One Man’s View Of Disc Brakes
#226
Quoted: 4717 Post(s)
Liked 1,882 Times
The funny thing is that I purchased one of those USB power bricks from Amazon, the one that lets you power 6 USB devices and has smart power to charge them at their appropriate amperage, and placed it near my two Di2 bikes. So I can charge their Di2 and also the four Bontrager LED lights.
Who'd have thought 20 years ago that such a thing would ever happen...
I understand the need for charging your lights, but how often are you charging the Di2 battery?
#227
It primarily was to solve the lights issue: I'd often forget that I'd gone through a pair, use up the other pair, then don't have lights because I was too lazy to go hunting for Apple charging adapters.
#228
Quoted: 18883 Post(s)
Liked 10,646 Times
#229
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,871 Times
#230
Señor Blues
Oh man, I stumbled onto this thread too late. It took me about 20 minutes to replace (upgrade) my SM-RT800 rotors with some Dura-Ace level RT900 rotors that I scored a sweet deal on, and also to replace the resin pads. The resin pads cost me $40, and the rotors $100, and although the 800s were still very much within their ....................
#231
Absolutely. If it only took me 20 minutes to do all of rotor uninstall & install + brake alignment + conversion to 140 to 160 (and keep in mind all of this was voluntary on my part, I wanted to upgrade the rotors and convert to 160, it wasn't a requirement)...then normal maintenance (outside of bleeding, which I haven't had to do) is going to be much easier. Replacing pads literally takes a minute.
And in exchange I get great stopping power in all seasons, and don't have to worry about rim brakes tracks on carbon wheels. Which if anything goes wrong, far eclipses the cost of rotors and pads.
Also keep in mind that was all my first time doing any of that. Future instances will be much faster.
Likes For CarloM:
#232
Señor Blues
Dura Ace brake pads are less than $18.00 for front & rear. Disc brake replacement parts as indicated in your post @ $140.00. Unless money is no object, this is a great reason to ignore all things disc on road bikes, unless there is a specific need, i.e. foul weather riding and/or off road.
Likes For on the path:
#234
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#235
And you're ignoring their improved performance of disc. Modulation. Stopping power. When I recently got into the cycling game I was trying to save money and was looking seriously at rim brake bikes since they were all being clearanced. Apparently we can consider 2019 the Year the Manufacturers Went [Nearly] All Disc. But riding the two...it's very evident which are superior brakes even in dry weather for me and my style of riding. I still go into my LBS and see one year (or older) models being clearanced at 25-40% off original MSRP, but most are rim brakes. I try them out and they're all great to ride. Until I hit the brakes. And then I realize I'm not going back to rim brakes.
And I already admitted the Dura-Ace rotors were for their cool aesthetics--although Shimano will claim they perform better than the Ultegra versions, which they'll claim to perform better than the 105 versions...
Since I'm using resin pads, which are rotor-life friendly, I don't anticipate buying new rotors any time soon.
#236
My take is that high quality rim brakes are way more than adequate wet or dry.
But...
I’m planning a new build and it’s going to have discs.
Why?
Because I can swap wheel sizes. 26, 650b, 700c. Not limited.
*why would you want to swap between those?* everyone will ask.
Because one comfortable, quality bicycle that can be ridden for as long as I want is what I want. And sometimes that means dirt, sand, mud and gravel. Sometimes it means ice. Sometimes it’s pavement.
But...
Why?
#237
Quoted: 1529 Post(s)
Liked 718 Times
Wow, I don't think anyone has mentioned being able to swap wheel sizes as an advantage for discs in this thread till now. That factor is a big deal for a small number of folks.
Shimano reckons IceTech lowers temps by a big chunk, like 80 degrees or something. And another hefty amount for DA/XTR level IceTech over that.
#238
Señor Blues
I've got nice wheels, light and strong, rim brake setup. I avoid riding anything but paved roads with them. And the brakes work fantastically well on that bike. Barring something unusual, those wheels should be in service for several more years. Why fix that which is not broken?
#239
I'm sure it happens but I've not heard of anyone wearing out a brake track on a rim. However, I do hear of rims failing at the nipple holes (not ironically, disc setups are tougher on spokes/nipples... show me a front wheel with radially laced spokes and I'll show you a wheel that's been improperly built). A worn rim has likely served its useful life. A failed nipple hole could be from normal use, abuse, or improper spoke tensioning.
As as far as spoke lacing, yes 24/24 with cross lacing is absolutely required as a minimum for disc brakes. Radially spoked wheels are about, but nobody who really builds wheels seems to endorse that.
#240
Liked 9,456 Times
Well... yeah. That's kind of the point.
Likes For WhyFi:
#242
Señor Blues
To each their own, $40 vs. $18 for something I don't replace often isn't a big deal for me, but I won't begrudge anyone else for whom that is a significant amount.
I paid $40 for 2 sets, back and front, including tax.
Sorry, simply making a declaration does not make something true. I can just as easily say that, wait somebody already said:
I'll declare that disk brakes on road bikes for riding on pavement provide absolutely no improvement over rim brakes on the same bike. See how easy that was?
Factually, disc brakes are heavier and more expensive on road bikes. That is not open for debate.
That the industry wants us to play along and "upgrade" to something we don't need has never been a reason for me to play along. Have fun...
#245
Liked 9,456 Times
Swapping wheel sizes can been seen as an extension of swapping tire sizes, which is certainly seen as a benefit by more than just a small number of folks. I can go up to 40mm on one of my bikes, up to 35mm on the other. I've certainly taken advantage of that ability on both bikes, swapping knobbies and slicks, as weather and terrain dictates.
#246
Liked 10,646 Times
#247
Señor Blues
I realize that this is the 41, but how can a thread like this contain no meaningful mention of tires? Tires are the single most significant component of any vehicle braking system. Ever hear - "your car is only as good as its tires"? When you're done "modulating" it's all up to the tires.
#248
Bikes: Shmikes
Liked 5,871 Times
#249
Liked 9,456 Times
Um, I'll declare that rim brakes categorically are just as good as disc brakes. And disc brakes are good enough. And heavy. And expensive. And overly complicated for the application.
Likes For WhyFi:
#250
Señor Blues
