Good Chain Lube??? Mines WD40. :P
#226
Quoted: 4414 Post(s)
Liked 4,867 Times
Any product from Silca has been rigorously tested and their lubes are the best in the industry. https://silca.cc/collections/chain-lube-wax
I've just got a new bike and been riding it with the factory grease for the first couple of hundred kms. Even riding on good dry roads it's already starting to look like a sticky, black, oily mess. Tomorrow I will clean it up and convert it to Silca wax and all will be good
#227
Quoted: 18420 Post(s)
Liked 15,564 Times
Listen, folks. I settled this a long time ago.
NFS is the best lube. Period.
#228
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
Yeah, I've been using Silca Super-Secret drip-on wax for about a year now and it is excellent. Easy application, low wear, quiet, no mess. It scored very highly in Zero friction cycling's lab tests too, which is what first prompted me to give it a try. Before that I was using Squirt, which is quite similar but doesn't penetrate the chain links as easily as the Silca SS.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#229
Quoted: 3952 Post(s)
Liked 7,299 Times
#230
I am just joining in this thread to say that I am extremely happy and, well...relieved I believe would be the accurate descriptor. I have actually been not sleeping well lately and I have realized it is anxiety brought on by thinking this thread was just going to scroll off into oblivion. As the months have passed, it has just been gnawing at my nerves more and more.
But now, all is well. Thank you so much, Mooree for bringing this one home. Thank you, thank you, thank you. I cannot thank you enough.
Thank you.
Thank you.
#231
Even used cooking oil is better than the blue can WD40
WD40 is an anti-seize. To be a good anti-seize, it must turn into a very thick, gummy sludge after some time, great to prevent bolts from sticking together permanently. But also makes it a very poor lubricant.
#232
Liked 15,564 Times
#233
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
No. It isn’t. It is a lubricant in a solvent, just like oil based bicycle lubricants…even to the same proportions. Look at the SDS for WD-40 and the SDS for just about any other chain lube and you’ll see the same or similar CAS number for the constituents in the mixture.
Stuart Black
Stuart Black
#234
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Every time one of these chain lube threads come up, I think about all the crap my dad lubed my bike chains with as a kid. Everything from 30 weight motor oil, WD-40, silicone spray to 3-in-1 oil. He used everything but bacon grease; he saved that for frying taters.
#235
Well if it is a lube, then it's the only lube I know that turns into sticky, messy, gummy thing after many days.
Mineral engine oils on the other hand will turn into black, messy grease after many days but not sticky nor gummy. Even used cooking oil will not turn into sticky gummy mess. If I was given only two choices, between WD40 and used cooking oil, I'll choose used cooking oil.
I'm not promoting either situation. Nothing beats a clean chain. A clean chain is the ONLY way to have long chain and cassette life.
#236
Liked 4,219 Times
But I also want to dispel some of the misunderstanding of what WD-40 is and isn’t.
Stuart Black
Stuart Black
#237
I like the dry lube from Muc-off. It comes with a slight hint of banana for some reason but the most important thing is that it's dry lube and doesn't attract that much much to your drivetrain
#238
Liked 4,867 Times
This ^ 100%
That's where oil based lubes fail for me. With the drivetrain fully exposed, the oil soon gets contaminated and quickly turns into a messy black grinding paste. Wax based lubes keep your drivetrain much cleaner with none of the oily mess.
#239
Quoted: 2333 Post(s)
Liked 2,097 Times
I switched from MSW to Silca melted wax with liquid touch-ups. Awesome product.
In defense of the bacon fat crowd, I did a tour once where it rained every day. I ran out of oil. I switched to extra virginal olive oil for a few days until I got to a town. It worked. Optimal? Who knows. But the chain lasted the tour.
#240
Liked 4,867 Times
#242
Three chains in rotation all waxed with Silca Secret Wax.
#243
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Belt Drive
#245
Quoted: 800 Post(s)
Liked 512 Times
+1 on Rock 'N Roll Gold. Since landing on this as my bike lube of choice I haven't looked back.
#246
What we didn't do, however, was clean the chain. Ever. Eventually the chain and gears became black, oily messy things which I am certain were slowly destroying themselves with the thick, grimy oily mess. Limestone dust + oil was particularly tacky and I am sure did little good to the chains!
#247
For the past few years I`ve been using Synthetic Gear Lube with a little STP added.
I have a few old, empty 3- In- 1 containers that I add it to. It makes for easier application.
#248
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
#249
I found this to be the worst lube I've used, used it a few times and had the noisiest drive train everytime, sounded like the chain was completely dry. Switched to Muc Off C3 Ceramic which IMHO is the best dry lube I've used.
