Liked 5,185 Times
Shimano freehubs are held on with a sleeve that threads into the hub. It requires removing the cassette, brake disc, cones, ball bearings and axle to tighten with an Allen wrench, then reassemble.
https://m.youtube.com/watch?v=SZZdB_P3mmc
#4346
VFL For Life
Liked 1,858 Times
Only bombproof wheels.
wut
The brown/barren patches. At least its flat.
#4348
Bikes: Shmikes
Liked 5,872 Times
Okay, so maybe Type II Fun.
Type I Fun
Type 1 fun is enjoyable while it’s happening. Also known as, simply, fun.
Type II Fun
Type 2 fun is miserable while it’s happening, but fun in retrospect. It usually begins with the best intentions, and then things get carried away.
Type III Fun
Type 3 fun is not fun at all. Not even in retrospect. Afterward, you think, “What in the hell was I doing?
Type I Fun
Type II Fun
Type III Fun
#4349
Silver Comet Fred
Bikes: 1
Quoted: 8845 Post(s)
Liked 2,995 Times
Glad you closed.
Likes For DougRNS:
#4350
VFL For Life
Liked 1,858 Times
