Vintage Miyata 610 and Similar Non Top of the Line Touring Bikes Thread
#76
Quoted: 195 Post(s)
Liked 207 Times
[QUOTE=squarenoise;21838556]Heres my 1984 Miyata 610. The only original parts are the Wheelset (Sealed Bearing Suntour Hubs), Seatpost and Rear Rack. The rest of the build is mostly period correct-ish, plus newer cockpit. I moved a majority of the original parts to another bike ('85 Sekai 2500) and built up the 610 closer to Miyata 1000 specs.
Vintage Parts:
Sugino AT Crankset (50/36/28) w/ Original Sealed Bearing Bottom Bracket
Specialized Touring Pedals (as found on the Specialized Expedition) w/ MKS Cage Clips
Shimano 600 Brake Levers w/ Dia Compe Adjusters and SOMA Hoods
Shimano Deore XT Brakes (BR-MC70) w/ Shimano LX Kool Stop Pads
Shimano Deore DX Derailleurs
Shimano 7 Speed Bar Ends
Speedic 170GT Saddle
New Parts:
Tange Levin Headset
Nitto Technomic Stem
Nitto Noodle Handlebars
Sunrace 7 speed Freewheel (13-28)
Panaracer Pasela Protite 27 x 1-1/4 Folding Tires
Accessories:
Velo Orange Randonneur Front Rack w/ Integrated Decaleur
(Not Pictured) Velo Orange Randonneur Handlebar Bag
Velo Orange Hammered Fenders
Crane EHard to call that a second tier touring bike. It's nearly perfect from my viewpoint. Ride on!
Vintage Parts:
New Parts:
Tange Levin Headset
Accessories:
#77
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I think youll find this is generally true for most all second tier touring bikes. The differences are usually only in the components, not in the frame. A Miyata 1000 had slightly better parts than a Miyata 610 but they used the same frame. Cannondale has done the same throughout their history.
Many of the other Japanese touring bikes from the 80s to early 90s were probably made in the Miyata factory. Miyata used to be the giant in frame production. Univega, Centurion, Panasonic, etc were likely Miyata frames with different badges.
Is this what T-Mar says?
#78
Quoted: 195 Post(s)
Liked 207 Times
[QUOTE=RiddleOfStee
And of course, my recently-finished 1985 Trek 620 in 25.5" / 65cm form. Like saying a second tier Ferrari is slow, saying this 620 is a lesser touring bike is a bit silly. Granted, Trek did not make a 720 for kicks, or with indifference, so, for research purposes, I will just [i]have to [/i]find one and compare.
Love the 'dale touring bikes. I couldn't afford one back then. Tall bikes need stiffness and triple butted bikes never made comfortable touring bikes for me. Rebuilt third tier touring bikes were the only kind I could afford and I found the straight gauge tubes stiff enough to provide a stable ride. I hated the 720 much to my surprise. For riders that don't carry as much s--t as I do I can understand the love though.
Likes For Cycle Tourist:
#79
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
[QUOTE=Cycle Tourist;21844481]
Miyata used Triple-butted tubing on their 912 and it was heavier and stiffer than their equivalent DB road frames. The Triple-butted downtube was really stout and featured an extra-long butt up to the head tube.
The Trek 720 felt like a Cadillac "noodle" to this lightweight rider when I tried riding it on one of the Griffith Park morning rides in the 90's. That tubing was light and even the steer tube flexed enough to dislodge the lower Stronglight headset bearing race once when I rode it off road!
have to find one and compare.
#80
Miyata 1000 and 610 of the same year did NOT necessarily share frame/fork. Yes, some times the three main tubes of the 610 were the same tubing as the 1000 (and other times NOT), but the seat stays, chainstays and/or fork were often of 'lesser' grade. Double-butted vs straight gauge (or triple vs double, or splined vs not...), CrMo vs Mangalite vs hi-ten, etc...
The other brands might have contracted with Miyata to build the frames, but they were built to the BRAND specs, but not necessarily the same as what Miyata used. Univega spec'd out their frames (and components) of their bikes built by Miyata. For instance, my '84 Univega Gran Tourismo is closely aligned with the same year Miyata 610, but not only do some of the components differ, but my Uni has mid-fork braze-ons that the same year Miyata 610 did not! The rear rack mounts on the Univega are on the inside of the seat stays, the Miyata is on the outside of the seat stay... so --- they are clearly NOT the 'same frame with a different badge'...
A closer example of which you speak is my '84 Univega Viva Sport. Other than it's 27" wheels vs 700c, and it's SunTour BL derailleurs vs SunTour Cyclone, it is nearly the same as a same-year Miyata 710. Same double-butted CrMo frame, Mangalite fork (but sized for 27", not 700c), hubs, brakes, bars, shifters,etc.
As for the other brands? I don't have any of those to compare...
Then there is Fuji... Fuji built bikes at several facilities...different facilities often had different spec parts... The same thing happens with auto manufacturers... A Japan-built Honda CR-V differs from a US built Honda CR-V! (a windshield from one does NOT fit the other -- ask me how I know!) A Ford Taurus made in Dearborn is different than one made in Chicago or StLouis....it is maddening!!!!
#81
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
Thank You! Honestly, I've been greatly inspired by yourself and many other forum members to make sure I get it right. My 610 has been pure joy to work on and now to ride. Everything is dialed in nicely and I couldn't be happier with how it turned out.
Likes For squarenoise:
Likes For uprightbent:
#84
Quoted: 99 Post(s)
Liked 267 Times
I totally remember seeing (and loving) this one! I originally had my VO fenders mounted on a surly Cross Check, but as soon as I acquired my '84 Miyata 1000 I just HAD to mover them over, then when I acquired the '84 610 I HAD to move them over once again, haha! There's just something about this frame color and those fenders that were "meant to be".
#85
Liked 1,296 Times
At least now you can relegate one of them to "high risk" duty. Urban theft or off-road insanity now can't leave you without a six-ten.
I think this is the same year as mine, my gravel bike since about 2006 or so. Before it I had a 1977 Gran Touring (1000?) model in the lighter blue color, it had steeper angles and higher bottom bracket as I recall, but was used as an off-road bike anyway. It was like an extra-fast mountain bike from the rigid old days.
Likes For dddd:
#86
If a Trek 520 is a beta tourer, does that make my Trek 420 a gamma tourer?
#87
Quoted: 604 Post(s)
Liked 1,064 Times
Ive only got a couple of bikes with a touring geometry, this is my favorite, definitely not top of the line though.
Tim
1988 Trek 400t
Tim
1988 Trek 400t
Likes For tkamd73:
#88
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I love the color. The brake housings look great with it too.
#89
Quoted: 604 Post(s)
Liked 1,064 Times
mkeller234 Thanks! I’m pretty happy with it. I’ll be rooting for the Browns, until, and if, they play Green Bay.
Tim
Tim
#91
Quoted: 99 Post(s)
Liked 267 Times
Very gentle/slow bending to get it there. The initial installment was too high and too close to the handlebars.
Likes For polymorphself:
#93
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 358 Post(s)
Liked 122 Times
Schwinn Passage
in grey . Not "top of line". I had some pretty decent components from a donor. Still needs some pedals and touring seat
Likes For rossiny:
Likes For boneshaker78:
#95
1984 Univega Gran Turismo as harvested Memorial Day weekend 2023. Looks to be all original save the tires, cables, bar tape and saddle. Not sure what to do with it...
I have some 700c hybrid wheels on a CODA labeled hub, 8/9/10 speed freehub..... Shouldn't be too difficult to spread the stays from 126 to 130.
Likes For Smokinapankake:
#96
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
1984 Trek 620 - 25.5" - As fully renovated. Frame, fork, headset, and crankset are original. Everything else is from parts I had. 600-level 531/cromo frame mix that is nearly as light as the full 531 frames on 700-level bikes. That was a very nice discovery. Rides very well. Beautiful bike.
Likes For RiddleOfSteel:
#97
Volunteer wrench
Bikes: 1971 Schwinn Suburan, 1971 Peugoet UO8, 1984 Nishiki Cresta, 1984 Nishiki Olympic, 1987 Schwinn Super Sport, 1996 Waterford 1250, 2018 Cannondale Synaspe Carbon
Quoted: 19 Post(s)
Liked 53 Times
I'm happy with an '87 Trek 520 Cirrus and no need for another like it.
That said, I spotted this NICE original, bargain priced Nishiki Cresta GT on eBay. Has stump pulling gearing with sought after Suntour triple pulley Lepree.
https://rover.ebay.com/rover/0/0/0?m...2F114083550504
#98
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
I bought this Cannondale ST400 a couple years ago at the Memory Lane swap in Bowling Green, Ohio. It had been ridden hard and put away wet, but it cleaned up well. The serial number says 1989, but the specs match the 1990 catalog. I also have a set of Blackburn racks for the front. I understand that all three Cannondale bikes used the same frame. Only the components and colors changed as you went up from the ST400 to ST600 and ST1000.
As for the ride, it reminds me of this old ad campaign from Ford:
1972 Ford ad
1972 Ford ad
Likes For Pompiere:
#99
A blue and white Cresta GT is one of my unicorns....
#100
Liked 1,296 Times
Not quite a "beta" level touring bike when it wears an original Sugino AT crankset at first thought, but some mild down-spec of the balance of the components perhaps makes it less than top-of-the-line?
I bought this Nishiki Seral from Goodwill as a back-up bike, and because it's crankset was worth far more than the a$k. I had already secured a Six-Ten as a replacement for my earlier ('77) Miyata Gran-Tour that I had been hammering off road for some years so needed to retire (I donated it).
The Seral handles difficult trail riding about as well as the Six-Ten, helping to keep my CX skills current year-round.
Like the Six-Ten, the frame geometry seems to lean toward the Sport-Touring end of the spectrum (the Six-Ten has 73-degree frame angles versus the 72-degree angles of the Two-Ten and the 1000). A Centurion Pro-Tour is yet more sprightly (subs for a road bike quite frankly, in a good way).
There was a period of a few years around 2006 when touring bikes flooded into our local thrift stores, with good examples selling for between $20 and $40.
The flood of road bikes had been in the years prior, as many baby-boomers moved up to my hilly foothills region from the bay area but obviously didn't take to riding their old bikes in such hilly terrain.
One can quickly gauge a bike's design intent by measuring how many fingers fit between the tire and the seat tube, more than two and it's a real touring bike (or it's a UO8/9/10), less than two fingers suggests sporting intentions, i.e. a road bike.
These "beta"-level and "sport-touring" bikes usually came with a rear rack, which I find greatly enhances their off-road prowess in terms of weight distribution, with climbing traction helped further by their modest (about two fingers) chainstay-length dimensions.
