Addiction LXXX
#9301
Quoted: 20810 Post(s)
Liked 9,456 Times
GP5k two-packs on sale at PBK for $75 - supposedly only a 2-hour sale. https://www.probikekit.com/bicycle-t.../12004047.html
#9302
Quoted: 10238 Post(s)
Liked 5,185 Times
thats crazy. I wonder how many toddler balance bikes were in the mix.
#9303
VFL For Life
Bikes: Velo Volmobile
Quoted: 28622 Post(s)
Liked 1,858 Times
#9304
VFL For Life
Liked 1,858 Times
#9305
Liked 9,456 Times
You'd never be able to off-load them, but why let reality rain on the parade?
#9306
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
Big accident in SoDak! (Correction: Sundance, WY) Turbine blade hauler was almost done making a left hand turn but the cattle truck didn't see the blade still sticking out into the road he was on, the blade tore off his sleeper roof, and the cattle trailer got hold of it really good and flipped the blade hauler's trailer and truck over, pushing the blade down the road right into the pickup truck pilot vehicle. Kinda surprised the pickup truck caught fire from an impact so high up on the vehicle.
#9307
Liked 5,185 Times
a year from now you’ll see “plastic” balance bikes for sale on a corner 20 bucks a pop.
#9308
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
#9309
Liked 8,927 Times
I may need to take this to the snowblowers fourms, but let's start here.
My snowblower has developed a problem. Blower is about 15 years old, but the problem only started 2 years ago. It starts up fine and runs for maybe 1 minute. Then dies. Restarts fine. Dies again. I cleaned out the fuel line. Still happens. It has electric start so I have to use it in 60 second increments and restart, which is a royal PITA.
Last winter I didn't need it so I did not mess with it. A week ago I started it up and took it up/down the driveway for several minutes and it worked great. Problem solved, so I thought.
Nope, trying it in today's snow same thing happens. Maybe worse. Runs for maybe 1 minute at idle before it dies. Only 20-30 seconds of active use.
Any suggestions??
Any suggestions??
#9310
VFL For Life
Liked 1,858 Times
#9311
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
Likes For genejockey:
#9312
Quoted: 8282 Post(s)
Liked 9,053 Times
Could you sue Kawasaki if you crashed a Ninja and claimed they didn't tell you it was dangerous?
#9313
Quoted: 9653 Post(s)
Liked 6,365 Times
Any suggestions??
Any suggestions??
The usual culprits are fouled fuel system, fouled air filtration, bad plugs, gunked up carburetor, deteriorated fuel hose, poor carb tune.
I had a boat outboard that did just that once. Tried everything that I knew to do, but with no luck. Then took it to a shop. Ended up being the fuel hose, and once that was changed everything ran fine. The motor was only about 2 years old when I had that problem. I ended up changing the fuel hose as routine maintenance every year after that.
I trust you don't store it with fuel in the tank.
Likes For Mojo31:
#9314
Liked 6,365 Times
That's like 20 horsepower but the instant torque would make it a wheelie machine. Rumor has it Simon is going to sue for $10M. Don't know how that could work except it was said that they just dropped it at his place without any training or instruction.
Likes For Mojo31:
#9315
Liked 9,053 Times
Any suggestions??
Any suggestions??
If you could spray a bit of brakeclean or carb spray (don't use starting fluid) into the air intake and it stays running, then it's a fuel problem. Don't start a fire!
#9316
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
#9317
Liked 8,927 Times
Does it shut down just when you engage the blades? That is, when load is placed on the motor?
I had a boat outboard that did just that once. Tried everything that I knew to do, but with no luck. Then took it to a ship. Ended up being the fuel hose, and once that was changed everything ran fine. The motor was only about 2 years old when I had that problem. I ended up changing the fuel hose as routine maintenance every year after that.
#9318
Liked 8,927 Times
Never worked on one but it could be fuel or ignition. Does it immediately start back up? If it has a carburetor and it just switches off and then restarts immediately it sound like an ignition problem.
#9319
Liked 8,927 Times
#9320
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
#9321
Liked 11,912 Times
That, and scrolling past my niece's 'inspirational' posts on Facebook.
#9322
Liked 11,912 Times
"All's Well That Ends."
#9323
he said member
Bikes: yes please
Liked 1,951 Times
Any suggestions??
Any suggestions??
if the fuel that was in it has ethanol the carb may need replacing or rebuilding. It corrodes the heck out of everything.
#9324
VFL For Life
Liked 1,858 Times
See it here? https://strava.app.link/RBRHspWsicb
So the club is set up to only accept rides? Other activities count too!
#9325
he said member
Bikes: yes please
Liked 1,951 Times
Likes For ls01:
