For the love of English 3 speeds...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Interesting Oddball
listed as a 1955 German built Jaguar 3 Speed
Torpedo hub and ??? trigger?
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
Wow, this is really cool, nice laid back angles like a DL1, cool hub, lovely pinstriped rims. A barrel shifter very much like this was used by SA I think, but it was earlier, maybe teens, 20's?
Quoted: 457 Post(s)
Liked 462 Times
Love the fender ornament!!!
The shift cable has a really cool end to it, no nut/bolt clamp to home the cable at the hub end!
I got my first commute in today on the Raleigh 3 speed. 5 miles each way with a couple of small hills on the way in. The AW range is ok for me on this short flat ride. 48 x 18
Last week I determined that only 2 gears were engaging in the hub. I flushed the rear hub with a healthy spray of wd40. After letting it set for a couple of days I gave it a try and was able to get all 3 gears to engage, sometimes. I splurged on a new chain indicator and was able to get all 3 gears, most of the time.
That was good enough to give the new ride a chance today. It rode ok, I missed a few shifts at some critical points and had a few gear slips between 3 and 2 while pedalling on the flat.
I think the hub will run smoother as I work the wd40 out of it. I plan to add some heavier oil soon.
Likes For JJScaliger:
Hopefully you folks are up to buying it along with my wrenches from my widow when I die.
Quoted: 457 Post(s)
Liked 462 Times
If there is some slack in the cable when the bike is in 3rd gear and you are getting the neutral space between 2nd and 3rd that means you have something wrong inside the hub, it could be gummed up old oil, but it could be something else going on internally as well. 3rd gear is generally very consistent as that is where the springs inside the hub want to go without any input from the shifter.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Liked 443 Times
JackB makes a good point that it should not slip in 3 (the hub's natural/resting state.)
Slipping in 2 is common and suggests a minor adjustment of the cable
Not engaging in 1 suggests a cable too tight or
something wrong inside the hub..
Mechanical failures are somewhat rare.
Over the years I've only found 2 instances,
one was a warped axle, cause unknown.
The other, a mangled sun gear. caused by over tightening the hub.
The trigger plays a part as well and is susceptible to damage/binding over the years.
Hub, cable and trigger all need to work together but once dialed in, are quite trouble free.
A new cable will stretch a bit and periodic adjustments are needed.
Once it's all sorted, you may want to consider a larger cog.
I prefer a 19T or 20T.
Quoted: 1299 Post(s)
Liked 103 Times
It's difficult to diagnose a hub issue through correspondence like this.
Inflate Hard
Inflate Hard
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
One of the cornerstones of my shop, and highest priority in my tool hunt at Westminster this Sunday. I'm even held up in my temporary shop, as without one I can't finish disassembling that burned out Armstrong.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Need to borrow one? You can use it long enough for disassembly, then again for reassembly.
Liked 103 Times
New Crank Cotter Press
Inflate Hard
Inflate Hard
Quoted: 515 Post(s)
Liked 167 Times
Likes For Ballenxj:
Quoted: 887 Post(s)
Liked 335 Times
^^^^ RIP Kirk.
Quoted: 913 Post(s)
Liked 515 Times
I can positively recommend this one from Bikesmith. This is also the best place for replacement cotters.
Liked 443 Times
It is hard to tell from posts on a message board. But, the most likely problem is that it is slipping into neutral from 2nd and tightening the cable a twist or two on the barrel adjuster would put things right. The next less likely would be slipping into neutral from 3rd from too tight a cable, but the cable wouldn't be slack in 3rd so it would be more obvious. After that would be a loose guide wheel that slips on the seat tube or loose cable stop on the top tube that keeps messing up the adjustment after you set it. We can already dismiss a bent or rusted link in the indicator chain since it's replaced. After all those, you can consider things inside the hub like sticky pawls.
Bikes: 1950s' GAZELLE 28"WHEEL GENTS ROADSTER (RALEIGH-MADE)
Quoted: 17 Post(s)
Liked 7 Times
Raleigh roadster rod brake parts for rear Sturmey Archer hub brake.
Hello to all. Firstly,my apologies for bumping into your posts,but it seems that this is the appropriate thread for me to post rather than starting a new thread,as most if not all of the English roadsters/sports owners on the forum are here...
Well,to keep it short: I am restoring my 1950s' Gazelle roadster(by Raleigh,Nottingham, not the Dutch version) 28"wheel 22"gents frame. I am hoping to get the rod brake parts for my Sturmey Archer hub brakes. I have posted a detailed message with diagrams at The Marketplace:Want to Buy forum.
Please do take a look at it and I hope some good folks here would be able to help me out.
My apologies again for intruding. Thank you very much,all the best,BYE&GOD BLESS.
Sincerely,
W.L.SOON,Malaysia
Sincerely,
W.L.SOON,Malaysia
Liked 103 Times
Sincerely,
W.L.SOON,Malaysia
Sincerely,
W.L.SOON,Malaysia
Inflate Hard
Inflate Hard
Liked 443 Times
Sincerely,
W.L.SOON,Malaysia
Sincerely,
W.L.SOON,Malaysia
https://www.ebay.com/itm/PHILLIPS-Bi...S/282476722509
But I've also seen Asian and Indian re-pros for sale as well.
An email to these guys might turn up something
https://www.hoopriderparts.com/custo...icycle%20parts
Quoted: 17 Post(s)
Liked 7 Times
That's a difficult one. Many of the linkage parts are the same as on regular pad rod brakes, so parts from current production Flying Pigeon or Eastman bikes could be adapted to work. From my experience with American coaster brakes, the pads are rarely worn down, just glazed. Roughing up the braking surfaces with 120 grit sandpaper makes a world of difference. It's a good bet you could get away without replacing the pads.
Thank you and GOD BLESS.
W.L.SOON,Malaysia
Quoted: 17 Post(s)
Liked 7 Times
There's a set here, a bit expensive..
I might try Hoopriderparts,but I aim to give it a shot first at finding the correct parts here.
I will post a couple of diagrams of what I need for the brakes so you guys will get a clearer picture.
W.L.SOON,Malaysia
Quoted: 17 Post(s)
Liked 7 Times
Hello to all. I am currently trying to find the proper parts for the restoration of my 1950s' Raleigh-made Gazelle,28"wheel 22"gents frame.
I am looking for the correct Front Sturmey Archer hub brake lever for the rod brake. The old catalogue says the part is a HSB 204,but I have yet to find one,but only a HSB 408. Is it the correct/direct replacement for the 204? Please help/advice.
Also looking for the complete rear rod brake actuating parts as circled in red in the second photo. I need the parts to operate the rear S.A. hub brake.
If anyone have these parts for sale/could help me out,please do reply.
Thank you very much. All the best to you all,BYE&GOD BLESS.
Sincerely,
W.L.SOON,Malaysia
Quoted: 17 Post(s)
Liked 7 Times
Hi.My apologies for copying and pasting my post from the Want to buy forum to here. I just feel that you will see what I need when you see the pics,as not everyone is free to 'go and have a look at another forum on what I want to find/buy'. So here it is. Hope you good folks don't mind. And please do help out/advise.
Thank you very much and GOD BLESS.
W.L.SOON,Malaysia
W.L.SOON,Malaysia
Liked 443 Times
W.L.SOON,Malaysia
W.L.SOON,Malaysia
Quoted: 17 Post(s)
Liked 7 Times
Hello gster. Thank you,appreciate it. They don't seem to have the brake set up that I need,but they do have many other parts that I will spend more time to look at. Thanks again and GOD BLESS.
Sincerely,
W.L.SOON,Malaysia
Sincerely,
W.L.SOON,Malaysia
